Results 1 to 50 of 71
Thread: Starting Rescue Minor in Plywood HELP
    Jul 2006
    Newport WA, on the Pend Oreille river
    Talking Starting Rescue Minor in Plywood HELP
    I have choose the Rescue Minor because of our moving sand bars and river weed (mill foil). My boat building experance is little my woodworking experance is good. My shop is OK but will improve as tools are needed. I spent my life figuring out how to do things for other people now it is my turn. The one comment I don't want to hear is don't do it.
    I do not plan to follow the plans to the T. Don't think I could bend that 3/4 inch ply.
    What I am thinking.
    change the rabbited chine to beviled and butt the plywood then cover with glass. what dimensionsfor the chine?
    Change the keel (flat bottom) to 3/4 inch Okoume in place of the 1 inch 1942 plywood. maybe run a couple of stringers.
    The bottom laminate two layers of 1/4 Okoume plywood.
    The sides 3/8 Okoume.
    Deck 1/4 Okoume.
    I came from the aerospace world so can not help to think light.
    I am open and would like to and need your comments.
    Thank you
    May 2004
    Cuyahoga Falls, Ohio
    Light is nice, but most boats seldom need to take to the air.
    Robb-White's son is around. You might discuss your ideas with him.
    Oct 2003
    Hell
    That design has been a popular topic here of late.
    A quick and dirty search reveals these threads: Search for Rescue Minor
    Jul 2006
    Yes thanks I have been following it for a few weeks.
    Sounds like you are building to the original Atkins plans, not trying to copy the highly-modified version that Robb White built, right?
    Been checking out the yahoo group? Subscribe: AtkinBoats-subscribe@yahoogroups.com
    My suggestion would be to follow the plans closely -- but if you want to change things, pay most attention to the dimensions and shapes. I understand that the tunnel shape and prop size and placement are **critical** for the propulsion to work.
    Don't go too light on the bottom if your waters may include hitting bottom occasionally, trailering on rough roads, or sitting out low tides on uneven ground.
    Will you use an old shaft motor as per plans, or try some sort of mod with an outboard? All very tricky stuff as I've heard, mostly as above with prop size and angle in the tunnel, but also sealing the tunnel as it sort of pulls up the water into the prop.
    Good luck and have fun building!
    Jul 2006
    For a engine I am considering the Yanmar 22HP diesel. With gears it is a little slow in revs I am looking at a 10 dia 12 pitch prop. (which comes first the pitch or dia) I tend to agree about the bottom thickness. Yes I plan on keeping the shapes as designed. Hope to make it look like the original.
    Apr 2001
    Thomasville, Ga
    I think 3/4" on the flat bottom would be fine, especially if it is fiberglassed. That is the only part that hits if you run aground. Laminating the rest out of two layers will be aggravating, but will make it much easier to get the shape right. My father was extra careful to duplicate the tunnel exactly as Atkin had designed it. That was the only lofting I ever saw him do. I am running a 10 1/2 x 12 on it now (I have always put the diameter first). 22hp should be fine, but I don't know about the gearing. He rigged his belt drive to give the same rpm at the prop that the plans specified. Lightweight is good, but he did find that his will cavitate running light. A bucket of water or a big cast-net on the bow fixes it. He was sure that, built to Atkins planned weight, it would not have been necessary. Sorry for the long post.
    Wes White
    Jul 2006
    Thanks Wes, I need long posts I have a lot to learn. I keep you posted on the engine and gearing. I am looking forward to making this.
    Wes, you've been a member here for over five years. And you are an experienced, inovative designer/builder of cool boats. No need to apologize for long posts. I for one would welcome hearing more from you. The longer the post the better.
    Steven
    May 2006
    Spokane, Wa
    river guy: Hey imagine the irony. I live on Long lake in Spokane! I just received my plans from Pat this week and am going to be tackling her over the winter as well. I had planned to go the 1" on the flat bottom and 1/2" or 3/8" okume on the tunnel. 3/8" or 1/4" on the vertical surfaces, and a lovely layer of 8oz to protect her.
    PM me if you get a chance, this could be a fruitful coincidence as we could build simultaneously.
    E
    Jul 2006
    Gray Me.
    Default rescue minor
    Mine is going together cold molded, I found it the only practical solution to my abilities. I am making molds so I can build another because I have some weird ideas I would like to try.
    Following Robbs build and with his encouragement I am considering running a kitchen rudder on number two. The drawings are comming along and there is a bit of machine work involved. It seems like a perfect combo but I am nuts anyway so if I muck it up or have to start modifiying it I find it better to have one good example left.
    RW's setup was incredible and I thought I would give it a go, but the whole point I think he was trying to make was to go "your own route" so here go's the batty Kitchen rudder idea.
    Back to cold molding I felt layups of 3 or 4 mm would do the turns well and allow me to get that full one inch on the bottom.
    Jul 2006
    I like to hear more of your cold molding The design botton is 3/4 inch with a 1 inch flat keel how are you working the layers into the deadwood in two molds like Robb White strips?
    Jul 2006
    Gray Me.
    I am building molds to support the frames on a strongback. steam bending the oak and laminating the keelbox and knees. I will layup on that then flip her. I think that is probally the simplest method. I will still end up with a 1" keel and 3/4" sides, just stonger with the diagonals in the layed up sheets. I am trying not to deviate to far from the original plan. I hope to be starting this month but I had to have some site work done to set the bow roof shed on. The site is almost ready
    with all the excavation done. Three feet of topsoil and a lot of stumps later, Drainage ditch in. Just waiting a couple of days for it all to dry out (3" rain in 6 hours this weekend) then the base goes in.
    The shed is 32x14 and woodstove equipped with an out building next to it for storage and the like.
    I will pop along some photos as it goes together.
    I envy the guys that have readymade shop space. Its as big a project to get ready as building the boat itself.
    Default Power for the Boat
    I see you're considering a Yanmar for power. Yanmar certainly has the rep for being a very sound marine engine.
    I looked at Yanmar, Universal and Beta. Both Universal and Beta use the Kubota tractor engine that Robb White used as their core. They then add the stuff you need to make a marine engine.
    I found Yarmar the heavest and most costly and Beta the lightest and cheapest. Beta seems to have done a good job pull all the stuff you need to reach/check out of dark corners and putting in invery accessable places. Beta also provides a short parts list cross referenced to "tractor" parts so you can buy spares at farm store prices rather than boat shop prices.
    Jul 2006
    I have not made a engine selection and the and I like the farm parts bit I live in farm country to bad John Deere dropped its small diesel marine engine. I am a diesel fan and will probably run BioDiesel. But I also want quiet. I do want to have a engine that is ready to install in a boat either by conversion of manufacture. The controls must be easy to use as it will be operated by everybody from above my lead Husky she only gets to steer.
    Engines are a problem The RPM have increased since 1942 even the new diesels are running faster than the gas of that time. The Rescue Minor plans call for a 10X12 prop. And a shaft speed of 2000 RPM. Most of the new diesel max out at around 3700 RPM with the torque starting to fall of around 2600RPM. The transmissions I have found are have a 2 to 1 reduction or greater. To achieve the RPM recommended for the RM this would call for a 1.35:1 reduction to stay above the torque curve. I see why Rob White was using a belt drive I believe he was running his engine at 2700 and the prop at 2000 RPM with a 10.5X12 prop. I don’t understand his reverse.
    My questions are:
    Is there another engine
    A transmission
    Am I missing something?
    What about increasing the pitch of the prop. We are stuck with the 10 or 10.5 prop inch dia.
    What about a three blade etc.
    May 2006
    Spokane, Wa
    Guy, a good agriculture option is to go into the local shop that carries combine parts. Combines have one powerplant that runs ALL equipment installed by belts ( except the hydrostatic tranny). Give them the rpm your engine makes and what you need your shaft speed to be. They should be able to come up with a V-belt system that will be smooth to operate, easy to maintain, and in the event you do foul the prop it will slip until you can get the powerplant shut down.
    E
    Default Gear Box Ratios
    Most of the small engines I mentioned will be offered with a choice of gear ratios.
    The Beta that I've looked at most carefully offers ratios of 1.45:1, 2.0:1 and 2.6 to 1 with the standard box.
    Don't forget you'll want to cruse at an engine speed of 2,200 - 2,400 for best fuel consumption and peak torque.
    By the way, I like the thought of exploring the combine drive system idea. I might look into that.
    Default How About this for Some Weight Reduction?
    I agree that light weight is a very desirable goal. It makes the boat easier to "push", uses less fuel, requires less HP. easier to pull on a trailer.... Oh, and a light boat requires less material to build.
    One of the really outstanding things about Robb White's boat is the amazing overall weight.
    One thing Robb White did to reduce weight was to delete the fore and side decks and the coaming. He used an elegant and strong rail type gunnel in their place.
    Not sure whether it's a good idea to eliminate the fore deck since it may add some strength and stiffness in the standard Atkin design. Maybe some of the experts here could comment.
    By today's standards the boat is certainly over designed. We have a lot better understanding of how to use plywood today. And don't forget that this boat was drawn in 1942 and proposed for military coastal rescue service. That design point probably contributes to some extra weight from over designing for hard service.
    Someone who knows what they are doing could probably take quite a bit of weight out of the plans.
    Default Rescue Minor: Thoughts and Questions
    The RM is a very attractive for fishing the flats in my area.RM has character, ecomony and the diesel is simplicity in running, if not in setting up.
    Questions. Does anyone want to sell a Rescue Minor?
    Would any that have built her want to share the cost to build the boat? Total project time?
    Has anyone built her in 3/8 inch plywood plus fiberglass?
    Are the plans of Mr. White's modified RM available for analysis and use for building?Is there a smaller version made for a fishing platform?
    I'm confused with the machinery set up. The belt drive seems the way to go but has anyone perfected the forward, neutral, reverse shifting?
    Finally, has anyone considered using an electric motor to run her? Too heavy with batteries? Too expensive? Too limited cruising range?
    Comments:It seems to me that the design was put together to work around heavily defended shorelines and to bounce off obstacles, be they man or nature made. The 1 inch, even 1/2 inch, plus fiberglass seems very excessive for running the river flats of sand around here. Because she runs in 6 inches , unless one became careless, one should never run aground. I love the way she looks and the small inboard. The way she runs too.
    Forgive the lengthiness and the number of qwuestions. I'm new at this but would really like to have a simple flats boat with character and performance such as the RM delivers. However, I have a lot to learn about the trades and cost of owning one.
    Jun 2006
    SE Mich
    Mr rvinson,
    I have a light weight, skinny 25' launch with a brushless Etec motor turning a 12x11 prop at 1600 rpm max using a 2:1 toothed belt reduction. Electric drive removes the need for a transmission. Controller provides reverse and neutral = off.
    Electric drive has several advantages but penalties, too, like battery weight and limited range. In my application (8) 6 volt batteries weigh 530 lbs and provide about 6 mph for about 25 miles range. The electric related parts (inc'l batts) cost around $4000.
    Denny Wolfe
    www.wolfEboats.com
    Jun 2005
    Virginia
    Out of curiosity, regarding the discussions here about drives - has anyone here thought about hydraulic drive?
    I saw a cool 9hp honda motor today down at Hamilton Marine. It's meant to run hydraulics for a lobster boat. Might be a cool way to power a small boat.
    Steven
    Jul 2006
    Gray Me.
    Been some limited discussion, I have a lot of hydraulic control experience but have not looked at drive issues. 22hp continuous duty doesn't seen hard but the expense would seem to out weigh the cost of a conventional tranny. I am open to suggestions /ideas though.
    This should really be a new thread, but I think about it quite a bit…
    There is a loss of efficiency associated with Hydraulic drives, but in some applications that may make up for the inconvenience of other systems. I am working on a prototype detachable outboard drive that uses a 4 or 5hp air-cooled Honda (cheap, reliable, quiet!) stationary engine mounted in a cockpit locker and a hydraulic motor to drive a propeller. My application does not want the drag of a permanent shaft/propeller and power assist is not used frequently enough to justify the required space/weight and systems of a conventional inboard. I just row instead.
    Because this project is for a canoe stern the mounting of a conventional outboard is hateful and problematic (mounted to the port side it is frequently swamped by wakes of larger passing vessels and impossible to sail on the starboard tack without dunking the engine) I’m often thinking about it. Most of the components are in place and just a few details left to finish; unfortunately my day job doesn’t leave much time for prototype toys!
    The 9hp Honda I saw today was $1500. I think the smallest diesel available is $4-5,000.
    Steven
    Jul 2006
    Gray Me.
    I flipped the issue of small marine drives at a hydraulic forum. I will report back to what I find out.
    Jul 2006
    Gray Me.
    Steven
    I scooped my 22hp yanmar for $2495 on e-bay, Found the timing covers to swap in a seawater pump for a couple of hundred two days later. I was going to belt drive the seawater pump but for that short money its cheaper to go with stock parts. I am debating if I am going to wrap the exaust manifold with ss tubing for exhaust cooling or go crazy and fab up a water jacketed manifold. Been looking for a stock manifold to fit it but they are very expensive for not a whole lot, if you know what I mean.
    Jun 2005
    Virginia
    Tylerdurden notes:
    There is a loss of efficiency associated with Hydraulic drives...
    I'm no expert about hydraulics, but my understanding is that most of the loss is in the traditional swash plate, and that there is/was some improved gizmo from Molitech which reduces that.
    Canoeyawl - maybe your hydraulic folks know something about this also?
    (... sorry for the thread drift....)
    May 2006
    Spokane, Wa
    Good news; I know exactly where a half finished, plywood RM is. Jig is built, faired, and ready for sheeting.
    Bad news: He isnt answering his email.
    E
    Mar 2006
    Lower Kennebec
    Nobody has ever built Atkins' Rescue Minor. Robb White confused things quite a bit, by building an Atkins-style Tunnel-Stern Skiff of his own design, and naming it Rescue Minor. There have been rumors of RM's, but I have been asking, and for a few years asserting that there are none existing, and nobody has stepped forward to claim otherwise.
    There are several now in progress. (mine included)
    There has been some discussion of Atkins Tunnel-stern on this board (search the archives) and considerably more on the AtkinBoats Yahoo group.
    See above. When I finish mine, I plan to review costs, production methods, performance, and market conditions, to determine if it would make sense to build more. Right now, my best guess is in aluminum, workboat finish, Kubota Diesel, it would cost maybe $20,000. Yacht finish, or wood/epoxy, maybe double that?
    We'll see...
    Building the keel much lighter than the 1" design would require additional framing. And the shallow draft just begs to be run in skinny water - what's the point of the boat, if you don't plan to run in waters far too shallow for others? So don't skimp on the keel. The "chine" and tunnel needs a bit of serious thought, or engineering, or trial and error.... Gunwales could be pretty light.
    There are no plans.
    No. Robb mused about such a thing, maybe 3/4 scale, with a 6 HP... Not clear how this VERY unorthodox design will scale up or down.
    Seems the way to go, but it is very unorthodox. Don't expect any support from the traditional marine power people. Robb perfected it, for Robb.
    Funny you should ask... Last week on the AtkinBoats group (or was it Duckworks - after a while it's hard to keep the different fora straight) there was a discussion of just this. I believe the tunnel stern is a BAD design for low speed/low power/electric. A design with a small tunnel might work, but you should have no problem finding shallow-draft boats that will be fine with low power.
    As to hydraulics, my understanding is that it is better suited for high-torque, low-speed applications. I thought about it for RM, but rejected it. (If anybody has any firm ideas how it could work - to turn a 2400+ rpm shaft, let me know ASAP!)
    Default Robert Vinson
    Mr. Denny Wolfe,
    Thank you for your answer concerning electric drive. I looked at Elco Electric and their motors only go to 8hp and the cost and weight are both pretty high.
    I wonder if anyone else would be kind enough to reply to some of my questions and comments.
    Kind Regards,
    Bob in East Florida
    Jun 2006
    Here are my thoughts on the subject of Rescue Minor and in general on tunnel drives in general. I still think Robb did it just "because" in my opinion but did it with a fair amount of experience in messing with boats. A tunnel drive with any inboard was and still is used for a boat when its primary use is shallow draft being the main use with a small craft. The net amount that you gain by using a tunnel is so little for the occasional boat these days makes it just not worth the trouble in more than one case these days when building a small hull out of anything that resembles wood.
    Incorporating into a build hydraulics or even slip drive gear boxes was fine in the commercial industry. But for a pleasure craft the builder needs to spend more time and in some cases money and hassle for what it actually nets out in your favor. Another huge issue is down the road for any resale of the hull. A tunnel drive system is completely different than the tucked stern which was also incorporated in work boats and inboard engines with a shaft drive. In my opinion this is still the better of two evils if you are looking to minimize your draft with an inboard power system.
    If you have never built a tunnel boat, you can build in a nightmare for handling if the tunnel is improperly designed and built into your hull. This renders your boat a bastard in almost all cases when in use.
    Nothing is above doing and much easier to do it wrong than doing it right the first time around, given all the iffys I read in this thread, or so thinks me. Its a great mental excersize and cheaper with less reprocusions for the first timer. Ever wonder why many keep seeking out other folks for another year.............. FWIW, I do like pioneers though, and support these missions.
    The boat is rock solid, but needs work.
    Sal's Dad,
    Thank you for the answers. They are pretty frighteneing for me. I haven't built a boat since I was 14 in 1964. Also, I still work 40 a week and have limited budget for a boat.
    It's just that the RM is so darn attractive and that photo of Rob running in such skinny water standing up with that hat and all reminds me of days gone by when life was easier and it just grabs me. It might be that since I am recovering from last weeks back surgery I am on meds and maybe am not thinking straight.
    I use a kayak to get into shallow water now and the thought of a boat with shallow draft that one can move around in is a delight. The charm and beauty of wooden boats is almost hypnotic and I think I am hooked from looking at Dad's Wooden Boats magazine.
    Is there a simple shallow draft boat that would suit me better? I wouldn't buy or build it if it did not look nice. I really didn't want to go with an outboard and would prefer to have the prop protected by a tunnel design. However the tunnel seems very difficult to build in wood. How does one bend the wood at that tight of circumference? .
    I am going to join the Yahoo group and see the discussion of the RM there. Thanks you for that knowledge.
    Regards,
    Bob in Florida
    Last edited by rvinson@cfl.rr.com; 02-21-2007 at 08:11 AM. Reason: Correct grammar concerning paragraphs.
    Jun 2006
    Well with today's modern materials all you need is some modern materials, a form, some experience with working with some structual glass and you can build a tunnel and incorporate it into a plywood build for any hull. I know this is a bit taboo for this boat construction, but not out of the question. As far as the Yahoo group, I attempted about a year ago to swap banter and did not have much response in gaining much in the way of feedback. As of today, most of what I have read has been the swapping of ideas and chatter about people amazed at the shallow draft of the boat.
    There are many other plans that deal with flats boats and the nature of their drafts for your expected needs I am assuming for redfish gunkholing if you want to go that way in the beginning. These plans can give you some knowledge and some added learning before you wing it on your own, in my opinionated opinion here.
    This is a firend's hull that incorporated an air cooled engine and adapted a hurst gearbox to it after building an adapter plate.
    If you look really close, you will see daylight through the glass. This is easy to accomplish even using thin layups of veneers of plywood over a dummy mould of wood laying flat on a table.
    Duncan, Vancouver Island
    Three mil occoume plywood is remarkably bendy. I don't see anything in the lines of RM or in these photos that it couldn't handle with a little coaxing, a couple layers laminated with epoxy.
  36. #36
    Jun 2006
    This one has an old cast iron 10 HP Briggs and Stratton. I put on a Bedford in and out box which disengages the drive shaft. There is no reverse
    This is listed on the gear that is on the link of the boat for sale in Vancover.
  37. #37
    Southampton Ont. Canada
    If you want shallow,but no tunnel,look here;
    http://www.disappearingpropellerboat.com/history.html
    R
    "Now Ron,don't you do anything stupid!" - Grandma B.
  38. #38
    Default Rescue Minor Nears Completion
    [quote=Sal's Dad;1507574]Nobody has ever built Atkins' Rescue Minor. Robb White confused things quite a bit, by building an Atkins-style Tunnel-Stern Skiff of his own design, and naming it Rescue Minor. There have been rumors of RM's, but I have been asking, and for a few years asserting that there are none existing, and nobody has stepped forward to claim otherwise.
    My Rescue Minor is in the final stages of construction. Final painting, final assembly of the drive train and sea trials are all that remain.
    I expect to be on the water within three weeks.
  39. #39
    Jul 2006
    Gray Me.
    [quote=windmill4048;1507866]
    Quote Originally Posted by Sal's Dad View Post
    You know we have questions?
  40. #40
    Jul 2006
    Gray Me.
    Quote Originally Posted by erster View Post
    A+ Its really nice to agree with you.
  41. #41
    Mar 2006
    Lower Kennebec
    RM's "chine" panels don't seem to be "developable". Close, but not quite.
    Sal's Dad
  42. #42
    Mar 2006
    Lower Kennebec
    Quote Originally Posted by windmill4048 View Post
    In our neighborhood "on the water" might be possible now. "IN the water", on the other hand, can be a bit tougher for the next couple weeks...
    My RM is at the welder's, full of snow...
    Sal's Dad
  43. #43
    May 2006
    Spokane, Wa
    Holy hell, that thing is STILL at the welders? Its been MONTHS!
    E
  44. #44
    Jul 2006
    Gray Me.
    I have been at this for over a year now and haven't started yet.
    Kinda glad I took my time though I still have issues to sort out.
    Been stuck on the kitchen rudder and the biggest question was flexing under load as the clearances are close to a 1/4" around the prop.
    I had some 14# stainless rolled and we found that the deflection was to great so 11# seems the ticket. The rudder itself is actuated by a bimba cylinder driven by a steering pump so that wipes out the issues of the drive gears loading and the outrageous costs associated with having custom gears cut. Once the rudder has been assembled and tested we will go to town on the hull. The main reason for that is I don't have the space to tackle both the rudder and hull at the same time, also it was to damn cold to do any layups.
    We are going to stick with Rob's original Idea and use a L type automotive belt for the drive and reduction. It will be direct and unable to unload and I am hoping that it will start readily with the rudder in a neutral position. If not its an easy mod to unload the belt for starting. Thats the status so far, I am curious to how others are doing with their designs in the water. If it turns out there are unforeseen problems I can do changes or abandon it altogether.
    Its been fun so far as I decided to challenge myself with the rudder idea and I can adapt it to other designs in the future.
  45. #45
    I would question the choice if a diesel engine . A gas engine will be far lighter and far less costly to maintain.An Onan twin cylinder with 18 to 24hp is light , smooth and very reliable.Usually under $1000 NEW.
    For a boat that might not see over 200 hours a year , the ability to merely shut off the engine , spray some fogging fluid down the cylinders , and remove the fuel , to burn in your car seems easy.
    A diesel will usually have a long "out of service over 30 days"procedure that is time consuming and not inexpensive.
    With no cooling water required , sand bar bashing , becomes lots easier.
    F Fred
  46. #46
    May 2006
    Spokane, Wa
    Unfortunately fred, the design requires a diesel for another reason. The weight of that motor prevents cavitation in the tunnel, along with providing an extremely long service life as it will be a low rpm utilization.
    E
  47. #47
    "The weight of that motor prevents cavitation in the tunnel, along with providing an extremely long service life as it will be a low rpm utilization."
    As I understood the box keel the tiny hull would reach hull speed very early , and the stern wave that usually causes a displacement boat to squat at hull speed provides the water for the prop to work with.
    The acceleration of the prop water helps lift the vessels stern , leaving a clean efficient wake.
    All the props in the Atkins Sea Bright boats seem to only be half submerged at rest .
    Load % and mean piston ft per second determines an engines life, not weather its gas or diesel.
    LOVED the Blogg , what a great amount of effort!
    PLEASE , when the boat is complete post a GPS /RPM comparison of the boats performance empty and with a dozen folks aboard. A weight/performance comparison would be very usefull, IF you can get an accurate weight from the ladies!
    FF
  48. #48
    May 2006
    Spokane, Wa
    Fred, the tunnel can aerate with the shape of the hull when at light load if she doesnt sit on her lines. Atkin penned her for a specific weight, which if it isnt there will allow air into a small cavity formed on the forward side of the tunnel. I have a set of the plans, and as the bilge panels make their turn into a concavity, there are two small areas where air can enter. When at her lines, they are below the waterline. Yes, the prop is exactly half submerged (almost dead nuts on the shaft as drawn) but the propwash fills the cavity on spinning the prop. The static tunnel doesn't have a cav problem, its the inflow if shes light or heeled over.
    E
  49. #49
    Mar 2006
    Lower Kennebec
    Default At Maine Boatbuilders Show
    I'm going to the Boatbuilders' Show in Portland this weekend, and will probably have Rescue Minor (aluminum) tagging along, if I can find parking.
    Give me a call if interested in taking a look.
    Curtis
    207 650 323Five (mobile number)
  50. #50
    Jul 2006
    Gray Me.
    I will keep an eye out for ya, I am picking up the rolled stainless for the rudder today.Just a little machine work left on it.
    Soon as its done I am going to start lofting.
Similar Threads
  1. Repost "Plywood" (NIA)
    By Ross M in forum Building / Repair
    Last Post: 08-11-2006, 03:22 PM
  2. Repost: Answer Me This, A Goo Question?
    Last Post: 04-16-2006, 09:47 PM
  3. Alternative to Epoxy
    By Dave Carnell in forum Building / Repair
    Last Post: 10-24-2001, 10:17 PM
