The guy I bought it off was also completely clueless so all I knew is that I had a boat.
It came with a sail, pretty short mast, yard and gaff (I think ) currently using it as a boom but have left it untouched incase I decide to use it for its intended purpose.
After a fair bit of online research I decided it should be a balanced lug rig with the materials at hand.
Does it look correct ish?
I've currently got no outhall or downhall.
The outhall I think I can sort easily enough but the boom is very low and right now there's not enough space to fit a downhall without the boom hitting the upper mast step (probably not its actual name)
I'm trying to come up with solutions and am hoping that a bit of adjustment such as tying the sail slightly higher up the yard or changing the attachment point between yard/mast/halyard might get me slightly more boom height.
Just looking for possible suggestions to sort out a working sail rig of any description without having to buy another sail. I'm willing to make a new mast if required but ideally I'm looking for something quicker if not optimal to get me started.
Thanks in advance
Sam
