Results 36 to 52 of 52
Thread: No Frills Standalone Radar
    seattle
    Default Re: No Frills Standalone Radar
    I helped a friend bring his Nordic 37 back to Bremerton from Anacortes yesterday and he has a brand new Raymarine radar, having replaced his old magnetron spinner. I found myself being quite envious of his new screen that color codes targets; orange for stationary things like buoys, purple for targets getting closer to you, and yellow for ones moving away. There may be more. My little Simrad just shows everything orange, leaving me to sort out the differences. His radar also shows his Navionics waypoints as little squares.
    May 2007
    Seattle
    Navigation tools just keep getting better. I picked up a book published in 1989 entitled a powerboat "bible." Lots of information about Loran C and other obsolete systems and hints about GPS, which was touted to be the next big thing, which of course it was.
    Looking forward to having a working radar again.
    What's not on a boat costs nothing, weighs nothing, and can't break
    May 2007
    Seattle
    Life interfered with getting the radar installed. Working on it now, but here's a question: the instructions tell me to run a ground wire to the hull or something bolted to the hull.
    "GROUND
    Connect ground
    wire to bolt fastened
    (or welded) to hull."
    Not sure about this. Whether it is needed. Not sure if it applies with a wood hull
    seattle
    You had me at “The instructions tell me to run aground…”. Thought it might be a new way to test radar.
    Can’t imagine that a ground strap to the hull does anything on a wooden boat. But I don’t know, maybe someone else knows better.
    May 2007
    Seattle
    Hope so, because I am not sure a ground would do anything
    seattle
    Lightning protection?
    Apr 2019
    Massachusetts
    Re: AIS: I keep thinking that someone will integrate AIS transmit with receive in a VHS radio so you don't have to buy an extra box. Has that happened?
    Ken
    It is a lot more complicated than and an AIS receiver. With the receive only option, you just need the VHS to continuously monitor the AIS frequency and plot it using GPS location in addition to normal radios functions. Once you make it a transceiver, you need essentially two transmitters and two antenna (or a signal splitter for a single antenna).
    May 2016
    Ottawa, Canada
    AIS + VHF
    https://www.vespermarine.com/cortex?hsLang=en
    Personally, I went for separate units for a little redundancy.
    Mark
    Does it go to a ground plate? I'm a long ways from my boat, so I can't look to see how my 1624 is hooked up.
    Default No Frills Standalone Radar
    "GROUND
    Connect ground
    Run it to the engine. There should be a ground terminal or ground buss for the engine.
    The ground bleeds off rf interference and will enhance performance. That said, you could try without. As always, YMMV.
    Jul 2008
    Ct.
    Yes they do, quite pleased with the small Furuno WiFi radar, picks up small boats and nav. markers just fine.
    May 2007
    Seattle
    Quote Originally Posted by woodpile View Post
    I fished commercially in the days of Loran C. I much prefer my laptop chart plotter.
    I suspect the new radar -- haven't had time to finish the install-- will be much better than its 1986 predecessor.
    May 2007
    Seattle
    I finished the installation, plugged the new unit in, and it worked....
    The biggest issue installing it was figuring out how to hide the extra cable. Furuno sent me a 10 meter cable. I did not want to spend $150US for a 5 M cable, which looked to be back ordered in any event. I mounted the display a riser and coiled the spare cable in the riser. I am pleased with how it all turned out. Good to have a working radar in the foggy part of the year.
    Glad it's all sorted!
    seattle
    My extra long cable is coiled in my chart rack.
    Aug 2022
    Minnesota
    All the best with the bleeps, sweeps, and creeps...hoping you don't get jammed :
    May 2007
    Seattle
    No jam so far. Need to learn the adjustments though.
