My very slow build of a small 12ft s&g boat continues...I am nearing the point of glassing and applying epoxy to the inside BUT am thinking of adding a mast step, partner, daggerboard box etc so I could sail her with a very simple standing lugg rig. I was originally thinking of just rowing or maybe getting a little outboard motor, but...why not go a bit further. The boat plans do not detail a sail plan however the designer does state it should sail reasonably well....so, we'll see about that.
I'd really appreciate some experienced feedback from the good folks on the forum on my initial draft sail plan, if anyone has a few minutes please?
Why am I not asking the designer I hear you say...well they would'nt confirm the transom height required for a short shaft motor...I do not believe they know where the designed waterline is, maybe I am giving them a diservice. Anyway my faith was gone after chasing for a response and then getting a non-commital response
I've done a little (and I mean a little) research but quickly established there are some basic fundamentals and thereafter it gets rather technical and I have'nt the energy to try and correctly absorb techy stuff, I'm not building a racing boat and the other half wants the "bl**dy boat out of the garage please"
cheers
Benny
Hull length 12ft, water line approx 11ft, beam 5.5ft
My initial thoughts are: Mast 11ft (I want it to fit inside the boat) hollow birdsmouth as my friend will router the timber for me in his shop, yard 8ft, sail dimensions approx: luff 5.5ft, leach, 13ft, head, 7.5ft, foot 8ft
Is the daggerboard correct in relation to the centre of sail or would it need to be more forward?
