Our horse shoe lifebelt is made from foam. We bought it early 2019. Well known brand and so on. The boat is out in summer, but under cover in winter. The belt has a considerable number of cracks in the surface - without being mechanically stressed. Probably degeneration from UV light.
Flashing life belt light - the first, bought with the previous boat, had a liquid mercury switch which for some reason unknown to me was broken. On the second one (different brand), the catch that holds the cover in place broke when I closed it after putting batteries inside. I got it swapped for a new one, which was eventually sold with the previous boat. The third one (same as second) bought early 2019 got a stuck automatic switch already in late summer 2019. When the boat got hit by a wave, often, it would start to flash and only stop when given a slight slap. Upsetting when crossing shipping lines at night. Returned to supplier. The fourth one (different brand) bought early 2020 was fine in 2020 but when the boat was put in the water again early 2021, it very soon developed condensation inside. A closer look revealed, that water was standing permanently in the joint between body and top. Returned to supplier. The fith one (bought in spring 2021) seems to be more for the proessional market and still works, the surface has only turned a tad dull. Battery life is 5 years and apparently, it is glued together, so, possibly no way to change the battery. But at least it still works and has no condensation.
Rescue sling system which came with the boat - the part of the floating line that is attached to the pushpit needed to be replaced as it had deteriorated in the UV light so far, that it just dissolved when touched. Now, this short piece of line does not have to be floating line ...
GPS, Chart Plotters - It does not seem to be usual to have a single big red or yellow button for MOB position. On at least some gizmos, for MOB, you have to go into second or so menue level ...
Inflatable Danbuoys - also discussed with the colleague at the club yesterday - his status was, that when there is a lot of wind, they will lie flat on the water ...
Any similar experience from others?
