Re: Fuel efficiency
It might surprise some that V-hulled planing boats make pretty good displacement boats.
Example, my 5000 pound 23 foot deep V with a single 250-hp V-8 outboard sips fuel at 5 knots. That's idling at 650 rpm. At that boat and engine speed, it burns 1.2 gph. or about 3.5 mpg.
You are talking about a much smaller outboard. You wont be burning much, if you operate in displacement mode.
Of course, what are your goals? Absolute best efficiency? How far apart are fuel stops? Most of the great loop isn't all that remote.
Is it financial? If we took my larger, heavier bigger powered boat we could, for example make 40-50 miles per eight-hour day for 8-9 gallons, or about $25 dollars a day in fuel. The smaller engine you'd use would burn and cost much less per day in fuel.
Diesel? Sure, you go further on a gallon, but it costs more. And the engine costs more to buy up front. Again, what are your goals? Do you need the range it affords? Will it enhance the vessel's resale? Etc.
Just food for your thoughts
