Correct. Always been intrigued by the Bolger Micro. But, the square sections and blunt bow were a bit too much. So, mine is a bit longer and has the raised cabin from a OZ build and the sides angle out to the lower rub rail, then return to the top, so it is 6" wider, that, running forward, gave an angled bow, a bit sharper..
Stern was angled out a bit, then returned to the 'deck' level.
Laminated up the main mast, mizzen in bits, as the temps are around 0°C. Quite close, after several years of fiddling. Aim to sail her to the Semainedugolfe.com in Brittany in April.
I must fugure out how to post pics. Tried a few times, but Not. Tec specialist, someone else..
