Results 1 to 4 of 4
Thread: Motor bracket question
    Nov 2006
    Mississauga, ON Canada
    Default Motor bracket question
    I've decided to replace my ageing transom hung aluminum out board motor bracket for one with springs to assist in lifting. My motor is a 75lb 7.5 h.p. 4 stroke Honda. Garelick make a motor bracket for motors up to 20 h.p and 115lbs but they state quite clearly that this is NOT for 4 stroke motors. Does anyone know any reason why I shouldn't use this bracket?
    Chris
    Jun 2007
    Dover, NH
    Garelick also makes several mounts for 4 stroke engines. In looking at their website, I couldn't readily tell why they specify 2 or 4 stroke as the ones I looked at, all operated on a vertical plane.
    You can call them and ask:
    Garelick Customer Service Call Center PHONE : 651.459.9795
    Hours 8:00 - 4:30 Central Time
    http://www.garelick.com/contact.php
    It's all about weight. The countersprings are designed to work with motors of certain weight ranges. 4-strokes are heavier, so they need stronger brackets with heavier springs.
    Don't get one rated too far from the actual weight of your motor, as it can be really hard to push down into the lowest position if the springs are too stiff/heavy and the motor too light.
Similar Threads
  1. Home generator question
    By marshcat in forum The Bilge
    Last Post: 09-08-2007, 01:42 AM
  2. Robert Fisk: Even I question the 'truth' about 9/11
    By Tylerdurden in forum The Bilge
    Last Post: 08-26-2007, 11:18 AM
  3. Repost "Plywood" (NIA)
    By Ross M in forum Building / Repair
    Last Post: 08-11-2006, 03:22 PM
  4. Deck Caulk (grab that stick, this horse is only kinda dead) Repost
    By Jim Hillman in forum Building / Repair
    Last Post: 11-11-2005, 02:10 PM
