Results 1 to 8 of 8
Thread: Chris Craft Sea Skiff info.
    Rock Hall, MD
    Default Chris Craft Sea Skiff info.
    I'm looking for the specs. (beam, displacement, etc.) for a 1962 Chris Craft 23 ft. Sea Skiff with a 283 inboard in it. Mostly importantly I need the displacement. Need to know so I can figure out what to lift it with.
    Bangor, ME
    You've looked on the web? There is a Sea Skiff owners group out there.
    Do you mean lift it in a lift, or on a trailer?
    Interesting boat. Too much engine, but that was the way of the time.
    Good luck.
    So many questions, so little time.
    Rock Hall, MD
    I looked on the owner's assoc. web site but they don't give specs. on the boats. By lifting it I meant, I need to pick it up and possibly turn it over to repair the bottom, plus put it on a trailer. I have the hoists in our shop that I used to turn over a Chris 22ft Sportsman. I just want to make certain it can handle the Sea Skiff. I have not yet bought the boat so I don't want to spend the money yet to order the specs./hull card from the Mariners Museum in VA.
    Jun 1999
    Minneapolis
    In addition to the Chris-Craft Sea Skiff specific group, there is a discussion forum for Chris-Craft in general: http://www.chris-craft.org/discussion/index.php
    Post your question there.
    Andreas
    Jul 2003
    Norfolk, MA
    I have a '56 26 footer, it weighed 3300 lb. shipped from the factory with the 130 hp. engine. Figure ~400 lb. less for yours.
    Feb 2005
    Alabama
    Dale,
    Here you go:
    1962 23" Sea Skiff Sportsman:
    HIN# Series: SUE-23-001 to SUE-23-180
    Beam: 8' 4"
    Draft: 24"
    Height: 7' 5"
    Weight: 3162-3222 lbs.
    If that HIN series doesn't match your boat, let me know and I'll re-look. However, all of the 1962 23' Skiffs were within 150# of the above weight.
    Hope this helps,
    Ethan
    Indianapolis, Indiana, USA
    Default Visit www.mariner.org
    and go to the Chris-Craft Collection. They'll have complete specs. and shop drawings for your boat. Here's a direct link---
    http://www.mariner.org/library/chriscraft/index.php
    Jerry Conrad is the curator, and may be reached at (800)565-6846 (last I called). His assistant is Katie. Both are helpful.
    Good luck.
    Best,
    Alan
    Default Re: Chris Craft Sea Skiff info.
    If it's the Ranger, it's 8'4" x 3422#
    Quote Originally Posted by Dale Genther View Post
Similar Threads
  1. Chris Craft Chrome logos
    By GC in forum Building / Repair
    Last Post: 03-14-2006, 10:26 AM
  2. Identifying Chris Craft Propeller
    By Dale Genther in forum Building / Repair
    Last Post: 12-19-2005, 12:10 PM
  3. Old Chris Craft Propeller
    Last Post: 04-26-2005, 08:05 PM
  4. Chris Craft - 5200 or Bulletproof Bottom
    Last Post: 09-02-2003, 01:08 PM
  5. Chris Craft Sea Skiff Hull Problems
    By ScottyO in forum Building / Repair
    Last Post: 05-26-2002, 09:08 AM
