Results 1 to 35 of 55
Thread: re-using canning lids
    Sep 2003
    Farmington, Oregon
    Default re-using canning lids
    do you do it?
    my mother-in-law would can apricots and tomatoes in nescafe jars. no money for canning jars and lids. i had some the first winter i visited norma's ancestral home, and i didn't die.
    i just inspected and washed a couple dozen used lids. if you open your jars carefully damage to the rim is negligible.
    Oct 2003
    Valley of the Sun
    Default Re: re-using canning lids
    yall drink nescafe?
    Sep 2004
    Arizona
    I assume you MIL was canning using the water bath method. It's not really a good idea. The lids have a seal on them that requires heat to set properly. The seal is not meant for multiple use.
    Pet photography, the degree you get when you fail aromatherapy - Duck D.
    Sep 2003
    Farmington, Oregon
    i use actual canning lids and rings. the rubber seal on the lids works multiple times. i use them twice unless visibly damaged, then discard.
    the story was about my m.i.l. making do with used nescafe jars, not me. family home with a dirt floor, etc.
    Oct 2003
    Valley of the Sun
    Quote Originally Posted by L.W. Baxter View Post
    and you didn't die!
    my mom always reused the mason jar lids with the red rubber seal
    she also used paraffin, no longer recommended
    Feb 2001
    Seattle, WA USA
    The lids can be reused for storage, but not for canning. They're designed to make a one-time seal.
    The rings/bands can be reused many times.
    Once the seal has been made and the jars cooled, the rings can (and should) be removed.
    From the North Dakota State University Ag extension:
    https://www.ag.ndsu.edu/news/newsrel...e-canning-lids
    You would not enjoy Nietzsche, sir. He is fundamentally unsound. ó P.G. Wodehouse (Carry On, Jeeves)
    Sep 2004
    Arizona
    and you didn't die!
    The old style seals were reusable. The lids they make today are not meant for multiple canning cycles.
    Texas
    The definitive source for good info on the topic. They don’t squarely address reusing. Or they do, and it’s acceptable given that it is not prohibited. I only spent a few minutes and may be wrong.
    https://nchfp.uga.edu/publications/p...html#gsc.tab=0
    Still Above the Grass
    Forty cents a pop. Why risk a ruined jar of pickles for forty cents.
    yall drink nescafe?
    Only when I run out of Folgers Coffee Crystals.
    Texas
    My grandad has a cancer thing removed from his nose when he was about 85. He motioned me over like he was going to tell me a secret. They used to drive out into the cotton fields to meet the moonshiners. Said that the spot they removed was where the mason jars would cut their noses as they drove back over the fields drinking.
    Sep 2003
    Farmington, Oregon
    at the end of the day, a vacuum seal is a vacuum seal.
    one must be careful and observant when canning and consuming. new lids can fail, too, eh?
    my failure rate with re-used lids is indistinguishable from my failure rate with new lids. very low.
    Sep 2003
    Farmington, Oregon
    as for manufacturers claiming that canning lids are single use only, well, they would say that, wouldn't they?
    Jul 2006
    Here
    Following
    Choose wisely -Treat kindly...
    A secret to a good marriage is to have a quick mind and a slow mouth...
    S/V ORCA 38' Herreshoff Ketch
    Sep 2003
    Farmington, Oregon
    Quote Originally Posted by Katherine View Post
    did the seals really change? or did the lawyers insist.
    Texas
    Separate from the lid issue, the emphasis they put on botulism is concerning.
    Oct 2003
    Valley of the Sun
    botulism is a bad way to go
    Texas
    Hoping not to live long enough to see airborne botulism, tetanus, or rabies. Though I suspect they are in a lab somewhere.
    Sep 2003
    Farmington, Oregon
    i haven't canned tuna in a couple years, but when i did i always used new. high value product, why not be a little superstitious.
    but i am doing tomatoes today. i have tomatoes out the wazoo. and my cans will all seal fine.
    the only danger is eating something that has spoiled. if you are not careful and observant, i suppose that could happen... with old lids, or new.
    Texas
    Growing up, they reused them all the time. Just ate the ones that didn’t seal. Or redo them.
    Aug 2002
    In the early days of the pandemic I bought a bunch of reusable canning lids and rubber seal rings. Turned out to be a good move as canning supplies became unobtainable later that year.
    Sep 2004
    Arizona
    Seals used to be separate from lids.
    vs how much money you saved on canning lids?
    not a good economy...
    Aug 2002
    The reusable lids that I have use separate seal rings.
    Texas
    [insert blowing seal meme here]
    Oct 2003
    Valley of the Sun
    Texas
    Mar 2006
    Entry Level
    I kept the first few empty boxes of replacement lids to keep the used ones in for storage, not canning; e.g. sun dried tomatoes. Price tag still on: 58Ę
    If Russia wins, there will be no Ukraine; if Ukraine wins, there will be a new Russia.
    -- Dmytro Kuleba, Foreign Minister of Ukraine
    Feb 2011
    n.c. tn
    for going on 30 years, I've reused lids unless they have a break/spot in the ceramic inside coat. Acid (water bath)/pressure, matters not. It's all good. There's a 'nopolice canning' group on book o' faces.. one of the (few enough) good things there, people from around the world share - shaming, not allowed. Reuse is fine. Yeah, imagine a 'for profit' culture insisting everything be new..
    Sep 2003
    Farmington, Oregon
    Quote Originally Posted by Durnik View Post
    yes.
    re-using may not make sense by some cost/benefit analysis, but very little i am doing these days pencils out anyway.
    i guess re-using lids is part of my aesthetic.
    Feb 2011
    n.c. tn
    ^ I hear that. cost/benefit (to capitalism) has made this mess.. the 3R's started with Reduce & Reuse (I believe you also pointed that out recently?).. and reusing means also reducing/reusing the energy spent/pollution created mining/making/shipping/buying.
    the old lids are already here & tested, plus I'm french yankee by birth & southern scottish by acclimation.. cheep, cheep, Cheap! (-:
    Feb 2011
    n.c. tn
    The definitive source for good info on the topic. They donít squarely address reusing. Or they do, and itís acceptable given that it is not prohibited. I only spent a few minutes and may be wrong.
    from the pic - "buy only the quantity of lids you will use in a year"..
    they are _not_ the definitive source. In fact, it can be easily seen they are clueless. Do people really imagine we know in advance how much canning we will do this year? Riight.. Great year.. or so/so year.. who knows, and supplies are bought before the fact. They're not canners, I see - nor, for that matter, preppers. Good capitalists tho! Bah! We stock up on lids when they are available and the price is right.. and use as needed.
    Nebraska
    Either they seal, or they don't. New, or used. Right?
    I don't see the problem.
    Texas
    Geocel 2320. Seals every time.
    Nebraska
    Surh. Buth stickth my tongue toh theh roof of my mouf!
