I agree that going the kit route wouldn't be imprudent, and the costs aren't a tremendous detraction. Unfortunately, that does seem to dramatically limit choices. Perhaps a good thing in some ways as the signal to noise is distracting. With that said, I'm not looking to spend too much on my first build. I'm anticipating budgeting around $5,000 or so for this project as a "proof of concept" and will be willing to budget more in the future if this build goes well.
Good advice. I double-checked this morning with the local lumberyard and they specified that it's Roseburg marine-grade plywood and it's also made of fir, just like their ACX exterior-grade. So it goes.
I was hoping for something under 16' which more or less is a function of the available space in my garage. Perhaps I'm being a bit conservative, but my hope is to store the boat indoors when not in use to limit dramatic temperature swings, moisture, and UV exposure. Additionally, if I'm storing a boat separate from a trailer which would need to be stored outside, a smaller and lighter boat would make it much easier to deal with, most especially if I need to do it solo.
Great suggestions. I went to the CLC site and reviewed both designs. The Jimmy Skiff II seems to be the best fit, but when I scrolled down, they specified that it would only work with a short shaft outboard and I have a long shaft Suzuki. I would hate to have to make any major modifications to support my motor (being a new builder) and it would likely end up looking like a hacked on kludge. The Peapod is absolutely beautiful and something I would be very proud to build and own, but being a double-ender, I was skeptical it would support an outboard. Reading further down, the designer specifically stated that it will not work with a motor. I bought the Suzuki (new) a few years ago, expecting to have a use for it, but plans changed for a number of reasons; hence part of my desire to incorporate use of the outboard in my planning.
I've heard that the GIS can be a bit tender (not as important for me as much as it would be for a passenger), but has good sailing performance. I'm not sure how much there is to that, having never seen one. Another design that I've taken a look at, also available as a CNC kit, is the Oonagh. Do you have any familiarity with this design? I feel that it might work out even though she looks a little small.
I've taken a look at the Navigator and she's a bit heavier than I would've preferred. I'm also looking for something with simpler rigging like a single mast with a balanced lug. Couldn't find a CNC kit for the boat either, and I spoke on the phone with someone yesterday who mentioned that Welsford's plans don't have the same level of detail and clarity as other designers. This wouldn't be as big of a concern to me if this wasn't my first "real" boat project, but I feel it would be important to have plans intended for new builders at this stage.
Speaking of CNC kits, what are your thoughts on full-sized plans? In my mind this would require more time and effort over a CNC kit, but it would also help to eliminate a source of easy errors. At the very least, it would afford a broader array of potential designs.
I appreciate it. Thankfully I'm not in a rush with some arbitrary deadline in mind. Ideally I get something on the water by next summer, but it isn't critical and am taking a deliberate and patient approach. I want my first boat to be something I will want to use often and keep for a long time. I don't really want to build a boat to be deprecated quickly.
