Results 71 to 105 of 150
Thread: Building Heidi | Documenting & Questions
    Sep 2017
    omaha, ne. usa
    Default Re: Building Heidi | Documenting & Questions
    This is turning out to a really good looking boat. Good work.
    Mar 2021
    Virginia, USA
    Quote Originally Posted by jonesmatt1957 View Post
    Thank you, Matt.
    Mar 2021
    Virginia, USA
    Some more tool restoration. This has been hanging in our cottage garage for decades.
    Mar 2021
    Virginia, USA
    After some thinking about how to properly go about it, I shaped the stem cap and spent a few weekends dry-fitting it.
    Mar 2021
    Virginia, USA
    When the time came to fasten it on, a screw sheered in half while I was drilling. I was shocked, and the stem cap was still attached. I had to lift the boat away from the jig with my shoulder, and unscrew the stem cap like a propeller on a by-plane to get it off. The neighbors likely had a laugh. Then I used pliers to unscrew the shank that was in the inner stem.
    Mar 2021
    Virginia, USA
    Bedded it in polysulfide and screwed it on for good.
    Mar 2021
    Virginia, USA
    Then I took some chunks of oak and sketched out the quarter knees.
    Mar 2021
    Virginia, USA
    After cutting them out, I had one hell of a time fastening them on. The clamps kept slipping because of all the angles.
    Eventually they were screwed in. When I install a rail on the sheer they will get screwed in from the outside too and become more secure, but I wanted a few screws on the inside to hold them in the meantime, and since I think the bronze flatheads look good.
    Mar 2021
    Virginia, USA
    I really need to finished the top of the transom, but I do not know what to do. What is recommended? Rounding it over with a router or keeping it flat? How necessary is a scull hole?
    landlocked in Mt. Solon, VA
    Quote Originally Posted by Future Old Guy View Post
    Lookin' great, Oldguy! Nice traditional construction, and much better workmanship than mine.
    Here's my procedure for driving bronze screws. It's admittedly tedious, but so far I have not broken any.
    Drill pilot hole with proper size drill/countersink bit.
    Drive in a steel screw. Lubricate with graphite if necessary (but not with a lubricant that would prevent epoxy from sticking).
    Remove steel screw.
    Install bronze screw, usually with a squirt of epoxy in the hole to both seal and lubricate.
    I use a hand cranked brace with screwdriver bit to drive the screws, not a power driver. Driving the screw by hand gives a much better feel for its progress, and prevents twisting the screw off.
    Keep up the great work!
    "George Washington as a boy
    was ignorant of the commonest
    accomplishments of youth.
    He could not even lie."
    -- Mark Twain
    Jun 2005
    Minnesota
    I love it. Solid! I can't wait to see her in action. Thanks for posting this with the great informative photo documentation!
    Bruce
    Apr 2018
    Bay Area, CA
    I also sewed a sail from a kit and really enjoyed it. Looks like you'll have a chance to test yours long before I will!
    Looks fantastic! Thanks for posting all the pictures.
    James
    Mar 2021
    Virginia, USA
    Quote Originally Posted by UCanoe_2 View Post
    Remove steel screw.
    This is great advice and worked very well, so thank you!
    I had never thought of driving in a steel screw with a phillips head to make life easier with the slotted bronze screw but I just used that technique on some new parts and it worked great.
    Mar 2021
    Virginia, USA
    Quote Originally Posted by hnsbrc View Post
    Bruce
    Thank you! The information from this community has been a God send.
    Mar 2021
    Virginia, USA
    James
    Thank you! Not so sure about that...building the sailing components seem like the most complicated thing I have left. I’m contemplating using it with oars this season and building the centerboard box and mast etc next winter...losing some steam, still thinking it over.
    Mar 2021
    Virginia, USA
    Mar 2021
    Virginia, USA
    Finally got the breasthook in.
    Either way you'll enjoy it. Even during the season you can work on the rig on rainy days or evenings.
    Aug 2019
    Woodstock, ON
    Could not resist taking it off the molds. I still need to shape the transom and install the outer stem, but I am happy with how the planking turned out.
    She does look sweet! Nice job.
    Mar 2021
    Virginia, USA
    Quote Originally Posted by chucksurette View Post
    I appreciate it, thank you!
    Mar 2021
    Virginia, USA
    That may be the what I end up doing. Installing the trunk for the centerboard is what intimidates me the most as I look over the plans.
    Mar 2021
    Virginia, USA
    Here is the wreckage of two battles I had while learning how to deal with slotted screws.
    Mar 2021
    Virginia, USA
    Uploading them for the record before I hide them forever today.
    Mar 2021
    Virginia, USA
    I was happy that I mixed the precise amount I ended up needing, but I should have done each side one at a time because the epoxy started to harden while I was still filling.
    Mar 2021
    Virginia, USA
    And one last word on the frames. After looking for a few weeks, I decided to slim them down after all. It only took an hour or so, and I am glad I did. I think they look better and it will make ensure there is not a large gap between the planking and the seat risers.
    Mar 2021
    Virginia, USA
    Bedded them and refastened them for good.
    Oct 2017
    Berkeley, CA
    Don't know how I missed this thread. Nice looking build, F-O-G!
    We'll never tell, Old Guy. A dab of epoxy and those blemishes will be good as new. Your build is inspiring!
    But seriously, it's time to treat yourself to the Ultimate Cordless Drill. Try one, and you will instantly see the advantages over that modern orange drill/driver.
    https://www.theenglishwoodworker.com...ordless-drill/
    The screwdriver bits can be hard to find, but there are a couple on eBay now. My brace in the photo is the old style with a chuck that fits a square shank bit. Modern braces will accept modern hex shank bits. Of course, make sure your bits fit your brace.
    Slippage can be minimized by making sure the bit fits the screw exactly. It's OK to grind or file to get the exact match.
    -- Mark Twain
    Mar 2017
    Indian Land, SC, USA
    To make driving that steel screw even less stressful, try using a coated 'exterior deck screw' with a 'Torx T25' head - that will greatly reduce cam-out, and the deck screws can be reused multiple times. I discovered the T25 screws while building a large stained-glass-work table and trying to use 3-1/2 Phillips head screws into the pressure-treated 44 legs - cam-out rounded out 3 of the first 4 screws. My local lumber yard guy showed me those deck screws, and all worked well.
    What hawkeye said. Torx head screws are my go-to general purpose wood screws.
    -- Mark Twain
    Mar 2021
    Virginia, USA
    Needed long stretches of oak for the risers and guards. I only had access to 8 foot boards, so I decided to scarf.
    Mar 2021
    Virginia, USA
    This is the jig I used for raised panel doors, so I figured it would make good scarfs.
    Mar 2021
    Virginia, USA
    I will use some epoxy and post the results. I never scarfed before so time will tell how they turn out.
    Raised panel doors! Your woodworking skills are light years more advanced than mine!
    What's the ratio (slope) of your scarf joint?
    -- Mark Twain
    Mar 2021
    Virginia, USA
    The boards are 5/8 and the length is 3"...so if my Maths is right, 1:4.8"?
