Results 1 to 22 of 22
Thread: 4 cylinder Front Wheel Drive in 1907
    Jul 2008
    Tacoma, WA
    Default 4 cylinder Front Wheel Drive in 1907
    Mar 2006
    Outlying
    Default Re: 4 cylinder Front Wheel Drive in 1907
    Barney Oldfield.
    Oct 2003
    beer city usa
    miller's front wheel drive inline four and straight eight and v eight racecars were decidedly more elegant
    Quote Originally Posted by Jim Bow View Post
    I wonder how the steering was………….
    Isle of Mull, Scotland
    With 19.6 litres, single speed (in one version), and no diff or CV joints, probably...interesting...
    As there was a clutch at either end of the crank, I suppose slipping the clutch would be a big help in cornering.
    Jan 2022
    Travelers Rest SC USA
    Next, you're gonna try telling us that there were electric cars before Tesla....
    Quote Originally Posted by MushCreek View Post
    And holding the land speed record for cars at 62 mph, in 1899...
    Quote Originally Posted by birlinn View Post
    No suspension either, but I can see king pins, so there will have been some flexibility in the half shafts, within the hubs.
    I believe there was a bit of sliding pillar front suspension- can't have been much with very short drive shafts.
    Just so, apparently Christie did manage it
    On each end of the crankshaft was a manganese bronze flywheel. The outer diameter of the flywheel was lined with woven camel hair to provide a friction surface. Covering the flywheel was a chrome steel cone clutch. Shafts and universal joints connected the drive wheels to the clutches and allowed for steering and independent coil spring suspension. Normal gear would lock the flywheel, clutch, and shaft together so that there was no reduction between the engine and drive wheels; for every revolution of the engine, the drive wheels turned one revolution. Normal engine speed was 1,000 to 1,200 rpm. With its 34 in (864 mm) by 4.5 in (114 mm) front tires, the car was capable of 120 mph (193 km/h) at 1,200 rpm. Of course, different size tires could be used to alter the vehicle’s acceleration and top speed. The rear tires were 34 in (864 mm) by 4 in (102 mm).
    https://oldmachinepress.com/2014/12/...ne-1907-racer/
    Not that long ago I was reading about the electric Lohner that Ferdinand Porsche bore some responsibility for.It had a hub mounted motor at each corner and since Rzeppa joints were some way ahead,he had to come up with a way to transmit motion along a beam axle.The rather elegant solution was to extend the kingpin and mount pinions,both above and below the axle,with a crownwheel connected to the wheel.
    Mar 2003
    Toronto Canada
    I know nothin’ about cars but I’ve got a good name.
    Miller straight eight
    1921: 32 valves, dohc, 183 cu. in., 135 hp (reduced to 122 cu in. in 1923, 2 liters)
    edit to add: http://milleroffy.com/Racing%20History.htm
    Jan 2001
    St. Simon\'s Island, GA, USA
    My mother claimed that she learned to drive on a Franklin automobile about 1915. It was was air cooled with a a cross mounted, four cylinder engine and front drive.
    Quote Originally Posted by ahp View Post
    How old are you?
    Jul 2015
    St. Paul, MN
    1924, 640cc, 5 cylinder German front wheel drive motorcycle, the Megola.
    Ever since I was kid I've had I've loved the Citroen Traction Avant. In 1934 it pretty much nailed the modern car. Front wheel drive, unibody, 4 cylinder and rack in pinion steering.
    Is that Rube Goldberg behind the wheel???
    How old are you?
    Edit; My father (b 1925) spoke fondly of Franklins.
    I have never seen one on the road! Only in museums/collections
    She was right about the air cooling.
    1901 front drive Singer.
    It could be yours (no connection, etc.):
    https://newyork.craigslist.org/fct/c...591199863.html
    There's a Franklin Museum in Tucson...
    note wooden frame rails/chain drive?
