Results 1 to 4 of 4
Thread: Soft Spots Repair on Bottom Plank of Clinker Planked wood skiff
    Mar 2017
    Owings, MD , USA
    Default Soft Spots Repair on Bottom Plank of Clinker Planked wood skiff
    Greetings all,
    I'm itching to use my 15' old wood skiff but I've noticed it has some soft spots/wood rot on the bottom plank where the plank meets the keel. It is a clinker planked skiff.
    They are soft enough you can press in a bit but you can't push through the wood and it seems reasonably solid on the inside.
    I used the boat last year and it didn't take on much in the way of water, I don't know if these soft spots were there then or worsened because I had no need to check the bottom until a trailer scrape on the plank made me pay attention in the fall.
    So as far as temporary fixes go, I thought I can either epoxy on a 1/8" mahogany skin over the plank on the bottom after sanding to bare wood. I know this isn't a permanent fix but I figured it would protect it from busting open easily as 85 percent or so of the plank is all solid hard wood so a great base for gluing.
    The other option would be some kind of rot treatment from the inside, or outside after sanding?
    I can't do the veneer overlay on the inside because the ribs would be in the way.
    I don't have time to replank the whole side this year, it's either that or get a new boat most likely. The boat is unremarkable and not anything special on the topside, not an antique or restored classic. Any input appreciated, would love to do some boating this summer.
    Default Re: Soft Spots Repair on Bottom Plank of Clinker Planked wood skiff
    Pics ?
    Is the planking a white cedar? That can appear very soft and funky sometimes.
    But if you think is's gonna pop through and sink you, by all means whatever is needed .
    A single layer of eighth inch may not do much, it needs 2 layers of crossed grain to have effect, thus, a nog of fg might be better.
    I had a half inch by 1 1/2 inch rot pocket under a frame on my larch planked clinker boat. I scarfed in a Dutchman with poxy glue. Still good to this day.
    Just be sure to cut back to sound wood.
    Mar 2017
    Owings, MD , USA
    I would go the dutchman route if it was just one section, unfortunately it is a 1" section or so repeated several times down the plank where the plank meets the keel. I believe the limber/drain holes below the ribs were clogged with leaves and water didn't drain out of the boat when it was left outside not under cover.
    The material is pine or fir it seems, I did a tapping test and all planking sounds good except those few areas along the bottom of the plank where the plank meets the keel. The plank is approximatly 6" wide and it is only 1" or 1.5" area way from the keel that are soft, and it isn't along the whole plank to seal seam just in select spots. The rest of that bottom plank is completely dry and solid so the glue bond will be impeccable if my 'veneer' covers the entire plank butting into both the keel and the overlapping plank above it.
    I can step the overlay plank thickness up to 3/16", or perhaps better yet 2 layers of 3 3/32 if I can manage to plane or resaw some pieces that thin.
