The rigging that came with my boat is minimal. I will need to replace all mast hardware with the exception of sail track. Should I relace all harware on the mast and hull with modern equipement or should I try to match the "vintage" hardware on the hull? I would prefer the former as it is easiest option. Nickles Boat Works will likely get the job. I plan to use the boat for "spirited" day sail not racing. Opinions?
