New question: ‘Any recommendations for a Sitka spruce supplier for our 20’ mast, gaff and boom? Minnesota, Wisconsin or Florida preferred, or could ship to Florida.
Sitka spruce for mast?
Thanks for earlier responses regarding bronze hardware for the 15’ Wittholz catboat we’re building; we’re going with JM Reineck and Son; ‘knows the boat and has been very helpful.
New question: ‘Any recommendations for a Sitka spruce supplier for our 20’ mast, gaff and boom? Minnesota, Wisconsin or Florida preferred, or could ship to Florida.Tags: None -
Re: Sitka spruce for mast?
Forest product supply in Maplewood has carried 4/4 Sitka in the past (and still lists a price so could presumably order it), so has the woodcraft in Bloomington. -
You can also get it from McCormick Lumber in Madison. They're iceboaters, so when you mention a mast they know what you are looking for.
https://mccormicklumber.com/sitka-spruceComment
Sitka Spruce is the gold standard of spars but your hull will stand up to aloft weight of a fir stick. We are taught that weight aloft is bad but it can slow your roll, from which some boats benefit.
but scarfing is not a problem. I like 12:1 faying surfaces and I make them dead accurate - no highs and no lows. I dry fit so all way of keeping the work in place are covered, remembering that epoxy is a lubricant till it sets. I use unthickened epoxy until the faying surfaces cannot take more, the on one surface a coat of mildly thickened epoxy before anything goes off, clamp them together.
It would not be odd to have the mast made up of four long pieces that are themselves made up of end pieces to reach desired length. Stagger the scarfs.
G'luckComment
I built the mast Ian described for my 14' catboat, which has roughly the same hull as you are building. That stick has held up to hard sailing on San Francisco Bay for over 20 years.
ATT Park.jpgComment
AlComment
There was an article in Classic Boat about building the mast for one of the biggies. 160 odd feet. They sourced the sitka from Canada, but it was not easy, as almost impossible now. Glued it with a version of eurea formaldahyde, as that gave the best results in lab test for ageing.Comment
Don't overlook the supply that might be serendipitously available from your local lumber yard. I'm not talking about the big box stores, but the small local yards. Go there early on a Saturday morning and peruse the longer lengths of 2x6 and 2x8. Or even the wider stuff. IF you're lucky you will find beautiful long lengths of spruce with tight pencil sized knots and 20+ growth rings per inch. I've built several spars from material sourced this way, with excellent results, and really good prices compared to the specialty marine sources. Oh, and be sure to stack the lumber neatly when your're done rooting through the piles. Else the yard men will give you the evil eye next time you come in.Comment
Don't overlook Spruce scaffold planks. They're not Sitka, probably Black Spruce, which is an excellent mast material.
2 in. x 10 in. x 16 ft. Cleated Spruce Scaffold Plank is a great choice for your scaffolding. The wood scaffold planking doesn't conduct electricity or retain heat, making it a safe and comfortable alternative to aluminum planks. The cleated feature prevents movement for more stable and safe. This scaffold plank can be nailed, notched or cut as required and is easy to erect. Features Designed specifically for use asComment
https://www.ihlcanada.com/2-in-x-10-...ld-plank-21859Comment
