Results 1 to 35 of 54
Thread: Small Field Work/Camp trailer
    Nov 2006
    NorCAL
    Default Small Field Work/Camp trailer
    I kinda like these for the direction I am going. Rugged little camper, solar and gas. Ton of access and locks for security. The top rack platform holds 500lbs.
    Nov 2006
    NorCAL
    Default Re: Small Field Work/Camp trailer
    May 2000
    I like it.
    But I’ve never understood the point of off-road tires on a trailer.
    Nov 2006
    NorCAL
    I understand that the tires should match the vehicle that tows it -
    making them all interchangeable.
    May 2000
    You know… that makes sense.
    Never thought of that.
    Texas
    Tempting. The rooftop tent looks clever but I’d want to try it in real life.
    May 2002
    the hills
    so where does the trail bike go?
    Jul 2008
    Tacoma, WA
    Daughter and SIL just took delivery of one of these. Built in Portland. They love it.
    They have an articulating off-road trailer hitch.
    ITS CHAOS, BE KIND
    Feb 2010
    Quote Originally Posted by Beowolf View Post
    I like it.
    I own a small Hercules brand trailer made in about 1949. It was designed to be pulled behind a jeep and used same rims and tires, so could use the same spare. My father bought it and was disappointed when I found out that it wasn't military surplus. Military trailers of that time didn't have tailgates so they would float when crossing deep water.
    Texas
    I got a 6x12 used wells cargo. Like this bit with a ramp. Insulated, bench bed, little window/hatch in the side, roof vent already installed, tiny tot, some cabinets, sink, air con. Changed the wheels to match the Jeep. Ramp is a nice deck. Though barn doors have some appeal.
    Feels pretty small inside. But cozy for one. Giant compared to a roof top tent. I’m living in it when working at my place. Pretty big and heavy for any real off road.
    Nice to lay around in relative comfort in the wind and driving rain.
    Southern California
    This post is temporary and my disappear at the discretion of the managment
    Texas
    Wow-Ming
    A solar-powered setup. Looks a bit more comfy. Not cheap.
    Southern California
    Wow-Ming
    Just don't miss a step on the ladder when you need to pee at 3AM.
    Oct 2003
    beer city usa
    Feb 2010
    Rivian No Longer Offering Camp Kitchen On R1T
    But it looks like Ted is wanting more gear storage space than most of the suggestions here.
    May 2002
    the hills
    I say we start with a budget going from $5k -$20k -$80k for the whole package.
    Oct 2003
    beer city usa
    ^ since its ted's money we're spending. . .
    Feb 2001
    Seattle, WA USA
    Quote Originally Posted by Joe (SoCal) View Post
    Those roof top tents run c. $6,000, and that Rivian slide-out camp kitchen is a $6,750 option.
    Just get a Camp-Inn 560 Ultra. Weighs about 1,200 pounds. Has a little settee forward of the doors that converts into Pullman berths.
    https://www.tinycamper.com/raindrop560ultra.htm
    Nov 2006
    NorCAL
    Quote Originally Posted by Jimmy W View Post
    The Rivian will have to wait.
    Jimmy is right - it really is about setting up an operational base came with storage. The camping part with fresh water and being able to clean up is a very nice part. The dual purpose of this trailer became evident when I was working out in places filled among fire waste, toxic materials and not being able to get out of the weather - sun and rain. being on top of a box truck sucked big time.
    Usually it is not a problem.
    last field assignment equipment load.
    on the box truck.
    Having this there would have made the weeks more bearable. And I could have operated on top of the trailer which has plenty of power and i could also bring along a generator.
    May 2002
    the hills
    ok
    Ford maverick awd w that trailer but get it repainted. I like the flat desert sand/ivory color. Good mileage as a daily driver , awd, enough hp to drive a light trailer freeway speeds.
    DonnW’s 4wd van?
    I’ll go look at Craigslist
    May 2002
    the hills
    that turned out great
    Texas
    Thanks. I put the tiny tot next to the cabinet. Sitting in it right now. Going to freeze tonight but it’s nice and warm. Looks like a random utility trailer from the outside (except for the Jeep wheels).
    Texas
    Jul 2002
    Western Washington
    Does that Tiny Tot have a 3 inch flue? Did you run the chimney pipe out the side, or out the roof? How did you handle the penetration - insulation, airgap, what? How do you cover / handle the chimney/penetration when you're on the road and moving???
    Texas
    Texas
    Up through roof. 3” pipe. I put an old aluminum tea kettle over it when stationary or raining. And lift the pipe and put a plastic jug under the pipe when traveling to catch any water.
    1” air gap between the corrugated and wall using emt. Edit-conduit
    High-temp silicone boot and collar at top. I forget the required clearances.
    Perhaps it would be convenient if the bolt patterns were the same, but trailer tires are (should be) different for several reasons.
    Sep 2005
    new zealand
    This is our camper bus.
    480W of solar on the roof, with a 240 A/h lead acid battery. If the battery was lithium, I could halve the A/h capacity, and probably be OK with only 300W on the roof - if I was doing it again.....
    Anyway, that keeps up with the lights, stereo, fans and a 130 litre 12v compressor fridge/freezer, on paper there's enough capacity for at least a couple of pitch black days. We run the fridge 24/7 over summer, the house battery system has no AC charger or connection to the vehicle electrical system.
    Heating is a 3kW diesel fired unit that runs on about a 1/4 litre per hour. A 2kW unit would have been plenty big enough in retrospect.
    That all works in the real world, no bs.
    There are lots of options out there, depending on what you really need this trailer to do.
    Pete
    The Ignore feature, lowering blood pressure since 1862. Ahhhhhhh.
    That's a "down doggie"!
    You taught your dog yoga?
    Sep 2005
    new zealand
    Rocket (fast dog, fast name) has learnt how to do very good up dogs too. His sun warrior sucks though.
    Pete
    N/A
    That's part of it. You want the the larger tires for clearance, the knobbyness is just for show on the trailer and I've never heard of someone leaving their $40,000+ trailer and kit behind, they all still carry a spare for the tow vehicle and in some cases the trailer, which brings it back to Teds point.
    In the US this perverted idea of “blood and soil” over “constitutional principles” is the most radical and anti-democratic and anti-Conservative idea I have heard in my lifetime.
    ~C. Ross
    N/A
    They suck for getting out for a piss at 2am. On the top of a vehicle, they raise the center of gravity too much and aerodynamics suck, and the tent tends to snag on trees brush on the trail, which is why most people are moving away from them. They, however, work better in this configuration but then at the prices these trailers and tents go for, you might as well buy a camper designed for off-roading, more aerodynamic for getting to the trailhead and better at being bear resistant and a lighter package all together.
    ~C. Ross
    May 2012
    UK. Cornwall, Suffolk.
    The thing about trailers is they are also anchors. Leaving aside offroad, you can't leave it anywhere while galavanting. Parking is restricted and towns are problematic.
    Why not get a simple van? I lived in this for 5 years while working and doing boat work all the while.
    Eberspacher, strongbox, gas locker, food cupboard, cook stove with cowling and inline fan (petrol boat engine room blower), aluminium frame holding up bed (adjustable level), cold box, water, clothes plus gear, cupboard for smaller stuff that becomes a table. Insulated, blacked out and very discreet; noone knows your in there. I once slept in Kensington, an extremely rich area of London for a week with no problems. I had a small drop down workbench at the back with a vice on it. About the length of a station wagon car too.
    I now have the shorter version T4 which is being done in similar fashion, but with differences. It will have a wood stove that heats a hot shower and no compressed gas in it; switching to Origo. Will have 220 volt too.
    If you want 4 wheels here's the Synchro if you can afford it.
