Results 1 to 19 of 19
Thread: Solar water
    Texas
    Default Solar water
    Reading the lake mead thread is depressing.
    Running a dehumidifier from a few solar panels and a cheap all-in-one inverter is all I can think of. Some will even run without a battery but having the buffer would be helpful.
    Would make water but lead solder joints and other not food safe stuff might be a problem.
    other ideas?
    Mar 2006
    Entry Level
    Default Re: Solar water
    Put a clear tarp over your lawn and collect the condensation?
    Then you could water your lawn.
    I'm not leaving.
    -- Mike Pence
    Texas
    We’ve got lots of sun. No rain. Not much condensation.
    Jan 2005
    Deepest Darkest Wales
    Move.
    We have a complex seawater distillation system which delivers an enormous volume of fresh water reasonably regularly, this is teamed with an advanced drainage system which supports trout.
    Population of Wales: ~3.1 million; population of LA: ~3.9 million. Might work? Problem is that without Lake Mead, LA is also without power. This could be a very ugly summer in a very dense neighborhood.
    Move.
    Would you be moving anyway after Texas secedes? Or would you stick it out in the Republic?
    Still Above the Grass
    Move.
    We had the exact same system when we lived in the Tongas rain forest.
    Texas
    6th generation. I’m stayin. I’ve got too much tied up in the uncle tom’s cabin.
    May 2002
    the hills
    Tom, what is the rainfall at your cabin and what is your existing water source?
    Texas
    38 inches annual. And about 1200 sq ft of collection area. A rain tank or cystern is vaguely planned. Will have a chance to put it in when I do septic.
    right now, it’s about 1000 feet of good rubber garden hose.
    other ideas?
    Lead free solder has been a requirement for drinking water systems here for a long time.The product exists somewhere and might get you one step closer.
    Move.
    Asking in the spirit of understanding.
    How much power is required, and at what cost per kW, for such a system to make sense?
    Texas
    Dehumidifier. 530 watts running. $250. 50 pints/6.2 gallons at , I guess 24/7. Depends on conditions.
    Five 350 watt panels. Around $1,750 installed.
    Small battery for buffer and runtime. LiFePO4. $1,000 for 200 amps at 12 volts. 2400 watts useable.
    6 hours good solar (10,500 watts generated). Less 3,180 used during peak production. 7330 watts for the batteries.
    Looks like I could knock out a panel or two.
    Small inverter with surge. $1250 (guess).
    6 hours run time in sun plus 4 hours run time on batteries.
    10 hours is about 2.5 gallons. $4,000-5,000.
    There is a solar panel thing out there that claims to generate water. About $2,000 each. Looks scammy.
    edit-knock all production back by about 25% for real life. But panels could be south East and west to increase solar run time
    Is there enough humidity in your air to make that system feasible?
    Oct 2003
    Valley of the Sun
    wonder how much water texas uses in hydraulic fracturing total
    according to the texas tribune, when fracking is used. it's something like 6 million gallons of water per natural gas well and 4 million gallons of water per oil well per annum per well
    Jan 2005
    It's all large scale direct solar, no fossil fuel, no nuke.
    Mar 2001
    Grosse Pointe, Michigan, USA
    Move.
    We have a distillation system that also delivers a volume of fresh water reasonably regularly. We call it rain.
    Texas
    That system is not meeting needs.
    Interesting. I would have thought hydropower in your part of the world.
