I need to cut a hole on the top of my copper fuel tank to gain access to clean the tank. Currently the engine fuel supply and fuel return are connected to the bottom of the tank. I want to cap these connections and run the fuel supply and return lines from the top of the tank.
The only solution that I've seen so far to close the opening on the tank is from SeaBuilt. www.seabuilt.com
Are there any other products out there that does the same thing?
