(The obvious alternative is the one part solvent based polys: brightsides or ez poxy, but not quite ready to give up on water based stuff yet).
Anyone used Totalboat Elixir?
So apparently System Three is permanently discontinuing their water based polyurethane paint (what used to be called WR-LPU, and recently changed to Pennant Topsides). I only used it once (panted the inside & outside of a 16ft boat), but really liked it: no fumes, and at least to me, much easier to use than at least traditional oil enamels. I looked around at the only replacement that I could find is a product by Jamestown, "Totalboat Elixir" which looks on the surface pretty similar. Anyone used it?
(The obvious alternative is the one part solvent based polys: brightsides or ez poxy, but not quite ready to give up on water based stuff yet).Tags: None -
Re: Anyone used Totalboat Elixir?
So, have you tried sanding the old junkimeanwaterbasepaint off? -
So I guess that’s a no to my actual question Bruce.Comment
WR-LPU is a linear polyurethane just like Awlgrip. It cures because of a catalyst not because of evaporation. I've used both and sanded both with no problems. It does not gum up sandpaper like latex. I used WR-LPU on my dingy five years age and I've been shocked by how tough it is and how well the paint has held up.
Based on the price, and the fact that they are comparing it to oil enamel, I would expect Totalboat Elixir to be softer than WR-LPU. I think a closer equivalent would be a water borne acrylic urethane. Awlcraft is a solvent borne equivalent. They're becoming the dominate car paint in large part because of California.
Sorry I don't have a better answer to your question. Elixir is cheap enough I could see buying some just to make some test samples.Comment
Unfortunately it is no more…
When I search for “water based acrylic urethane”, the only things that come up are non-marine products (eg, Ben Moore COMMAND). Is that what you were thinking of? I know people use house paints (even latex stuff), but I’m not sure if I want to experiment.
If I stay w/ marine, and want stuff that is reasonably easy to use, does that mean a closer equivalent in terms of end result would be a two part poly (interlude perfection, epifanes poly, etc)?Comment
They both have to be sprayed and aren't particularly user friendly. If I were painting another boat I would use Envirobase or Alexseal. I don't know of a waterborne paint marketed as marine that would be as good as WR-LPU or the 2 part solvent borne polyurethanes.
Amazon still has some of the WR-LPU in stockComment
If they are permanently discontinuing it, thats a big disappointment.Comment
I tried to order some color samples from duckworks. They initially said it was delayed, for exactly the reason you said: testing, etc. then the other day they told duckworks (who told me: wonderful people!) that they had decided to pull it entirely. Best guess is something must have come up in testing and they didn’t want to fix? If I was in progress I’d reach out to try to find out what, but for me it just means I need to find something else…Comment
Major bummer. I was actually going to come to this subforum and write a review of the application. It does not level perfectly using roll and tip, I can normally get a near perfect finish with Perfection. But its certainly a 3-5 foot finish and the ease of use (no sanding between coats), and lack of smell, certainly seems worth it. I had done my cockpit last summer and because a change in the way I was dogging down the sole hatches, I sanded those off and refinished them. From the sanding experience, I can tell its a dang hard paint.
Oh well.Comment
