Results 1 to 10 of 10
Thread: Dinghy needs a mast. Need help to ID design or type of mast to build.
    Nov 2022
    Bellingham, WA, USA
    Default Dinghy needs a mast. Need help to ID design or type of mast to build.
    This dinghy is 9 feet from bow to stern and 5 feet wide. I am hoping to build a mast but not sure the height and design.
    Thanks for any help,
    Teresa
    Default Re: Dinghy needs a mast. Need help to ID design or type of mast to build.
    I might try looking at, then for, an El Toro rig.
    An El Toro is an 8 foot pram, but the rig is a bit sporty. Bermudian catboat .
    Unless you seek a particular type of other rig.
    Oct 2017
    Berkeley, CA
    El toro rig is a good idea. Leave some play fore and aft and make little T shaped shims out of 1/4” ply so you can adjust the rake to work for the hull.
    Nov 2022
    Bellingham, WA, USA
    Thank you, I will look into that rig.
    Nov 2001
    Seattle
    El Toro rig would be small for a boat 5 feet wide.
    I don't recognize the design. It looks to me like a common type from the mid 20th century, build at home plywood boats. Glen-L was a big seller of such plans, they also appeared in Popular Mechanics and the plywood association published plans too. Good luck with it, it looks fun.
    yes i think you may be right John, this is a real two to one catboat.
    per'aps a real gaff like a beetle would be in order ?
    Aug 2017
    Kennebunkport, ME USA
    Looks like a Turnabout to me. Should be easy finding the rig specs as it's still sailed at least along the US northeast coast.
    Oct 2000
    Padanaram, MA USA
    Looks like a Turnabout to me, too.
    You might get plans/specs for the rig from the builder.
    https://n10association.com/?page_id=23
    Nov 2001
    Seattle
    Turnabout carries 61 sq.ft. of sail.
    https://sailboatdata.com/sailboat/national-10-turnabout
    About half again as much as an El Toro.
