I made a new spiling batten out of the previous one, spiled the next plank, and made a full pattern out of 3mm MDF. I had thought I would have to dog-leg scarf this one, but as I had been supplied with 8" (200mm) planks I didn't have to, and I think the next one will be even straighter. Then I drew around the pattern onto the next kauri board, cut it out with my jig-saw slightly clear of the line, planed it to the line, drew around it onto the next board, cut that one out then planed the pair to match, which is my usual process.
I was not entirely happy with the way the after ends of the previous planks fitted onto the transom, so I looked at my books again and cut the rabbets a different way, as you see here. You can also see the spiling batten and the patches I was talking about last time. I cut away part of the end of the plank so I could see what was happening there. This is shown in my book, "Thoughts on Clinker Lapstrake Dinghy Construction" by Peter Peal, who did his boatbuilding apprenticeship in Auckland in the 1930s. It's very interesting. Well, the other way would have been alright too, if I had done some more work at fitting them, but they seemed OK at the dry fitting stage. The other end of the plank is hanging from the roof beams.
This is the result.
The other end, dry fitted.
A general view.
After more fitting and fiddling, I got this pair of planks permanently fastened down today, with sealant and the same screws. I didn't steam them. I am leaving them overnight and will clean them up tomorrow, drill the holes, clench the nails, and do the beveling for the next pair (strake?). That will be four strakes done, only five more to go......
I was going to put another photo in, just a general view from aft, but I selected the wrong one, so I deleted it but it still gets counted as one of five. It will appear as an "attached thumbnail". It's from when I was transferring the planking marks from the battened side to the other side, some time last year.
Ian
