Results 1 to 24 of 24
Thread: Battery recommendations for MinnKota?
    Default Battery recommendations for MinnKota?
    I'm getting ready to set up some sort of electric propulsion with a 12v Minn Kota 48# thrust motor, and am looking for recommendations for an **inexpensive** battery to start with.
    The motor will not be set up permanently in the boat, nor will the battery. I'd prefer not to slop acid all over the place, but the AGM or Gell batteries are pretty pricey compared to the "maintenance-free" well cell batteries. I know that the regular open-top batteries allow better testing and water-replacement, and I have a plastic battery box, but still wonder about the sealed batteries as a better option.
    My boat is 14', weighs about 400lbs, and will have a fairly long cable run from the bow (where I need the battery weight) to the transom-mounted trolling motor. Weight is also a factor as I'll be hoisting the darn thing in and out of the boat.
    I won't be running the system for hours and hours, and realize that a 'proper' setup would consist of dual 6v golf-cart batteries, chargers / testers /meters / etc.
    But at this stage I'd like to pick up an inexpensive 12v deepcycle battery to test with, and might combine it with another deepcycle later on if the system works and I need the extended range.
    There is a lot of info on the web, mostly from battery manufacturers, but it sure looks like the AGM is replacing the gell battery and has a slightly reduced cost - but still 2-3x the cost of a wet-cell battery.
    http://www.windsun.com/Batteries/Battery_FAQ.htm
    http://www.batterystuff.com/tutorial_battery.html
    Any suggestions?
    I used a wet cell deep cycle/starting battery to power my 20' sloop for about a year. I mostly sailed up and down the canal whenever there was a breeze, but the battery seemed fine. The sloop weighed 1 ton, the canal 4/10 of a mile long, it didn't leave me stuck. I don't remember how often I recharged it, but not every trip for sure.
    Mar 2001
    Delton, Michigan
    A sealed gel battery will do the trick. No spillage and they are available in deep-cycle versions. An 85 amp-hour battery will weigh about 65 pounds. A little heavy; no matter what battery you use, be sure to secure it well.
    Dec 2000
    Have a brand new one sitting downstairs......come and get it and it's yours....
    Wakan Tanka Kici Un
    My wife just flew out to NYC this morning, maybe I'll have her take a cab up your way and bring it home on the plane?
    ( NOT )
    ;0 )
    Just buy a cheap dual purpose battery and put it in a plastic box, and try it out. If you need something bigger, or more high tech, you can always use the battery you bought for the car. My sense is that you don't need something huge and expensive. A regular lead acid should be fine.
    Wooden boats are like shingles, recurring, and often painful.
    Feb 2001
    Seattle, WA USA
    I'd look at Optima batteries -- their "Blue Top" is what they recommend for marine/deep cycle use.
    I believe you can get them at Sears. They're not too hideously more expensive than a good lead-acid battery (Froogle found them for about $180 online).
    The Optima batteries are actually lead-acid batteries, but the case is completely sealed and the plates are wound in spirals. They can be mounted in almost any position -- supposedly even upside down
    Optima also makes a case ("Troll Fury" ) that lets you bridge 2 of their batteries as one: you can configure it in series (24v, double the voltage) or in parallel (double the amperes).
    Here's how these batteries are put together:
    From what I can tell, the Optima batteries are AGM, not old-school wet acid. And AGM looks like a much better option than Gell, which it is replacing rapidly.
    But as I said, the cost per Amp Hour looks double for the AGM compared to wet acid. If I was building a serious electric launch, I'd certainly get the good stuff -- but I'm not, and not sure how much use the trolling motor will get. Hence my request regarding the cheaper wet acid style.
    "The major construction types are flooded (wet), gelled, and AGM (Absorbed Glass Mat). AGM batteries are also sometimes called "starved electrolyte" or "dry", because the fiberglass mat is only 95% saturated with Sulfuric acid and there is no excess liquid."
    Sep 2004
    Ohio
    Also note that AGM's must be charged at a lower voltage than standard wet cells. 13.8 v. rather than 14.2 v. While they are "sealed", they are also vented to relieve pressure if overcharged. The higher voltage will cause them to off gas, shortening their life. Be sure the charger you use has an AGM setting.
    My co-owner buddies and I just spent a lot of time researching batteries since the old set of 4 golf-cart 6V batteries died. We concluded the advantages of the sealed gel-cells and other more expensive types aren't worth the extra cost.
    I think, and my own experience bears it out, that careful maintenance of a basic lead-acid deep-cycle battery will get you years of use. In short, pick one up at K-mart - you may even get a good end-of-the-season price now. The main thing is to recharge it fully right after use, monitor the levels and keep it charged over the winter. Batteries that die young have usually been abused.
    Thanks again, everyone! Battery is on the tricklecharger as we type...
    I hit Kragen's Auto parts on the way home and picked up an Exide Nautilus Gold marine deep cycle battery for $64. 80 Amp Hrs, 140 reserve minutes. Priced out by Amp Hours, the old wet batteries are still a better deal, even if they aren't the 'real thing' for serious electric motor use.
    I got the NG24 - http://www.exideworld.com/products/m...old_specs.html
    Apr 2004
    Brisbane QDL (Everton Park)
    Don't go yacht, go commercial. A friend of mine owns a golf course and says the Trojans hold up better than others.
    Mark Twain
    Apr 2003
    Dallas and points north
    I was going to recommend either a Trojan or Rolls Series 27 for about $95...and you would have very good quality batteries. The Rolls (Surette) is probably better than the Trojan but costs about the same.
    RB
    Sep 2005
    new zealand
    Quote Originally Posted by Peter Malcolm Jardine
    Whatever you do for the battery, dont scrimp on the cable. If it is undersize, half the battery power will just be going up in heat in the cable.
    Pete
    Mar 2001
    Grosse Pointe, Michigan, USA
    AGM batteries supply the equivalent power of wet acid for about the same cost, but half the energy. This means they cost twice as much per hour of running time. Advantages are low self-discharge, no liquid to spill, and high resistance to deterioration due to deep discharge. The latter offsets the basic capacity limitation somewhat.
    Jul 2006
    Gray Me.
    For cheap steady power, nothing beats a 6v golf cart battery.
    If you can afford it the rolls or mastervolts are the trick item.
    Use a variable pulse charger on the boat. don't scrimp there.
    Chargers kill batterys if they are cheap.
    Too many times I have seen good expensive batterys on $2 buck chargers, and when they fail the battery gets blamed.
    Jul 1999
    Vancouver
    So, you have a series 24 there. If it's technology you like and it doesn't produce enough steam you can fit a series 27 in the same box. From there you're up to a series 29 and that's going to need a couple more inches of length but no more width - still way smaller and lighter than an 8D or a couple of 6V golf cart batteries, and available from the same maker as the one you have. From the direction you've gone those are your options if that one doesn't work - but I think it will. You made a good call in terms of cash economy in my opinion.
    I'll be more enthusiastic about encouraging thinking outside the box when there's evidence of any thinking going on inside it.
    -- Terry Pratchett
    Rather than confuse everyone, I'll start a new thread on charger recommendations.
    Haslett, Michigan
    You need at least a dual purpose battery. I found one for my trolling motor at the local battery manufacturer in town. Reconditioned for $30 for a size 24. The more amp hours, the more they weigh. The size 24 only weighs about 35 lb.
    Question about Epoxyboy's post and general wiring --
    Does it do me any good to buy and string huge thick wires if the Minn Kota leads are relatively small in diameter?
    Seems like the little electrons would jam up and get frustrated at having the pipeline get so much smaller before they could reach the motor?? Or is the gain in lowered resistance for 80% of the length of wire run worth the cost in extra copper?
    ;0 )
    Should be able to find a chart on the net that shows voltage loss over length... Use a good quality #6 wire... marine grade, and good connectors. Should be fine. The connectors are crimped, and maybe a small covered pair of terminal blocks to connect the minn kota to... that way you can permanently install the wires in a tidy fashion.
    Sep 2004
    Ohio
    There is a chart in the waste marine catalog that shows recomended wire gage for length of run and current draw for both 2% and 10% voltage drop.
    Jun 2006
    SE Mich
    It does make sense to use battery cables to hook to the dinky wires on the motor. The energy wasted as heat in the wire is a function of amps (not volts), wire gage and length.
    Scroll down on this page http://www.powerstream.com/Wire_Size.htm to find a voltage drop calculator. You would want less than 2% drop in your wire. For instance 50 amps and 14' results in a drop of 3% with 4 gage wire, 1.9% with 2 gage. You can put in your actual max amps and cable length.
    Denny Wolfe
    www.wolfEboats.com
    Sep 2004
    Ohio
    And remember, the wire length is the total length of the circut, from the battery to the load and back to the battery.
Similar Threads
  1. New ceramic battery 500 mile range 5 min recharge
    By sdowney717 in forum The Bilge
    Last Post: 09-22-2006, 07:10 AM
  2. How do ya know if its the battery or the alternator ?
    By Joe (SoCal) in forum The Bilge
    Last Post: 06-19-2006, 04:54 PM
  3. Lead-Acid Battery charge question
    By Hughman in forum Building / Repair
    Last Post: 08-12-2004, 09:18 PM
  4. EDTA - a Battery Preserving Agent?
    By Oyvind Snibsoer in forum Building / Repair
    Last Post: 10-28-2001, 01:17 AM
  5. Fire Hazard: Recall on Dewalt/B+D Battery Chargers
    By Nicholas Carey in forum Building / Repair
    Last Post: 08-15-2001, 09:07 PM
