The diagram of my proposed repair is at the bottom of the blog post.
Questions:
- What size screws?
- What type of wood to glue in? Should I use spruce or a harder wood? I don't want it to split, with the addition of about 100 screws, spaced 3 inches apart.
- What type of epoxy? Flexible? I have lately seen advertised some epoxies that are supposed to be more flexible. This mast is designed to flex in heavy wind. I don't want to inadvertently over-stiffen it.
- Do I epoxy in the screws. The whole business about adding epoxy to holes in wood, per the West System Bros, has me a little skeptical.
- Main concern is that I don’t want to split the mast along its glue-line. That's why I don't want to simply attach the track to the mast itself, because the screws would go directly into the glue-line. But I thought that if I added epoxy into the holes, after drilling them to a larger size, then it might actually end up stronger. In which case, I could just plane off the luff groove and dispense with adding another piece of wood into the slot.
- Second concern is to maintain flexibility in mast and need an epoxy that compliments that flexibility
- Should I use this as an opportunity to embed antenna and mast head light wires in to the mast? And if so, what kind of wire do I use for the masthead
- And unbelievably, I'm still questioning whether I shouldn't just stay with the luff groove in the mast!
I'm a beginner with spars and rigging, and I don't think I have covered the whole thing very well, and so I am looking for guidance and experienced replies.
Thank you in advance,
Josh
