Results 36 to 59 of 59
Thread: Building a Seaclipper 20 trimaran
    Dec 1999
    Matera, Italy
    Default Re: Building a Seaclipper 20 trimaran
    Here's a view of the complete swing-wing system temporarily installed on the boat to check the geometry. It works!
    For more details visit the construction blog: http://seaclipper20.blogspot.it
    Dec 1999
    Matera, Italy
    Today we assembled the whole boat to test the aka system with the amas on. It worked!
    May 2015
    Port Elizabeth, South Africa
    It's looking good!
    Do you use a bush or bearing at the aka hinge point?
    Dec 1999
    Matera, Italy
    Thank you! The pivot bolt has a diameter of 12 mm. The plans specify to drill an oversize hole (15 mm dia) and to coat it with several layers of silica thickened epoxy to reduce the diameter to 12 mm. The same is done for all those bolt holes in the aka system.
    Dec 1999
    Matera, Italy
    Deck seats completed. We're about to start the fairing/painting phase. Photo below.
    Dec 1999
    Matera, Italy
    We've started washing and scrubbing everything to remove the blush.
    Question: would epoxy primer be enough to fill and fair the fabric weave, or should we use epoxy/microspheres first?
    May 2009
    Fort Worth, Texas, USA
    Plain epoxy will work fine.
    But filled epoxy will work easier. Might be a little cheaper.
    Microballoons will sand easier.
    Too bad you didn't fill immediately after laminating down the glass. Takes less work.
    Jun 2007
    Quote Originally Posted by pippo View Post
    Epoxy/microspheres/fairing compounds for sure. Primer is for small scratches and such. Don't forget to re-coat the faired surfaces with neat epoxy.
    Dec 1999
    Matera, Italy
    Should I sand before, or would epoxy adhere on (clean) cured epoxy with no problems?
    May 2009
    If you haven't filled the cloth with resin, you can't sand because you will just sand into the cloth.
    Epoxy or epoxy with microbaloons will stick just fine without sanding, if you have water scrubbed away any possible blush.
    I've done it that way several times and never had a problem of the 2nd coat of epoxy coming off.
    To keep from sanding into the cloth, I have found that I need to put down 3 extra coats of epoxy to smooth out the surface of the cloth, and to give enough thickness to sand the surface flush. That means I do 3 instead of 2 fill coats.
    Dec 1999
    Matera, Italy
    Thanks, very useful. Actually our cloth is quite light. We have laminated only 1 layer of 160 g/sq.meter except on the bottoms where we have two layers. It feels quite smooth already...
    Jun 2012
    Salem, MA
    Very nice all around. Boat looks quite spacious for a 20'er. John and Jim do such interesting things - years of making mistakes Jim would say
    Curious about how wide that bottom panel is at it's widest? ... and what ply thickness for that?
    Congrats on doing a good job on this great little design. And thanks for sharing the build pics.
    Dec 1999
    Matera, Italy
    Thanks tom151. To give you an idea, the daggerboard slot is 5 cm wide, so the bottom should be around 45 cm wide at its widest point. The bottom thickness is 12 mm for the vaka (central hull) and 10 mm for the amas (floats).
    Apr 2017
    Lilburn, Georgia, USA
    Bravo! You've gotten a huge amount done in "just" 600 hours! Thanks for posting here.
    Dec 1999
    Matera, Italy
    Thank you Chris. Actually we could have cut that time quite significantly with a larger workspace and a few more power tools. The problem is that those 600 hours are spread along 4 years! Unfortunately, due to other commitments, we can work at the boat only on saturday mornings.
    Dec 1999
    Matera, Italy
    A little update: many things happened, but we are close to finish.
    The two amas, finished and set apart:
    The complete aka system, painted:
    Graphite coat on the vaka bottom:
    Details on seaclipper20.blogspot.com
    Great. I'm looking forward to seeing the launch.
    New Zealand's Far North
    Looking good!
    Dec 1999
    Matera, Italy
    Last sunday we gave the vaka hull a second coat of primer. On the port side of the hull something strange happened:
    Any idea? On the starboard side nothing happened.
    Jun 2007
    How thick was the coat of primer? Multiple thins coats are much better than one or two thick coats.
    Dec 1999
    Matera, Italy
    I didn't measure but it is quite thin, spread with a roller... That was the second coat
    Dec 1999
    Matera, Italy
    Today we completed painting of the vaka hull.
    Dec 1999
    Matera, Italy
    Today we completed painting!
    Details on our blog: seaclipper20.blogspot.com
    Nice!
