Some progress today, tomorrow I hope to finish the rest of the keel structure. I've decided to mount the keel prior to putting on the Xynole. I figure it will be less stress doing all that mixing and glassing one side at a time. I'll wait to fillet the keel until I glass the bottom to tie it together.
Put a fillet under the laps...
Continued to work on the stem, put a bevel on it so its 7/8ths wide in the front, looks quite a bit different, it was nerve racking putting a power plane on the stem after having spent two days making it, all came out well, no goofs, Shinto was key...
here is a before and after..
Before
After...should I take the bevel higher up the stem? maybe another few inches?
Also located a spot for the boweye and the stem is now screwed to the boat and ready for epoxy...the hole almost came out perfectly centered on the inside stem, it's off about 1/8". I drilled the stem, got it nice and centered first, at the angle I needed for the boweye, then I used the stem as a guide to drill the hole in the boat.
I need to to decide how high to carry the bevel on the stem, I think I'll take it about half way up the sheer plank.
