Results 1 to 33 of 33
Thread: Power planes
    seattle
    Default Power planes
    The previous WBF threads on these are pretty old. I’ve never had a power plane. I have a prewar Craftsman 6” jointer, kind of cute, but frankly it scares the hell outta me and with its motor and stand it takes up too much precious floor space in my tiny shop. My use would be occasionally straightening a crooked board prior to table saw or thickness planer use. Maybe I would find other uses I didn’t know I needed. So, should I ask for a power plane for Christmas? Would it replace my scary little jointer?
    If so, which one? Probably corded, as I doubt I would use it away from the shop, and if cordless it would probably limit me to DeWalt for existing batteries. Plus it will need a vac hose attached anyway. If corded, Makita? Bosch? Other? Doubtful I would need Festool unless someone convinced me it’s really worth the $ for my little amateur shop. What’s your favorite?
    Nov 2006
    Default Re: Power planes
    You can't beat the little Makita planer. I have that one and the Festool and the Makita gets used most of the time. The Festool is saved for when company comes over. The advantage is that the Makita is shorter and handier. The Festool is longer, which makes it more accurate on long, straight edges, but the Makita easier to use one-handed for stock removal and such.
    Go corded on this one, Ron.
    Jim
    I have a Bosch. I don't recall the exact model and can't look right now. It's a 4" wide, and not too big. It works well and one thing I fully appreciate is that I can dial down the depth of cut to zilch and easily via the combo handling/adjusting knob on the front. One can even adjust the depth of cut "on the fly." These things can remove a lot of wood in a hurry and that scares me more than the likelihood of getting cut by the thing. I consider it to be a hogging tool so I use it to remove the vast majority of wood, then switch to one of my hand planes to finish up. I don't use it often.
    I'm glad I have the tool but it is not a jointer. The tool isn't long enough to effectively joint any board longer than 10 inches. And that, for me, would take practice.
    Your scary jointer might best be replaced by a good track saw. I have the Festool track saw and have to say that it has largely replaced my need for my jointer (I have a 12") in most cases. With very little effort one can easily use a track saw to straighten the edge of just about any board. They are not just for cutting sheets of plywood.
    Aquitaine
    Like jpatrick, I just use mine for rough removal, before a hand plane. After years with a B&D model, very good. I just use cheepo ones from the big box store. But I do have a planer thicknesser that handles the long bits.
    Currently building a 27ft laminated mast. Removing lots of wood quickly with the power planer to get the tapers, but finish with a Record No 5 hand plane.
    Sep 2002
    A little while back I had a 900 kg lead keel casting to smooth off, and shape the leading edge. We'd used a wooden mould and it had shrunk and cracked with the heat so there was a bit of fettling to do so I bought a really cheap power plane from our equivalent to Harbour Fright and used that. I also had a nice Bosch 3in power plane, I've still got the cheap one and its still working fine even after much abuse, the Bosch failed, even though it never was used on that lead casting.
    My main go to power plane is an 18v cordless Makita, they dont come much better than that.
    John Welsford
    Feb 2010
    Albuquerque, NM
    My corded Bosch PL1682 got me through building my boat and is still ticking along just fine. Finast Kind.
    Gerard>
    Albuquerque, NM
    seattle
    I notice the Makita and a couple others, don’t have a vac hose attachment, whereas the Bosch does. I know it removes a lot of material but so does my thickness planer and my shop vac and small cyclone keep up with it just fine. I understand outside that would be okay. But in my shop I think I’d like to catch the chips and dust. Unreasonable expectation?
    Aug 2022
    Minnesota
    Also having good results with a lower end Harbor Freight planer. Lighter than the metal bodied ones and can either eject chips to the left or right (select with a lever) and can take a hose with a little finagling. These hoses work nice: https://foamez.com/product/slinky-hose/
    Dec 2009
    Vancouver Island
    My favorite is the Makita 1900b. It is the ergonomics of one-handed operation that make it rate above the others, imho. While I have 'borrowed" other makes if they are handy and doing so will save me steps, and have the time on tools to make a value judgement, I have seen no reason to change what has worked best for me for the past 40 years. If you are new to this tool I think it would benefit you to handle some of the top brands to get a feel of what is right for you. / Jim
    My Bosch will eject either left or right as I choose. My Festool hose attachment fits flawlessly. I would always choose to have efficient dust extraction.
    BTW: I have also shaped a lead keel with my Bosch. It worked very well with no apparent damage to the planer. I did not use my vac to suck up those chips!
    May 2007
    Seattle
    I have a Porter Cable that I bought when shaping some oars. I am not sure why I didn't buy a power plane years ago. It will eject to either side
    What's not on a boat costs nothing, weighs nothing, and can't break
    Aug 2016
    Queens, NY
    Lou makes a convincing argument for the cheap Ryobi in this video..
    great tips for tuning it up too
    May 2006
    Dog Ranch, USA
    My Makita power planer has no dust collection or at least I've never tried to hook any sort of collector to the exhaust port. It's a screamer and makes a huge mess. Sure is effective though.
    Yeadon is right, of course.
    Southampton Ont. Canada
    We have a couple of Makitas. One is light grey,so from the early eighties.
    They don't get much use,but are handy when nothing else will do.
    They make heavy flakes more than fine dust,so pretty easy clean up.
    R
    Sleep with one eye open.
    Mukilteo, WA
    The Makita is a workhorse, mine got used hard building the timber frame from rough sawn beams. It's bad enough dragging a cord around, I wouldn't want to also have a hose involved in every stroke.
    Of course I've never owned a dust collector and usually work outside. And I love shuffling through snow drifts of shavings.
    Sep 2015
    Mountains of Ocooch
    Probably a good thing that!
    I borrowed a power hand plane back some 50 years ago when I was building the second mast for my Pumpkinseed stripper scow. Contemplating the tapering necessary after the blank had been glued up with a conventional hand plane, made such a choice an obvious one.
    Some years later I acquired a nice INCA 10" jointer/planer that I have to this day. It's served me Very Well Indeed in the interim.
    About two years ago I 'upgraded' its two straight-bladed knife head with a Shelix style fitted with numerous, four-sided carbide cutters (for over the original cost of the tool itself mid-'70's but that's inflation at work, not relative value) and have never felt so good about spending such a bunch of $$$ on a single tool.
    Power planes, whether bench- or hand-style, have their place. I get great pleasure out of using my traditional hand planes for lighter work, the finishing touches if you will.
    Even the wood-bodied, curved blade scrub plane.
    Even if I spend more time getting the keen edges I know will work best than I do actually using the planes as they were intended to be used.
    I've been quite happy with the $99 Bosch I got many years back. I think it's still around $99.
    seattle
    Quote Originally Posted by sp_clark View Post
    I have Shelix cutters in my DeWalt thickness planer. If anyone here is not familiar with helix style cutter heads, do yourself a favor. Yes, they are very expensive, but given the four sides and single cutter replacement if chipped, they probably save money in the long run. But even if they didn't, the quality of the cut is worth it alone.
    Quote Originally Posted by coelcanth View Post
    HA! You beat me to it. I bought one and set it up, pretty much as Lou says and it works great for stock removal. It's not a finish tool, but does nice roughing and it was cheap​!
    Jun 2007
    I've got a corded Makita (can't remember the model #) and it is a very precise tool. But no matter how much I plan, that #$% cord somehow gets in the way. It's also not great on chip collection.
    That said, I can't see a handheld planer as a good substitute for a well tuned jointer. I consider it one of the four woodshop essentials (the other three are planer. table saw and band saw) It's always a pleasure to start a project with wood that's square, flat and parallel.
    Aug 2022
    Minnesota
    I modified an older Ryobi planer with an irregular-shaped exhaust port with a plate with a round hole to accept a hose to a small shop vac. I run the vac with a Dust Deputy cyclone.
    On the old Skil 100 metal bodies planers, beloved in traditional surfboard shaping bays, people make various vac attachments too, often running power and vacuum lines overhead. There is also a guy making a fiberglass 'turbo chute' for the 100 which mixes the motor exhaust air with the shavings and sends them out faster/further. The surfboard shapers often modify the planer depth controls to work without detents or 'on the fly' but this would be for foam only.
    i never had one i dint like
    but my next will be cordless
    Barrie, Ontario, Canada
    They're a great tool when you have rough-cut or slabbed boards, and need to remove a lot of material in a hurry to true up an edge or surface.
    But they make a LOT of shavings in a hurry. I use my el-cheapo one outside. It doesn't have a good vacuum hose port.
    I'd get a cordless one next time. It's a tool that gets its work done fast.
    Nov 2010
    Chesapeake Bay
    I bought a Ryobi and gave it the Lou treatment and it works well, although to be honest I've only had to use it a handful of times.
    Sep 2015
    Mountains of Ocooch
    Quote Originally Posted by Spot View Post
    Another solid recommendation!
    I think I learned of the DD vac accessory here a few years back, bought one for my big Rigid. Saved maybe five, six times its cost for vac filters in the mean time!
    Then I 'upgraded' an early '80's bag-filtered dust collector with one of their larger cyclonic separators and HEPA style filter & collection drum, made a quantum leap in efficiency of dust & chip capture from my jointer/planer & table saw. Their products're well appreciated by this customer.
    landlocked in Mt. Solon, VA
    Home Depot has a cyclonic separator similar to the Dust Deputy. It has a lower profile and fits next to my radial arm saw below table top height, so it does not interfere with workpieces. Functioning is very effective.
    https://www.homedepot.com/p/Dustoppe...D12A/315749552
    "George Washington as a boy
    was ignorant of the commonest
    accomplishments of youth.
    He could not even lie."
    -- Mark Twain
    Sep 2015
    Mountains of Ocooch
    Quote Originally Posted by UCanoe_2 View Post
    I have one of those also, fitted to one of their branded orange 5-gallon plastic pails. It lives in my garage/shop, connected to a low-profile Rigid (their brand) vacuum cleaner.
    I agree it's effective, yet my experience with both devices tells me the DD is superior when it comes to efficiency. The Rigid vac my HD separator's connected to uses paper bag filters as well as a HEPA pleated type. The bag filters are substantially cheaper than the pleated kind but I still find I have to change the bag filters fairly often as they tend to clog with fines as one would expect.
    With the DD unit in-line with my larger Rigid shop vac, fines don't make it to the vac bin, the HEPA pleated filter it uses stays virtually pristine over quite a long time.
    Make no mistake the HD device is better than simply a vac alone! You'll save a bunch on filters after you put one in-line with a vac.
    Still, IMHO the DD is worth the price if you can fit it into your machine arrangement.
    Having to sit upon the 5-gallon pail for debris collection makes for a tall combo. The HD adds about 5" to the bucket underneath, without considering how the intake elbow affects things.
    I built a carriage to hold the DD and my vac that's on casters so I can roll it around to where it's needed. Before that the DD would invariably fall over from the strain of having the intake tube pulling on the intake for the separator so high off the floor when I chose to move the combo.
    Great Barrington, MA
    re Wisbang's collection--that looks like a first generation Ryobi there, what a tool. I have two. The blades are carbide tipped and hard to sharpen so I sent them out, and now they're pretty much unavailable unless you want to order from Japan. But because they're short and wide they're great for some things other longer ones aren't and they are bullet proof. I have that Makita, too, which is great like any other Makita tool.
    ^ the 1980's makita in the center has a motor twice the amperage of a regular modern planer, but still with regular 3 inch blades
    I shoveled the tar goo used to glue old linoleum to a floor in Ben Sebens home a few years ago to prep for refinishing. It ran through stuff that would STOP the others
    planers are a bit like disc sanders for me, if i'm on a job, i'll have 3 or 4 "in service" at once...sharp/dull, rough/fine/ beater/still nice, nails/ not nails.
    I wait until at least 3 need sharpening to sit down and slow down at the bench to sharpen em. it has been a long time since I even use the guages to install the blades or grind them. all by eye and feel.
    i made a pile of ayc chips yesterday with the green one...a freakin PILE !
    of course, y'all know I'm not building leaky boat joineryimeanfurniture
    oh i have a few more on the boat.
    Bruce
    I have a rule with power planers, stop when you think you need just a couple of passes more………..
    Mine is several years old, and in a tool chest in the shed…..
    Just received a promotional video for this Triton model. Looks interesting. No idea whether it's worth owning. No personal experience with the Triton brand, and I hear mixed reports...
    Apr 2019
    Massachusetts
    I've never had much luck with Triton products. The seem well designed but are cheaply made. Just my opinion, but I wouldn't touch one again unless there were underwhelmingly positive reviews on some type of woodworkers forum.
    Jan 2016
    Auckland New Zealand
