In the last couple of years I have also had to brace myself against one of the walls and hold on to the stair railing to get down stairs. Knees and hips being 80 provoke slow stair descents and using whatever is available for balance reinforcement.
As a result, the horsehair plaster has crumbled so badly where I've braced myself that it has fallen off the wall, revealing the lathe behind.
So now I will have a stairwell that I can poke holes in without plaster crumbling, and two long hallways upon which to hang more art.
So one hallway is maybe 8 feet long and the other one is more like 12 feet, and at one end of the shorter hallway there is a single overhead light fixture. At an end of the other hallway is also the same lame thing, right at the base of the stairwell.
I'd like to install track lighting in the ceilings of both hallways so I can actually see the art.
Now the questions: Shouldn't I get 6' track for the shorter hall, and even longer track for the longer hall? The shorter hallway has two doorways on either side of the overhead light fixture, so the first 30" of the track won't light anything. The longer hall has a doorway on one side and the bottom of the stairwell on the other, so again, the first 30" of track won't light much.
When I look at track lighting kits, it seems like after 4' all the tracks branch out from a central electrical connection. Is there longer track that begins at one end, rather than the middle?
If I have to have the ceilings rewired, I'll have to get an electrician to change the current wiring. Presumably that's something that the sheet rock installers are not licensed to do, and thus needs to be coordinated so it gets done while the horsehair is down and before the sheet rock goes up.
Does that sound right?
