Some years back I got a screaming good deal on a Dickinson Newport Solid Fuel Heater. Someone had bought it for their boat, never quite got around to installing it, and then finally decided that the project was never going to be realized, so put it up on Craigslist, which is were I snatched up for about half of what they were going for at a marine supply store at that time. Since then it's mostly been an ornament in the living room of my house, not unlike under its previous owner, but that sort of worked out well because I have since acquired a bigger boat (36' as opposed to 25'), which I think will be a more appropriate fit for this little fireplace. I have finally decided that this year is the year. I am going to install the stove.
What I would like to ask the collective brain-trust here on the forum is this: how important is a flue damper to the operation of this little wood stove?
In most of the pictures I've seen of them installed on boats no flue damper is used, but Dickinson offers one as a separate accessory. How vital is it that I incorporate a flue damper into my installation? I guess it's not really the end of the world because I can always add it on later with only a simple modification to the flue pipe. However, if it really is essential to have, then I might as well just buy it when I'm ordering everything else from them (like the flue pipe, deck fitting, charlie noble, etc...).
Follow-up question: what about the barometric damper that Dickinson also offers as an accessory? Does that necessarily help any more or less than the regular flue damper? Would it be an important addition to my wood-stove set up?
Thanks for your input!
