I have a very simple design for a plywood boat build. I've purchased epoxy, fiberglass, plywood, what have you. But what I cannot understand is the hull design portion. I've download "Hulls" and toyed with it, "FreeShip", and "Delftship", and yes, I am computer literate. I've coded in "C" and "Perl", administered UNIX and Windows machines, what have you. But for some reason, I cannot understand how to use these applications. I've purchased plans for various designs, but this somewhat defeats the purpose of what I am doing.
The design is for a 3 chine hull, 15.5 feet long, 4 foot beam, 30" transom. Hull depth of 23" aft of the 8 foot mark from the bow, 30" forward of that, I know, it's weird, but this is an experiment for what I do on a local reservoir. Maybe 5 frames total, including the transom.
So basically, I need to cut (3) strips of plywood to make each side of the hull. I've considered just starting by cutting the uppermost portion and seeing how I could fit the other parts, but this does not seem like the proper way to go.
Is anyone here an expert or at least seasoned user of "Hulls" or similar and can point me in the right direction. At a minimum, I would just like to get the design in the software and loft as appropriate.
Thank you!
Garry
