Results 36 to 42 of 42
Thread: Why are inboard engine shafts angled down ?
    Aug 2020
    newburgh,NY
    Default Re: Why are inboard engine shafts angled down ?
    The reason I might want to keep the engine level is that I am building a small steamboat and it may make installation easier. I am planning to us a thrust bearing because the bearings in the engine are not thrust bearings.
    Quote Originally Posted by Pete H View Post
    Fair 'nuf! I'm sure experts here can tell us about the best way to do this, but one thing I'd consider is a constant velocity joint (like one in an axle of a FWD car) instead of a U joint. They are much smoother.
    Nov 2003
    Rio de Janeiro, BRAZIL
    A Constant Velocity (CV) joint-cum-thrust bearing in the same piece :
    https://www.vetus.com/en/stern-gear-...-5-flange.html
    May 2005
    Bradford, VT
    Ian's suggestion of Dave Gerr seems a good one. He has some successful tunnel drive designs. One advantage evidently is running at speed over known bars and enjoying the surprise in the audience that you didn't rip the stern gear out.
    Quote Originally Posted by carioca1232001 View Post
    Perfect - though I bet it's not cheap... Nope - about $1700 US.
    Nov 2003
    Vetus´ engine-to-drive-shaft couplers are renowned for their prowess in subduing noise and vibration. Not inexpensive by any means.
    herez ware we r at jusnow.... fine tuning the inside
    a lil picture i made of her about 20 years ago
    At first glance, Bruce, I thought you painted a desert landscape scene on the inside of the transom. Looks like sky and mesas in the background, flat sand in the middle, and perhaps a riverbank with some greenery in the fore.
    Maybe just clear coat it?
