Building a Ross Lillistone First Mate
  • Time
  • Show
Clear All
new posts
  • Building a Ross Lillistone First Mate
    Hi all. After lurking on this forum for a decade I've finally gotten around to starting a boat. Over the years I've been researching different designs by many designers, but it just didn't work out to start building. My wife and I recently bought a house after living in an apartment for a year, so now I have a garage again. I grew up canoeing and sailing a Sunfish in the Chesapeake so I wanted something small for the shallow water, but faster to row and drier to sail.
    Anyway, I finally settled on Ross Lillistone's First Mate stitch and glue dinghy. I've been living vicariously through WI-Tom and AJZimm's camp cruising threads which is something that really appeals to me and helped me pick this design. I had originally convinced myself on the lug rig, but I think I've changed my mind to the spritsail and jib. I'll probably end up trying both rigs at some point, but I don't see myself making the Bermuda rig.
    $650 of Okoume plywood. I have six sheets of 1/4" and one of 1/2".
    I originally drew everything in CAD to be cut out on a buddy's CNC router, but it's brand new and he hasn't got the software to read my files set up yet. I'm in a hurry to get this started, so I did it the old fashioned way with pencil and ruler. The quarter is for small radii like the limber holes. I used the base of a Coke can for the larger radii.
    Here's one of the bulkheads cut out. High dollar beam compass to mark out the ventilation and hatch plate holes.
    Before scarfing the 4x8 sheets together I wanted to get a bit of practice using epoxy. I primed both 1/2" centerboard pieces with neat epoxy, then slathered on a healthy layer of thickened epoxy and weighted it down. Two drywall screws preserve the alignment and were removed after the epoxy started to harden. Saran wrap keeps the whole thing from getting stuck to the bench.
    The next day I attacked with an angle grinder and flap disk to give it a bit of a foil shape. I intend to reinforce the edges with thickened epoxy when I get around to fiberglassing the outside.
    http://sailingmoga.com/
  • #2
    Re: Building a Ross Lillistone First Mate
    Armed with my epoxy practice I started in on scarfing the plywood sheets. These are 1/4" thick, so I set them back 2" for a 8:1 slope. Each layer is screwed to the one below at the edges.
    Then I started planing out the stair steps. Probably not the best plane for this job, but it was the one I keep in my tool bucket and the rest were 30 minutes away at my folk's house.
    It's a bit wavy in places, but a decent first attempt I guess. I'll make sure there's enough thickened epoxy to fill any gaps.
    Next I taped some plastic to the garage floor and glued it down.
    I snapped a chalk line near the edge to give me a good datum and marked out the points for one of the planks. I don't have a 16' batten so I used a piece of shoe moulding to mark out the curve.
    Eventually I got the bottom, side planks, and most of the other parts cut out. I still have one full sheet of 1/4" and a fair amount of the 16' panels to use for decking and laminating the rest of the parts (mast step, mast partner, rudder, cheek filler pieces, cleat pads, etc.) I also have the ubiquitous box of scrap that's too small to keep, but too big to throw out.
    • #3
      Here's a shot of all the smaller parts.
      The heros of this part of the build.
      So far I've been at it for just over three weeks and I hope to have this boat done by the spring of next year.
      • #4
        Will be following!
        • #5
          Good grief Jeff, my shoulders ache at the thought of using that tiny plane for the scarfs! Props for getting such good results; you definitely earned a cold one.
          Ross's designs have such a clean look to my eye, and his Periwinkle was on my short list before I decided on an Oughtred Fulmar. I'm looking forward to watching your progress and thanks also for sharing it with us.
          Mike
          Mike Builds a Boat on YouTube!!
          • #6
            Great choice! I love cruising my Phoenix III.
            I started with the 76 sf balanced lug but added the little jib Ross drew last year. I now run the original sail as a standing lug with jib set flying, and it has dramatically improved the boat's performance. Now my first reef is dropping the jib, moving the downhaul, and resetting the main as the original balanced lug. It has been a handy, simple, effective upgrade.
            • #7
              WOW a new build to follow
              i'll be interested to see which rig you end up setting
              i kinda like the added method of reducing sail jon m mentioned above which w/ 3 rows of reef points would/shoud provide you with a much more manageable rig when Mother Nature spanks you(i didn't say IF)
              you mentioned camp cruising as part of your dream so... IMHO listening to WI-TOM and studying his travels and rig evolution would be time well spent
              please keep the pics coming
              sw
              steve
              • #8
                Great to see another First Mate build. I'm going to share a list of things that I would have do different based on experiences with mine, and you can do with it what you will:
                I should have added a foot to the length of the mast shown in the plans. The boom is too low to see under without leaning over and I have to really duck down when tacking.
                A solid mast is fine weight wise, but a hollow spar for the balanced lug would help the sail hold it's shape better in light air and bumpy water. The spar could also be a little less thick. It is very stiff and makes it hard to flatten the sail with the down haul.
                I'd redesign the rudder and centerboard case attachment so I could lift the rudder.
                I'd use porch and patio latex rather than simple exterior latex as it is harder wearing. The easy touch-up of latex paint has been nice.
                I wouldn't have added weight to the centerboard. It should sink under its own weight and I ended up using a line and clam cleat system that makes that irrelevant anyway.
                One thing I did that has been really nice was to use a hole saw to cut a 1" hole in all of the side deck knees to use as tie down points.
                I spent time thinking about visual details and it was time well spent. Things like making a sweeping arc to the deck around the mast instead of a straight line and mirroring the varnished rub-rail on the inside of the cockpit to add a bit of contrast added time and complexity to the build but are things that I like seeing every time I sail.
                • #9
                  I'm in. Thanks for sharing your project!
                  • #10
                    cracked lid gives good advice. I did both of these on TWO-HEARTED as well. I have lengths of thin shock cord running through the holes in the deck knees and they are great for stowing jackets, lights, charts, or whatever up under the protection of the side decks.
                    Try moving the downhaul attachment forward on the boom to set the sail as a standing lug. It doesn't affect performance too much and raises the boom enough that I can actually sit on the thwart and row beneath it.
                    I also just remembered that I made a measurement error which added about an inch to the gunwale; it's been quite useful because the wider gunwales help knock down the spray, and the wider decks are great for hiking out when things get sporty.
                    • #11
                      Great start, keep those photos coming!
                      Ken
                      • #12
                        Originally posted by jon m
                        [/COLOR]Try moving the downhaul attachment forward on the boom to set the sail as a standing lug. It doesn't affect performance too much and raises the boom enough that I can actually sit on the thwart and row beneath it.
                        I appreciate the advice, and I have played around with the downhaul attachment point as the block just has a cowhitch to attach it to the boom. I use the bleater setup on Storer's website that loops the line around to the boom and onto itself with taut-line hitch. I can go from balanced to standing lug configuration in very little time, but the issue I found with doing this is that it brings the front of the boom down even more, and at that point there isn't enough space between the top and bottom blocks of my downhaul set-up to fully tighten it, so I'd also have to redo my downhaul arrangment plus I still have the visibility issue looking over the bow, which is actually a bigger deal to me than ducking to tack. All in all, it isn't a huge deal, as if it was I'd just make a new mast. But considering I cut the mast down to make it the length in the plans, I figured I'd save someone else from the same issue.
                        • #13
                          Thanks all for the comments! I'm glad to share my progress with the community, after all I've learned a ton browsing old build threads and hope mine can help someone in the future.
                          I emailed Ross the other day and got a copy of that drawing, along with the gunter rig. I haven't studied the gunter very closely, but it appears to use the same mast as the spritsail and lug which might be interesting to experiment with someday.
                          I definitely agree that the spritsail rig is not conducive for quick reefing. I guess I should clarify my thought process. My day sailing area is in a pretty protected creek and small river so I think the spritsail might be the better option for that. However, once I get out into the Chesapeake I do think the adjustability of the lug setup will be ideal. Realistically, camp cruising will probably be less than 10% of what I do, so I think I'll make the spritsail first and then eventually make the lug and pick between them based on the conditions and what I plan to do.
                          Cracked lid, thanks so much for your advice. I've read through your build thread multiple times to get an idea of what to do. Ross does say in his plans you can add a foot to the mast and I was leaning that way. The line/shock cord running through the interior was also high on my list of modifications. What exactly do you mean about the rudder and centerboard case attachment? I though the rudder does kick up?
                          That's interesting. In Ross's plan update he mentioned making the gunwales stick out about 1.75" from the hull.
                          So I started zip tying the planks to the bottom and I'm pretty stoked with how well they fit. The curves seem to match pretty well and the lines for the bulkheads are lining up.
                          Whoo! After nearly 2 hours of work it's finally time for the whisky plank!!! haha
                          Here's the hull tied together and most of the bulkheads positioned. I need to cut some stiffeners and glue them one before zip tying them in place next.
                          • #14
                            I agree, and when I eventually replace my birdsmouth mast with a carbon one, it will be 10-12" longer.
                            • #15
                              The rudder kicks up. The tiller cannot be lifted and there are times when it would be handy for it to be able to rotate vertically.
                              Working...
