View Poll Results: What's your varnish of choice? Add others in the commnents.
Voters
61. You may not vote on this poll
  • EPIFANES Clear Gloss Varnish
    27 44.26%
  • PETTIT Flagship High Build Varnish 2015
    4 6.56%
  • PETTIT Captain's Varnish 1015
    13 21.31%
  • SYSTEM THREE RESINS Spar Urethane Gloss Varnish
    1 1.64%
  • CETOL Cetol Marine Gloss
    3 4.92%
  • AWLGRIP Awlwood MA Clear Topcoat Finish - Gloss
    1 1.64%
  • MCCLOSKEY Man O'War Spar Marine Varnish - Gloss
    5 8.20%
  • INTERLUX Schooner Gold
    4 6.56%
  • INTERLUX Original 90 - Traditional Spar Varnish
    3 4.92%
  • BRISTOL FINISH Clear UV Finish Urethane Varnish
    0 0%
Results 36 to 70 of 171
Thread: Poll: Life after Behr Spar Varnish
    Jan 2011
    Norwalk CT
    Default Re: Poll: Life after Behr Spar Varnish
    pfffft ...how do you pronounce Epifane?
    Var-nish
    I chose to use Epiphanes because I like the look and sound of the name. Seemed like as good a reason as any. Flagship sounds rather navy or political like. Man O' War, the same. Behr... well who can find it? Besides, does it poop in the woods?
    May 2006
    City, State, Country
    I think Steven Bauer must have the last unopened gallon of Behr in the world. A big responsibility, if you ask me.
    Yeadon is right, of course.
    Jul 2002
    We might have a poll of the best way to remove 12 coats of varnish every 3 years .
    The best way to proceed is to have someone who knows how to varnish do the job.
    There have been several excellent products mentioned here. I first ask if my client has a preference. So I've used an assortment of varnishes and similar products.
    But I don't recommend that approach. Instead, for most boat owners, I strongly suggest you pick one of the reputable brands/products and get as good as you can with it.
    FWIW -- My own go-to is Interlux Schooner #96. Unless I'm doing something where ambering is undesirable. Then there are some other choices available. I grab McClosky's if it's handy. Pick a varnish. Pick a brush type. Get some of the recommended solvent. Using them consistently will yield far better results than hopping around in a search for 'better'.
    Jul 2002
    davidg, you don't mention Cetol. (?)
    Aug 1999
    Woodbridge, Suffolk, UK
    Epifanes. Always rub down between coats. That’s 14 coats.
    IMAGINES VEL NON FUERINT
    Feb 2001
    Seattle, WA USA
    Le Tonkinois is not on the list.
    That's an awfully nice varnish.
    Jul 2002
    Quote Originally Posted by Andrew Craig-Bennett View Post
    Hey! You trying to confuse the boys, Andrew?!
    Jul 2002
    Because I don't speak French I would not be able to read the instructions on the can.
    Jim Drake might have some, too. We each bought a case when it was getting scarce.
    Dec 2015
    Dorset, UK
    A few other marginal gains...
    Beside Schooner original, I use a Harris stain/ varnish brush. Clean it in Intetnational’s solvent then store it bristles suspended in a jar of linseed oil (not boiled) that doesn’t skin or oxidise (only very slowly). Coz its a tung oil based varnish its kinda ok to store the brush in oil. When i do some more, take it out swill it off in some Internationals solvent again then dry it then go to the boat. Brush is always clean/ supple and its more eco than chucking brushes and you can use a nice one. I think I got that from the woodenboat series finishing book. Cut off any stray bristles before using it. Doesnt seem to loose shape suspended in the linseed oil.
    I also have to say, some course paint filters (amazon) strain out any lumps easy, though with the bags, now that seems to be fixed as its not going off in the resealed tin, even upside down. With the bags you just sqeeze any air out and seal it. About a £1 bag.
    Getting some tack rags also seems to eliminate that last bit of dust and improves the finish. Then picking my day...windless grey overcast if possible. Just leaves those black flies...
    Dip my brush in the clean undisturbed - no bits picked up from the boat or bubbles - right hand side of the decanted varnish container, and remove excess or whatever on the left side of the plastic tub so dont pick that back up.
    It’s A Pee Fanny.
    May 2015
    Oakland, California
    I find Sikkens Cetol Marine to be a perfectly acceptable 'clear' finish for brightwork. Impressive longevity. But wasn't the OP asking about varnishes?
    Also... Your comments about the horrible orange are outdated. They don't make that product any more. They make 3 versions of the base (color) coat. And then the clear topcoat. One of which resembles the original fluorescent orange goop a bit, but much muted. My preferred flavor is the Natural Teak.
    For this thread, I am speaking of Cetol Gloss.
    I have mentioned "Cetol Orange" a few times , knowing it is a novelty.
    Cetol Gloss dries clear, shiny, fairly hard ,very slowly, and outlasts any other product here,imo.
    bruce
    Jul 2002
    Well, ok. As the Frenchies say: "chacun à son goût."
    Never used it. Never will. Why go to all that prep work, and then top it with a finish, which to me, is inferior.
    Jul 2002
    Aug 2006
    Rockford, IL
    Deks is easier for patching a ding because it's a softer finish. For #1 it's just a case of rubbing on more 1. For bright #2 all you have to do is lightly sand, rub in a couple of coats of #1, then apply a couple of coats of #2.
    Fisheries Supply does not sell Deks Olje. I feel like maybe I've seen it at the Northwest Maritime Center Chandlery in Port Townsend. (Though it's not listed in their store.) What do you like about it?
    Erpifert.
    Duh.
    Mar 2012
    Adirondack Mts, New York State
    Interlux #90 Original.
    Brushed on with a cheap handled brush that has good natural bristles. I clean the brushes and use them 10-12 times then throw them out. The only cost $15 so not a major investment.
    Aug 2006
    Rockford, IL
    QUOTE=Andrew Craig-Bennett;6695778]
    Epifanes. Always rub down between coats. That’s 14 coats.[/QUOTE]
    Stunning! But do you get to use it between coats of varnish?
    Nov 2006
    NorCAL
    Jul 2002
    Quote Originally Posted by Nicholas Scheuer View Post
    Stunning! But do you get to use it between coats of varnish?[/QUOTE]
    The drying time per coat will increase with additional coats.
    A customer once wanted twelve coats of varnish on his Chris. (not 13, not 11) I usually coated until the grain was full then a couple more. Did not count. I would guess 7-8-9
    May 2006
    I use Cetol gloss over numerous "varnishes".
    Bingo is Cetol Gloss over epoxy
    The little bit of bright on Woody is Cetol Gloss over Cetol "orange"
    and of course Wonderland is all Cetol Gloss over Cetol orange
    Woody is a fun boat. The Cetol looks great on her. Nice dog too.
    Jul 2002
    Quote Originally Posted by Chris Woodward View Post
    Nice work. I used to use foamies for the build coats, then switch to an inexpensive brand which does not drop bristles...sorry, can't remember brand...they were about 5-6 bucks wholesale then just toss 'em.
    Warning! Do not buy badger brushes. If you want to spend a lot of money on a brush, go to a professional painters' supply house.
    The Fooler
    May 2007
    Seattle
    I'm currently having pretty good results with McCloskey Man o' War on my spars and tiller.
    That's what I am using
    What's not on a boat costs nothing, weighs nothing, and can't break
    Jul 2002
    It is a wonderful handling finish...there are some issues with longevity...
    It is very pale, at times that can be an issue.
    Jul 2002
    Default Re: Life after Behr Spar Varnish
    Saddened by the refusal of Home Depot to carry Behr Super Spar Varnish, I'm curious what varnish my fellow forumites are using. Let's poll the crowd. My poll contains varnish products carried by Fisheries Supply in Seattle.
    Feel free to add your own product suggestions in the comments.
    Shopping at Home Depot? Are you aware that the company is owned by Satan?
    Durham, NC
    So my local Home Depot sells Behr Spar Urethane. I take it that this is not the same varnish that was earlier marketed by Behr. Or is it? I've used Pettit Captain's for years and like it a lot. I've run out and need to buy more hence looking at other products.
    - Anything you can't have fun with is not worth taking seriously.
    Quote Originally Posted by gazzer View Post
    Hmm, an oil based urethane. $18/qt, $47/gallon. I’d say worth a try. Who’s going to step up and report back?
    May 2006
    Not the same stuff. Though for a premium Steven could probably sell you a few ounces of the original nectar.
    I'd just order more Captains.
    Apr 2019
    Massachusetts
    The manufacturer pronounces it Epi-faaan-ays
    yea but, they have a dutch accent. I can't even pronounce their cheese (post #16)
    Jul 2002
