Results 1 to 13 of 13
Thread: Instructions help
    Texas
    Default Instructions help
    Working on getting these barn doors installed. I’ve got the 5055 hangers.
    Looking at the attachment; what do you think the “1” max.” on the 2x8 refers to? I’m at a loss.
    Maybe it is trying to keep the top lag bolt from being too close to the top edge? Seems like a goofy answer.
    Hoping you guys have a better interpretation.
    Default Re: Instructions help
    It means a 1” overlap is the maximum allowable.
    Why? Because otherwise the doors would hang up.
    Texas
    That didn’t occur to me. I think you’re right although I don’t see what would make the doors hang up if I had a bigger overlap. As long they were hanging plumb. Thanks!
    My track (same brand I believe) is 1 1/2" up from the bottom of the board it's attached to:
    It's worked fine for a year +
    Apples and oranges shown dimensionally, though. The directions are measuring to the top of the actual door/shutter. Looks like yours is measuring to the bottom of the track flange? Looks nice, though....got pics of the rest of the installation?
    The top of the door is roughly even with the bottom of the board the track is attached to - the door may be 1/8" above the bottom.
    Thanks!
    Texas
    Shop envy. Or even home envy.
    Thanks. This has been planned for 15+ years & was finally able to pull it off. 1/3 shop (yet to be insulated & behind the doors with the wreath) 2/3 equipment storage. Sure is nice to have stuff indoors instead of under tarps!
    WOW! That is gorgeous!
    GD Garret ! That's what I shoulda built!
    Jan wanted steps on the outside, separating the loft better.
    Thank you all! I'm pleased with how it came out. While the framing is all regular storebought (& the metal roof you can't see), the siding (which you can see a closeup of in the track pic) is all local wood from a local mill that (damnit!) burned last fall. They call it "drop siding" & I think it looks great. PITA to stain though... Oh - the stairs are all local cedar & the 6x10 beam behind the door is local hemlock as well.
    Almost in BC, CA
    Last summer I put up a door with that hardware. The diagram on the instruction sheet is poorly done. The door will hang an inch or more below the track, not butted up against the track as shown (see Garret's photo). The "1" max " dimension is to insure the bolt heads (or nuts) are below the 2X8 and don't rub. I used a 2X10 and countersunk the nuts on the inside of the door, so the amount of overlap between the door and the 2X10 doesn't matter. I have a 3" overlap with no problems.
    Texas
    Makes sense. Thanks. I’m going to have to move my blocking. They do hand down quite a bit compared to the instructions. Darnit.
