Been fitting the hardware- I think (hope!) it's going OK so far.
I did the drilling over size holes and re drilled for the M8 bolts. I added a slurry of epoxy to the bolts and fitted them using a large washer and a lock washer. The oak pad is epoxied to tge deck. I epoxied the steel plate to the oak pad, and used a butyl sealant to bolt the bollard to the plate. The head of the bolts are buried in the oak pad and epoxy is in the holes. I just thought if I ever wanted to remove it, it will be much easier with a butyl sealant as opposed to epoxy.
