Can someone guide me to 'bend' maple branch to make a cane ?
My lady has mobility issues, and often uses a cane to walk. My neighbor took down a maple tree, and I secured a branch / limb piece about 4 feet long and approximately 2 inch diameter ( the bark is still on and the ends are painted ) . I would like to make a custom cane, shaped somewhat like a Christmas candy cane, but am not sure how to bend one end into shape. Any suggestions or advice would be appreciated.
RickCharter Member - - Professional Procrastinators Association of America - - putting things off since 1965 " I'll get around to it tomorrow, .... maybe "Tags: None -
Re: Can someone guide me to 'bend' maple branch to make a cane ?
Make a jig and steam it? Best do it now while the wood is still green. A "live edge: cane sounds like a cool idea.Steve
H.A. Calahan -
i might be inclined to boil the end to be bentSimpler is better, except when complicated looks really cool.Comment
All great ideas - thanks - I will keep monitoring for new ideas. . .Charter Member - - Professional Procrastinators Association of America - - putting things off since 1965 " I'll get around to it tomorrow, .... maybe "Comment
Generally this bend is best made while the branch is still on the tree, and alive. Next best is to steam it with lots of steam that is just barely over 212f. Too much heat will cook the wood. You can also try putting fabric softener in the boiling water/steam. Fabric softener is basically a sort of wax that may help the individual layers of lignin/cellulose slip by each other.
I used fabric softener on a difficult bend about 40 years ago, and it definitely helped VS. steaming w/o fabric softener. Since then I've mostly resorted to laminating difficult bends.Comment
Whichever method is used, the branch should be pared down to near its final diameter prior to bending. Trying to do a 180º bend in 2" diameter stock might prove daunting.
JeffComment
Thonet mostly used/uses beechwood. Works well for bending when steamed.
Given the number of different members of the Acer family it's hard to predict what you'll have to go through to bend 2" green stock to much less of a radius of 10" or more if it's even possible.
For your walking stick project, something closer to 1 or 1-1/4" ought to work to a tighter radius, maybe 5 - 6". 3/4" to 1" ought to work to something tighter.
Use some kind of metal support along the outside as you increase the radius as shown in that Youtube video, keeps tension on the outer layers to prevent splits from getting started.Comment
It would be easier to bend a longer piece into a U,then cut it into a J.
RSleep with one eye open.Comment
Still 'tracking' all the recommendations - thanks - - - - What is the best idea for cleanly reducing the diameter from , say, 1-3/4 " with bark on down to 1" 1-1/4" without bark ?
RickCharter Member - - Professional Procrastinators Association of America - - putting things off since 1965 " I'll get around to it tomorrow, .... maybe "Comment
