Cordless power caulking gun
After watching the guys squeezing goop into the deck seams on Tally Ho, I realized I need a powered caulking gun. My ancient hands just don’t squeeze that well anymore, especially with some of the thicker bedding compounds in a tube. But then I saw the price. Around $300 for the DeWalt (I have DeWalt batteries). Guess I’ll keep squeezing and tell myself it helps keep arthritis at bay.Tags: None -
Re: Cordless power caulking gun
Do you have a compressor? I got a cheap pneumatic gun (they sell for about $30 on Amazon or from Harbor Freight) when I was doing my Sikiflex deck seams. Worked fine for me. -
Do you have a compressor? I got a cheap pneumatic gun (they sell for about $30 on Amazon or from Harbor Freight) when I was doing my Sikiflex deck seams. Worked fine for me.Comment
I have seen these used on construction sites for bedding rebar into concrete foundations and they are the bomb. I don't need one but if I did a lot of caulking I would get one. I have arthritis in my hands and even an hour with a caulk gun means advil the next morning.Comment
Having used a pneumatic caulk gun 50 years ago doing teak decks I have had one in my shop for years. A portable compressor works just fine, preferably one that you can turn down the output PSI so you can just hold the trigger down on the gun and go.
With just a little pressure fiddling it will make for a smoother caulk job with less waste. I have. It used the battery powered versions.
Also worth adding to throw away the cheap caulking guns hardware stores sell that only have a 5:1 advantage and get a proper one that has 18:1 advantage, Newborn makes them, but just check out the ratios.Comment
Whatever you choose for a gun, try to bring your caulk to a temperature well above that at which it's been stored when it's time to use it.
Hot water bath, left in the sun for a couple of hours, put in a moderate oven (120° - 140°) for an hour, all will work.
Pushing goop at 65° F is vastly tougher on hands or batteries than something closer to 90° - 100° and it tends to stick better as well.Comment
I have a caulking gun (English-made?) that I got at . . . Hardwick's, I believe, years ago. Very well made and easy to use.
Milwaukee makes a raft of different caulking guns for both their M12 and M18 lines. https://www.milwaukeetool.com/Search#q=caulking%20gunYou would not enjoy Nietzsche, sir. He is fundamentally unsound. — P.G. Wodehouse (Carry On, Jeeves)Comment
Pushing goop at 65° F is vastly tougher on hands or batteries than something closer to 90° - 100° and it tends to stick better as well.There is nothing quite as permanent as a good temporary repair.Comment
