Results 36 to 47 of 47
Thread: 600 lb Lead Keel Mold
    Bainbridge Island WA
    Default Re: 600 lb Lead Keel Mold
    Concrete suffers from thermal spalling at around 570 degrees Fahrenheit (300 Celsius) the melting point of lead is 620F (325C).
    H.A. Calahan
    And it sounds like someone is shooting a gun...
    Feb 2001
    Seattle, WA USA
    1/16" sounds about right to me too.
    Bud McIntosh covers this in "How to Build a Wooden Boat". He says to pour your ballast as lofted and then build off the actual shape. Makes sense to me.
    This says 5/16 per foot for lead.
    https://www.nonesuchtools.com/pmkr/shrink.html
    I didn't measure the actual shrinkage of my keel pour which is 5'-6" long and m/s roughly 5"x5" but it didn't go from 5'-6" to 5'-4 1/2" in the cooling process.
    H.A. Calahan
    mine did, almost exactly
    Jan 2021
    Orlando, FL USA
    Okay, now I'm rightly confused with regard to this shrinkage thing. Yes, there is no doubt that lead shrinks on "freezing" and that the rate is 5/16" per foot (2.6%). HOWEVER! As seen from some of the mold pours that I've viewed on YouTube (most specifically Bob Emser's "Art of Boatbuilding" and Steve and Alix's "Acorn to Arabella") the solid lead didn't seem to pull away from the walls or ends of the mold (or from the centerboard slot blank in the case of "Art of Boatbuilding").
    So, my MOST IMPORTANT QUESTION is: Does lead shrink *evenly* (from all dimensions) when cooling in a mold? Or does it *just* shrink from the open top?
    My mold is roughly 8' long, so allowing for shrinkage, should I make it 8'2" long? I will reach out to Emser to get his experience, but it certainly seems like the cooled lead was *very tight* to the mold when he broke off the mold wood.
    Thank you again for your sage advice and experience.
    Jul 2021
    Greater Northern Arizona Republic
    Not actually knowing, I would think shrinkage would be concentrated wherever cooled fastest and that some of the variation people see involves their setup.
    Oct 2017
    Berkeley, CA
    If the pour cools unevenly molten lead gets drawn out of hot of hot areas to those that are cooling. To prevent voids from forming it is often recommended to heat the pour area to keep a pool of molten lead that can flow into the voids. If enough molten lead is drawn away like this the vicinity of the pour has less metal in it. This process isn’t shrinking per se but the end result is that there can be less lead in the area of the pour than elsewhere. My pour ended up with a slight low spot and was also pinched inward just a hair in the area of the pour. I faired it with fairing epoxy.
    Feb 2001
    Seattle, WA USA
    Quote Originally Posted by nrs5000 View Post
    That is a whole 'nother issue than shrinkage.
    If you heat, or cool, a metal/crystal/pretty much whatever, it expands or shrinks respectively. By a very predictable amount.
    Water (ice) is the anomaly. It contracts (shrinks) until it hits c. +4 deg C, its point of maximum density. Then, as it gets colder, it starts expanding again. Weird stuff, water.
    It would probably be better to describe shrinkage in terms of percentage -- e.g., 1 cubic foot of molten lead shrinks xx% from molten to ambient temperature -- but that's not terribly useful to the pattern maker who has to make the pattern or mold.
    Quote Originally Posted by bogolese View Post
    Excellent idea about the dowels for the bolt locations. Is a specific ply that you would recommend or avoid (e.g., OSB)? OSB, is, of course, nice and cheap. ;-)
    It was nothing fancy I know that much.
    This was the mold, I got Peter Sibley to make it for me.
    Mold in the ground and pouring.
    It wasn't that pretty when the mold was removed.
    Cleaning it up was messy but the end result was pretty good.
    I would rather have questions that can't be answered than answers that can't be questioned
    The cheapest power-plane you can buy will make about 500 lbs of chips before you toss it in the recycle bin...
    N62 5352" E27 4110"
    +1. Exactly what I did, although mine was an ok unit but almost at the end of its career when I used it for the ballast.
