Page 8 of 8 FirstFirst ... 78
Results 246 to 273 of 273
Thread: Stambaugh Sailing Skiff Build in Virginia Mountains
  1. #246
    landlocked in Mt. Solon, VA
    Default Re: Stambaugh Sailing Skiff Build in Virginia Mountains
    The heat and judicious application of clamps really worked like you guys said it would! From up close, I was doubtful that the chine log would edge set. Stepping back and looking at the profile, it sure did! In this view, all the clamps are off, except for the green ratchet strap pulling the chine log in at the transom.
    "George Washington as a boy
    was ignorant of the commonest
    accomplishments of youth.
    He could not even lie."
    -- Mark Twain
  2. #247
    I realized that the stem needed more lateral bracing. Pushing and pulling trying to get the chine logs to mate was throwing the stem out of plumb. So I added more later braces, the white pieces in this photo. There are also blocks to keep the chine logs at the correct height on the stem, with the heel of the stem 24-1/2" above (below) base line.
    It's nice and plumb now. The little level was purchased at the neighborhood drug store in the 1950s, back in the day when "Made in Japan" was the mark of poor quality. The level has held up well and is still accurate.
    -- Mark Twain
  3. #248
    Here we are at the end of the day's work. The port chine log is clamped in place, after some adjustment to the notches in the frames. We're all ready for temporary screws. I'll fit the starboard side chine log before epoxying everything in place. After all the learning experiences on the port side, starboard should go more smoothly.
    -- Mark Twain
  4. #249
    After a week or so of minimal progress, preparing chine logs for gluing.
    Forward half of starboard chine log glued and permanently fastened...
    ...and aft half of port side glued and permanently fastened. Epoxy plus bronze screws definitely seems like a belt-and-suspenders method.
    -- Mark Twain
  5. #250
    Feb 2003
    Placerville, CA
    Looks like you're getting close to starting planking. Is this plywood-sided, glued lap, traditional lapstrake, carvel, or something else?
    The only man who makes no mistakes is the man who never does anything."
    Roosevelt, Theodore
  6. #251
    It's plywood, Ed. Hopefully planking will go pretty quickly.
    -- Mark Twain
  7. #252
    A few moments were stolen yesterday from Crisis-Driven Home Improvement, and the aft half of the starboard chine log is now glued and screwed.
    -- Mark Twain
  8. #253
    Somewhere along the way, the forward half of the port chine log got attached without being photgraphed.
    Then I realized there had been another major Cerebral Flatulence. You guys are really getting to see the good, the bad, and the ugly parts of this build. Recall my bragging back in #247 about the little 1950s drug store Made in Japan level? I used that level to plumb the stem.
    But the eyeball said something was very not right. When checked with another level, the stem was not so plumb. Guess which level was correct?
    -- Mark Twain
  9. #254
    Time to do a little demolition on work that was just completed. I disconnected all the braces holding the stem in place. Some heat from the 200 watt soldering iron allowed the screws to be removed. I used a hacksaw to start cuts on the epoxy joints, then completed the cuts with the Sawzall. Did you know that the Sawzall cuts on the pull stroke, just like a Japanese saw?
    Here's the current state of affairs. I need to plumb the stem correctly, and then re-attach the braces.
    Attachment 85781
    The Sawzall made short work of the old Made in Japan level. The pieces are now in the scrap aluminum bin. This tool will never mislead me again!
    Attachment 85782
    -- Mark Twain
  10. #255
    Wow, I have not posted in a long time. I have not been idle. Plumbed the stem with a brand new level.
    Attachment 86416
    Of course now the port side chine log, which fit the out-of-plumb stem, is now too short. I padded out the stem with a piece of Philippine mahogany.
    Attachment 86417
    Then some Implements of Destruction boatbuilding with the belt sander shaped it to a reasonably symmetrical match with starboard.
    Attachment 86418
    -- Mark Twain
  11. #256
    Now I have a new problem. At #1 and #2 frames, due to my inexact cutting of notches and the Douglas fir's reluctance to twist, the chine logs are not collinear with the sides of the frames.
    Attachment 86420
    I am planing the sides of the chine logs, but now they will be too thin at the bottom of the boat. Here, a chine log originally 3/4" thick is down to 1/2" and still not in line.
    Attachment 86422
    I'm worried that there will not be enough faying surface for gluing and screwing the bottom planking. I'm planning to epoxy another piece of fir on the inside. If you guys have any suggestions, please let me know.
    -- Mark Twain
  12. #257
    On a positive note, the chine logs are fitting well at frames #3, 4, and the transom. Risers for stern sheets are installed between #4 frame and the transom.
    -- Mark Twain
  13. #258
    Forum software would not allow me to put a picture in the last post, so I logged out and logged back in. Here's the missing photo.
    -- Mark Twain
  14. #259
    Oh, the things we do to earn a few Boat Bucks! Construction has been on hold for a few days.
    Here I am being a medical research guinea pig at the University of Virginia. For the scientifically minded, we are testing how Tylenol affects the accuracy of a continuous glucose monitoring system. For a few days of being poked and prodded, they are paying me well. I'll come out with most of the cash needed for a Trailex trailer.
    -- Mark Twain
  15. #260
    Feb 2003
    Placerville, CA
    A Trailex Trailer is not small change. Just be sure to get your order in well before you need it. I'm still waiting on delivery of one I ordered in March.
    Roosevelt, Theodore
  16. #261
    Good advice, Ed. This is a pretty lucrative guinea pig gig. As you can see, ordering a trailer is still a bit in the future.
    I'm hooked up to the IV again today. Will repost the missing photos from #255 and 256 when I'm back home.
    -- Mark Twain
  17. #262
    So here are some of the missing photos:
    Re-plumbing the stem with a new level:
    Correcting the stem of course left the port side chine log too short. I fitted a piece of Philippine mahogany.
    -- Mark Twain
  18. #263
    -- Mark Twain
  19. #264
    My chine log fitting problem was more complex than I realized at first. Except for the port side of #1 frame, the half breadths at the chine were OK. However, due to the reluctance of the chine logs to twist and my inexact joinery, the upper edges of the chine logs at #1 and #2 frames are too far inboard. It's a little difficult to see in this picture.
    I rigged a temporary bed for the planer and made some tapered shims. These will be applied to the upper edges of the chine logs to make them fair. I'll also have to pad out the sides of #1 and #2 frames by about 3/16".
    My doctor says boatbuilding helps prevent dementia by requiring us to solve complex problems. So, when I have to go to the nursing home I will not be in the memory care unit!
    -- Mark Twain
  20. #265
    Mar 2021
    Virginia, USA
    This is a great thread, impressive building, problem solving, and 'hunting'. I am really enjoying it all! And learning a lot. You have great tools and a nice space. I am building a smaller flat-bottom up in 'NOVA', but I live in a rental. All my useful tools (bandsaw, planer, ect) are at my brother's garage in Lexington, so I make frequent trips down your way to dimension wood and cut out pieces. Lots of time on RT81, but I enjoy the scenery and bought my first smoothing plane from Duke's antiques down there for a good price. I am going to endevour to make my mast and sprit soon and your example has been a great resource.
  21. #266
    Thanks, Old Guy. I have been following your build thread and greatly admire your craftsmanship. Don't use me as an example -- most of my problem solving results from correcting my own mistakes!
    Wave as you go by on I-81. I am a refugee from NOVA, been in this area 46 years and would never go back. Maybe when our boats are complete we can get together IRL.
    Lexington is a great town. I worked there for a few years, and watched the steeple collapse when Stonewall Jackson's church burned. "Draketail" on this forum lives near Lexington.
    -- Mark Twain
  22. #267
    I just looked up Duke's Antiques, and surely somebody on the forum needs their compass and binnacle http://www.dukesantiquecenter.com/
    Old Guy, there used to be a hole in the wall antique store in downtown Lexington that sometimes had good stuff. I have no idea if it is still open, and even 20 years ago the hours seemed to be irregular. IIRC it was on Jefferson St. around the corner from The Palms.
    Since you are traveling up and down I-81, you might check out Rolling Hills antique mall in Harrisonburg (Exit 247) and Factory Antique Mall in Verona (Exit 227). Both are right off the interstate, and I have scored some good old tools there.
    -- Mark Twain
  23. #268
    No photos, but I have been gluing the shims in #264 to the chine logs. I'm kinda bummed, believing that of course everything should fit together perfectly. But then I looked at another boatbuilding forum in which a guy was singing the praises of Bondo for fitting boat parts....Feelin' better now.
    Some of you may remember the thread from last year about "What Would You Do With This Tree?," which began with a 75 foot elm blowing over and ended with that tree plus three others meeting the WoodMizer http://forum.woodenboat.com/showthre...h+this+tree%3F
    Tasks for yesterday and today included sorting through the piles of rough cut lumber and setting aside pieces for boat parts. Here, the tractor is lifting two pieces of ash that will become sheer strakes. They are 17' long, 14" wide, and curved just right. They are 2" thick, and will be resawn and planed to 3/4". Other pieces of ash and elm will become gunwales, breasthooks, and quarter knees.
    SWMBO once remarked that my hobby was lifting large heavy objects......
    -- Mark Twain
  24. #269
    Feb 2003
    Placerville, CA
    Nice! I had a quercus lobata (white oak native to California) blow down on my property a few years ago. It was 18" DBH, and I debated whether to hire someone with a portable wood mill to cut it up on-site. It was on a hill above the house, though, so not easy access. I ended up cutting up the branches (everything under 12") for firewood. The main part of the trunk is still up there.
    Roosevelt, Theodore
  25. #270
    Ed, the professional tree guys have some pretty amazing equipment for bringing logs out of tight spots. Of course, their expertise comes with a hefty price tag.
    Here's a photo of the "Dingo."
    And here is a video of the "Spider Lift" (not on my job).
    -- Mark Twain
  26. #271
    Feb 2003
    Placerville, CA
    Nice gear!
    Roosevelt, Theodore
  27. #272
    It was great fun, and great expense!
    This walnut log was too heavy to lift with the 31 hp. Kubota. I made a sledge to support one end, and dragged it around the field.
    -- Mark Twain
  28. #273
    So, let's take a brief break from the frustration of the chine logs, and work on sheer strakes.
    When we cut the trees last year, I picked out a couple ash boards for sheer strakes. Unfortunately, they were cut too thick and needed to be resawn. The original sawyer was too busy to saw them again.
    Appalachian Woods in Stuarts Draft, VA has a Wood Mizer. They resawed the boards for me.
    The finished product:
    We have two ash boards ~ 17' long x 8-12" wide X 15/16 thick, and nicely curved. The resawing was expensive, but using lumber from my own trees is priceless.
    One of my boating buddies will run them through his lunchbox planer. He's going out of town in a couple weeks, so hopefully we can plane the boards before he leaves.
    There are a few thinner boards as well. I have thought for some time it would be cool to make a bodhran. A thin, steam bent, ash board would make a good frame. There's a rawhide deer skin in the attic that would make a good head. Then I can drive my wife nuts by teaching myself how to play it!
    -- Mark Twain
