Another Hartley TS16 restore.
  • Time
  • Show
Clear All
new posts
  • Another Hartley TS16 restore.
    With the retirement of Redwing another boat was needed, and a downsized one at that. I've always liked the Hartley TS16, and in fact my original plan was to build one.
    Anyway I bought one.
    It involved a road trip to somewhere substantially colder, but it was fun, and it was nice to get away for a day or two. Also I got to meet JayinOz.
    Once home it was a matter of reorganisng the shed to fit the new boat.
    And there it sat for a couple of weeks.
    I did manage a few hours removing all the cabin sole and bunk panels and vacuuming out the hull inside the cabin.
    And I did find the partial remains of a previous owner.
    Which brings us to today.
    Without freedom of speech, we wouldn't know who the idiots are.
  • #2
    Re: Another Hartley TS16 restore.
    Today was follow the rot and see where we end up. I started on the port quarter of the cockpit seat as I knew it was dodgy.
    So a bit of digging showed it was in to the beamshelf and a section of topside but it's reasonably small.
    So I set the power saw to a depth of 6mm and removed a good sized section of cockpit seat. Hammer and chisel removed the bits over framing.
    Judging by the fact recorcinol was used in the original construction I would say it was constructed sometime in the 60s or early 70s.
    • #3
      So, topside, I won't know how bad till I strip the paint back but I will probably replace the whole section from the transom forard to the buttstrap.
      Moving on the the outboard well and the transom uncovered another fairly big area of rot, but not in the framing.
      As for the transom, I had hoped a patch would work, but I'm thinking it may be smarter to replace both layers of the transom ply.
      • #4
        This looks familiar, ouch!
        • #5
          Yeah, but done properly this time. There's no rush, no hardstand fees or time limit.
          • #6
            If you remove and replace the transom make sure that the hull is secured.
            Have heard of problems with hull springing out wide and it is tough job to pull it back into shape and ensure the hull is correct.
            • #7
              Buttstrap??
              You could do without that “outboard well” thing Gary, 'might make things a bit easier for you.
              • #8
                I feel really bad now- it looks awful! I'm sure there was no rot in the transom when it was painted, so I'm thinking that has happened while it's been sat in the shed over several years- rain and leaves sat in there wet. And that captains cap was in good shape when the rats stole it! JayInOz
                • #9
                  Go hard on it Gary.
                  • #10
                    I'd ditch the outboard well too. Extra room in the cockpit there!
                    Do you still have the outboard bracket from the other one?
                    The racing boys in NZ don't even have outboards, they treat them like a big dinghy.
                    • #11
                      Hartley transoms are quite strongly framed, and this one is sound. All I need to do is strip the ply off and replace it.
                      • #12
                        Originally posted by Larks
                        Buttstrap??
                        I was thinking of a modified outboard well with a locker in the middle.
                        • #13
                          The outboard bracket on Redwing is quite heavy. I'm going to stick with clamping it to the transom.
                          Something like this.
                          • #14
                            It looks worse than it is. Ply is easy to replace and the bit of rotted framing is quite small. The transom ply is damp and the dirt in the bilges was damp as well...it kills plywood quite fast once it gets going.
                            Relax Jay, I had a fair idea what I was buying.
                            • #15
                              Ok- relaxed So are you intending to have a little outboard on it Gary? I could have let you have the one that was on it cheap- a little five horse Tohatsu in as new condition. For that matter I could have left the wheel and forward controls on and you would have had a lot less holes to fill JayInOz
                              Working...
