For some reason there is a huge dump of used chain mortisers on ebay right now, from $300-500. The only catch is they are coming from japan and are rated for the rather strange 100V, 60Hz supply.
Do you think they would even notice the difference plugged into 120V 60Hz? I've been trying to figure out if I can swap the motor or add a VFD to the side, but it almost seems that a motor that works on 100V will probably work just fine on 120V if the frequency is correct. What do you think?
I'm willing to take a bit of a risk, as I'd be saving literally thousands off a good Makita mortiser.
