Results 1 to 9 of 9
Thread: bandsaw blade speed
    rockland, Maine USA
    Post
    Hi folks,
    I just got my hands on a really nice old 36" bandsaw, and am in the process of setting it up. I'm having trouble finding info on what blade speed I should aim for. I'll be cutting mostly hardwoods in the 1 to 6 inch range. Any advice would be appreciated.
    Feb 2004
    Wickford, R.I.
    Post
    Check out old wood working machines.com
    Sep 2004
    Ohio
    Post
    My old 20" Powermatic runs a 4500 SFM, if that helps any.
    Sep 2001
    USA
    Post
    Blade speed 2000/4000 FPM
    Read the Specs...
    http://www.redmond-machinery.com/powermatic_2013.htm
    Slower blade speed for harder material will make them last longer..
    Nov 1999
    Broken Arrow, OK US
    Post
    3000-3200 ft/min (depending on what pullies are available) seems like a nice range for me.
    Sep 2004
    Ohio
    Post
    My Powermatic is a model 81 made in Tennessee and weighs almost 1000 lbs., not the lighter Jet/Powermatic Chiwainese saw Gary found specs. for. It runs at 2000 or 4500 SFM. 2000 works great for thick bronze and 4500 will cut 1/16th" venieer 12" wide with 5hp.
    [ 09-10-2005, 11:29 AM: Message edited by: kc8pql ]
    Dec 1999
    Oriental, NC USA
    Post
    Things to consider.
    1. Larger diameter wheel saws can and should be run faster. Less flexing means that the blade can be run faster.
    2. Thick stock needs either or both faster cutting speed and greater tooth spacing. This allows the blade to run cooler and truer when the gullets don't fill with sawdust.
    3. For your 1 to 6 inch stock I'd use a 2 or 3 tooth/inch blade and at least 3500 SFPM speed, preferably 4000 SFPM. Some industrial blades run at up to 5000 SFPM.
    4. Go to the Suffolk Machinery website and read their rules of bandsawing.
    http://www.suffolkmachinery.com/six_rules.asp
    [ 09-10-2005, 02:57 PM: Message edited by: Tom Lathrop ]
    Nov 1999
    Broken Arrow, OK US
    Post
    Blade speed does not depend on the thickness or type of wood as much as it depends on ...
    blade material - High carbon, HSS, carbide
    machine bearings - babbit, oil lub, sealed ball, sealed roller
    rockland, Maine USA
    Post
    hi folks,
    thanks for all the advice. some of the links were very helpful. Much appreciated.
