Page 1 of 3 12 ... LastLast
Results 1 to 35 of 71
Thread: Need some help- stripped positive battery cable bolt
    Apr 2001
    Riley, Mi U.S.A.
    Default Need some help- stripped positive battery cable bolt
    I asked the shop that the car was in two weeks ago to replace the thing but they forgot. Now I have corrosion at the positive pole, the alternator won't charge the battery, and the head of the bolt is stripped beyond vise grip use. This kind of stuff only happens in the middle of winter. Any ideas for getting it off?
    Nov 2002
    Sitka, AK
    Default Re: Need some help- stripped positive battery cable bolt
    Top post, or side post?
    SPID
    First thing, disconnect the neg cable before you attack the pos cable. If your metal tool touches the pos cable and any other metal part of the car, there will be serious excitement. Maybe an exploded battery, maybe just sparks, but best not to find out.
    If this is a post-type connection with a clamp-end cable, no worries. The posts are slightly tapered and lead is soft. A little judicious wiggling by hand will usually break the corrosion and the cable will slip off. Be very sure when you're wiggling the cable end that the post is not moving. Another approach is to spread the cable clamp ever so slightly with a large screwdriver. Again, make sure you don't twist the post. You can get replacement clamp bolts at any auto parts store.
    Now, if this is a bolt-on connection and the bolt is stripped, you may end up cutting the cable and replacing both battery and cable.
    Sep 2004
    Huntsville, AL
    I'd try a Dremel tool with a mini disk grinder. It should take maybe 10 minutes. Hopefully you are able to get at the bolt without cutting the terminal. It would be ideal if there is a split in the terminal where the bolt goes through and you can position it there.
    The disk grinder looks like one of these:
    http://www.lawson-his.co.uk/scripts/...&product=13106
    The other day I used this method to cut loose a corroded wing nut that was frozen. I went through one of these disks and partly used up another in the process.
    Will
    Apr 2001
    Riley, Mi U.S.A.
    Side post.
    SPID
    Oooooh! Not pretty. Maybe an angle grinder. You might be able to grind away enough so the connector comes free. If you're living right you might be able to get the bolt stud out of the battery and save both the battery and the cable. At this point I'd think about disconnecting the cable at the starter and removing battery and cable together so you can work at it effectively.
    Oct 2003
    Hell
    you tried using the cable itself a wrench? or light taps with a hammer and chisel or screwdriver?
    Mar 2001
    Grosse Pointe, Michigan, USA
    Hand grinder w/cutoff wheel.
    --cuts through almost anything--bolt, bracket, that heater hose....
    Apr 2001
    Riley, Mi U.S.A.
    I was afraid to do anything after the bolt head stripped. I think what I'll have to do is get a new cable end before I destroy the old one getting it off, that means waiting until tomorrow afternoon when I'll have swmbo's car to use.
    I've got one of those, Dan. Only used it once in five years.
    Oct 2003
    Hell
    Quote Originally Posted by Rich VanValkenburg View Post
    keel bolts?
    Nov 2002
    Sitka, AK
    Better get some PB Blaster on it. I think Normans got a can you can borrow.
    Apr 2001
    Riley, Mi U.S.A.
    keel bolts?
    No Paul, another auto-related battle, sway-bar links. Rusted nut in a confined space.
    I just did one the other day I used a new pair of vice grips that had a slight curve type and you can clamp them just on it when you move the connector you need to move the cable and the vise grips at the same time as the cable may be stuck to the connector but if you keep at it you will get it off and i even put mine back on with out cutting the connector
    Bangor, ME
    Oh, that does look ugly. Spray it with liquid wrench, put a torch to it, lightly, and then try the locking pliers again. I like the idea, too, of using the cable itself to turn it. Some combination will get it loose.
    So many questions, so little time.
    Jul 2001
    Memphis TN.
    Cut the cable at the terminal. Remove the battery. Use needle nose vice grips to remove the old terminal and replace with new one. That bolt is a really soft metal, maybe lead. I could get it out with my teeth.
    It might help to get rid of the corrosion by pouring a mixture of baking soda and water on the old terminal and then spraying with Liquid Wrench or WD 40.
    Jul 2001
    Memphis TN.
    " put a torch to it, lightly"
    Oh yeah! That's what I would do......I forgot.
    Sep 2001
    USA
    Quote Originally Posted by KingKuvas View Post
    NO... DO NOT TRY TO ROTATE THE CABLE...it has radial teeth on it's face, and the battery has meshing teeth on the case...Rotating it will ruin the battery...but in this case, your going to be buying a new battery and a new cable anyway... Get on it with vice grips, and find the biggest strongest guy to clamp them on whats left of the bolt, as others have said, some liquid wrench or other cant hurt.
    Southern Maine
    See Mikes post, please don't follow Ish's advice and put a torch to it.
    It really looks run of the mill to me. I think you need better (or smaller) vice grips. You could run it to a shop.
    I'm sending you a bucket of perseverance.
    Jun 2001
    FORGET the torch!! JESUS!!
    Hydrogen gas is explosive.
    "Why, sometimes I've believed as many as six impossible things before breakfast." - Alice
    Bangor, ME
    The battery is dead, right? Not much if any hydrogen about. If it's venting some still, it won't go boom.
    Jul 2001
    Memphis TN.
    Quote Originally Posted by ishmael View Post
    Automotive mechanics is not one of your strong points, is it?
    His batterie can explode from just a spark fully charged or dead.
    Bangor, ME
    Whatever. Don't use a torch, fine with me.
    Jun 2005
    Seymour, TN
    Ish, let me very gently suggest that you do NOT attempt any car repairs on your own. Your suggestion is at best misguided and at worst, completely negligent. I am surprised at you.
    Rich, let me strongly suggest you heed the preceeding five posts, excepting Ishmael's. You can try the suggestions above (if you use the grinder/cutting wheel, do so OUTSIDE and in the open air as they can also produce sufficient sparking to ignite the battery, but - as a former professional mechanic - you're gonna probably replace battery AND cable. I assure you that it is far better to spend the money and NOT endanger yourself! It's what I'd do faced with the same situation.
    Oct 2003
    Bright's Grove, ON, Canada
    Right, not much.
    It would just be a small explosion, possibly spaying battery acid all over you.
    What could go wrong?
    If you do try it, remember to say "Hold my beer and watch this!". It will make the story so much better.
    Allan of the Grove
    "never send a ferret to do a weasel's job.."
    Jul 2001
    Memphis TN.
    The main problem you are having is that you don't have enough room to work on it with the battery in the car. If you cut the cable and remove the battery and follow my instructions, you won't have any trouble replacing the terminal.
    Apr 2001
    Riley, Mi U.S.A.
    Sometimes....
    The thing about the radial teeth is true. Been thinking that one through since Paul suggested it. I do have a set of curve-jawed vise grips and I'll try those. Got to get the corrosion off of the connector to see what there is to grab onto, the negative post should be a good indicator.
    Ya know, I used to do all of my own car repairs, but it's not fun anymore and I'm not as strong as I was in my 30's. I should get whacked upside my head for not dealing with this last August when I didn't need a snowsuit.
    Bangor, ME
    If you guys think a dead battery is going to explode if you put a bit of heat to the terminal, I don't know what to say. It's not. The off-gassing from a dead battery is nonexistent. I will say, I wouldn't try it with a live battery.
    Sep 2002
    Ash, NC (not Asheville)
    I've got a dead battery around here somewhere. I'll take a torch and attach a looooooooong pole to it and see what happens. Care to back up to it with your britches around your ankles Jack? I'm gonna have to borrow someone's vid cam. My cam takes horrible video and I'd hate to have to reshoot it for Jack's Darwin Award.
    Doug
    Feb 2005
    San Antonio, Texas
    If you trim away some of the plastic on the cable it will probably expose enough surface to grab with a pair of good channel locks. Channel locks used correctly grip much better than vice grips when trying to turn round objects. Grip the round part of the bolt, not the now stripped hex part. With a little manipulation you can usually get the bolt free from the cable end. You can then replace it with a very short , about 1/2 inch long with 3/8 -16 thread IIRC or go buy a replacement - they're cheap. If the cable is easy to replace (some aren't) do it.
    Chris
    Dec 2008
    Bradford, NH
    It might help to get rid of the corrosion by pouring a mixture of baking soda and water on the old terminal and then spraying with Liquid Wrench or WD 40. __________________
    PB Blaster is better on this application.
    clean it up first.
    then if you have enough cable length that you can replace the cable end you are home free.
    disconnect ground wire
    cut the cable as close to the terminal as possible.
    Remove battery. Set battery on work bench.
    Carefully use center punch first and drill the center of the bolt. (it's a soft one). Use a proper marine type long taper reverse direction screw extractor. Tap it in with a light weight (I use a body shop sheet metal hammer) hammer. back the dam% bolt out carefully re-tapping the extractor in if needed.
    Worked in 1968 on stuff at the Chrysler dealership I was an assist. service manager at and still worked last year on my daughters GM POS OLDSmubble. She loves her late model PT Cruiser she got when the Olds folded in half from rust.
    IT WILL WORK JUST BE PATIENT!
    Replace bolt and cable end.
    By now the lack of proper charging has probably sulfated your battery plates.
    If you have one use it if not borrow or buy a Home Depot Husky charger and use the battery re-condition feature overnight. Your battery may be in better shape than a garage or parts store would ever tell you. They want to sell you a new one. In the navy we de-sulfated our battery plates once a month.
    good quality car batteries and marine deep cycle ones last a lot longer with proper care than most would think.
    Re-install with proper felt corrosion pads and dielectric grease.
    Chase
    P.S. I would not, nor would you want, to replace the batteries in my 40 ft. Prevost conversion bus. LOL $$$$$$$$
    Sep 2001
    USA
    SIDE MOUNT TERMINALS in 1968 ??? your sure ??
    Dec 2008
    Bradford, NH
    The big one we used technique on as "stuff" in the late 60s was the built in rusting of the early Mopar disc brake caliper bolts. Less than a year and whoa boy.....
    Seems like every used late model mopar we bought at auction for our lot had the same problem.
    Every car is different, they all have their unique design flaws. Even Audis and Mercedes cars. I could give a list for each of those two.
    Apr 2006
    sussex county delaware
    If that battery is over 3 years old, not worth the trouble - replace it. New cable, too, as it may have a lot of internal corrosion. I've replaced a few that weren't that old but were essentially red powder in a plastic casing.
    Mar 2005
    FL. USA
    A Rigid, 6" pipe wrench will beat vise grips any day of the week. It will also still grab bolts rendered useless by vise grips.
    Bangor, ME
    My assumption was that people have half a brain.
