Results 1 to 17 of 17
Thread: wave speed?
    May 2010
    Port Townsend, Wa.
    Default wave speed?
    This morning I was messing around on the "Windy" app, and noted 10' waves every 8 seconds offshore of Neah Bay, Wa. while in Eastern Lake Michigan the app reported 6' waves every 5 seconds. I wondered what the relative wave speeds and steepness might be, but quickly got in over my head in equations when searching the topic online. Has anyone come across graphs &/or a simple way to deduce wave speed? (In both cases I think I got the data far enough offshore that they would be considered deep water waves) Obviously we are also dealing with the difference between fresh and salt water.
    Ken
    Default Re: wave speed?
    Waves in my part of the Atlantic are *normally running at about 10-12 knots. This estimate from years of running home downsea at ~22 knots boat speed and observing.
    *Normal means, say, 2'-4" seas, six second period and winds 15 kts or less and no storm nearby. A hurricane in mid-Atlantic may not affect the weather but can generate larger, faster moving waves, for example.
    Oct 2003
    Valley of the Sun
    the waves in neah bay began their journey 6000 miles away and bounded over the deepest ocean on earth before piling up on the west coast
    the waves in lake michigan coalesced twenty or so miles off the coast of wisconsin and then traveled a mere 100 more miles across the lake
    big difference in how the two waves were generated and evolved
    Apr 2017
    Kailua, HI
    In oceanography, the equation you are seeking is for "celerity". Dont have it ready to hand tho, sorry.
    Feb 2010
    Sonoma County, CA
    rough formula... in deep water, the speed (in knots) at which a train or set of waves moves thru the water = 1.5x the wave period (in seconds) so a set of waves with an average period of 10 seconds would be 15 knots
    individual waves within the set would move faster than that, new waves are constantly forming at the back of the set, moving their way through to the front and then petering out and the process is constantly repeats itself across thousands of miles of ocean with very little energy loss until ideally it becomes perfect clean surf breaking on a California beach
    Wave celerity - The speed at which an individual wave advances or “propagates” is known as the wave celerity. For a deepwater wave the celerity is directly proportional to the wave period, T. The formula for deepwater celerity, Co, is Co =1.56T m/sec
    So for Lake Michigan your speed is 7.80 m/s
    May 2010
    Port Townsend, Wa.
    Does your formula also apply to fresh water?
    Ken
    Oct 2017
    Berkeley, CA
    I believe In deep water wave speed is purely a function of wave length. This is why boats have a hull speed.
    Ken
    Yes, or it would include a density function.
    May 2010
    Port Townsend, Wa.
    Ok, I hear what you are saying, but I just moved from Chicago to Port Townsend, Wa. and my initial impression squares with what is often mentioned in other accounts: That waves in fresh water get up taller and closer together for a given wind velocity than in the sea.
    Lots of factors will affect wave speed, especially water depth, fetch, and how long the wave was forming. For mature ocean waves, the formula is like the "hull speed" formula: 1.3 times the square root of distance crest to crest in feet yields wave speed in knots. Give or take.
    Factors matter. For example, shoaling will increase wave height and slow wave speed. Juvenile seas are not so high but can be steep, close crest to crest, and slow. And lets not even get to barometric pressure.
    Correctly estimating wave height from a boat is hard. In another thread I gave a method that involves known sight lines. Wave speed is even harder unless you have good instrumentation, can climb on the wave's back, and take that a ways.
    Wind blowing on one part of a sea or large lake will generate waves of all sizes and wave length. The longer faster waves will arrive at an observer before the shorter slower waves. If there was a storm close to the observer and one far away, the observer will see a mix of waves from the two storms, and if there are islands out there waves will also be reflected or diffracted. Which is why measuring sea states is such fun.
    On the topic of wave height/sea state observers tend to focus on the highest wave heights in a sea, so oceanographers refer to Significant Wave Height to define the sea. That is theaverage height of the highest one-third of all waves measured, which is equivalent to the estimate that would be made by a visual observer at sea.
    If an observer reports a six-foot wave height sea state, the oceanographer can convert that to a spectrum and calculate the total entrained energy of the wave system.
    Bay of Islands,N.Z.
    Is the purpose being to work out what wave state you'll go out in? Because that's down to boat size / comfort and how much they can bridge the chop or be in or out of sync with the wave.
    Brings to mind a wonderful sail on a 50 ft (35 ft waterline) boat upwind in shallow water in a typical 3 or 4 ft chop, the Tamaki straight( one of the recent America's Cup courses) up front were small boats at perhaps half or 2/3 our speed, pitching away their boat speed. Bucketing.
    As we caught them up they turned out to be 3 or 4 Townson 32 yachts, not small at all and a boat renowned for windward ability and performance. They just weren't in sync with the waves presented that day, a few ft more in w/l and overhangs and we slid on through near flat.
    May 2010
    Port Townsend, Wa.
    Is the purpose being to work out what wave state you'll go out in?.
    Indirectly: When I was younger I crewed on a variety of plastic sloops in 'round-the-buoy races out of Chicago. I was always struck that in going upwind they all had a rhythm that was essentially out of sync with the waves: They would ride one wave fine, ride the next one and overshoot in height and on the third or fourth they would butt head into the next wave. Then they would start the whole process over again. Of course all these production boats were designed for the predominant salt-water market and I wondered if there might be a design that would stay in sync with the waves? So a huge part of my motivation for building a traditional Mackinaw boat has been to find out if the old timers may have found a better rhythm? I haven't sailed my Mackinaw enough in big enough water to be ready to weigh-in on that question, however I can say that the fine lines aft definitely lift less with a passing wave and therefore are less likely to lever the bow down into the coming wave. It is also striking that as this boat approaches hull speed it doesn't drag a big quarter wave behind it. The bluff bow definitely makes itself known, but the water leaves the stern much flatter than other boats I have sailed.
    So my essential question is differences between fresh and salt water waves?
    Ken
    Pleasant Valley NS Canada
    Like most things with boats, the closer you look at the seemingly simple bits, the more complicated it gets. This topic is firmly within that generalized statement...
    Every boat hull has a natural pitching frequency. This frequency is affected by amounts and locations of weights within the hull, i.e., if your boat has a natural pitch frequency of x, and you put that giant cooler full of ice and beer in the bow on the vee-berth, the natural pitch frequency changes to x+1. Think of it like a teeter-totter at the playground - put two kids of equal weight at the ends of the plank, and it rocks (pitches) at a certain frequency. put a lead weight on one end by one of the kids and (besides being unbalanced) the pitch frequency changes. But for now, just assume that the pitch frequency of your boat is constant (don't drink all the beer and change the location of its weight in the boat! <grin>)
    In really simple terms (i.e., the sharp guys in the crowd will show up shortly to offer up a bunch of well-meaning 'whaddaboutisms' to illustrate the error of my explanation), if your boat has a pitch frequency of, say, five seconds and you are sailing head-on into a wave pattern that has a crest-to-crest frequency of, say, seven seconds, your boat's pitch will coincide with the crest of a wave every 35 seconds. In the intervening pitches of your boat, you will be either behind the crest or catching up to it. If, however, your boat has a pitch frequency of five seconds and you are sailing head-on into a wave pattern that has a crest-to-crest frequency of five seconds, as your boat's pitch will coincide with the wave crest frequency it's motion will be amplified by the waves acting on the hull and your boat's motion will become extreme, uncomfortable, and possibly dangerous.
    If you are in seas that match your boat's pitch frequency and you are in danger of losing your lunch, you need to break the cycle of pitch amplification by the waves. Since you can't change the length of your boat (length of the hull affects its pitch frequency) and changing weight distribution within the hull is usually pretty difficult, the only thing you can do is change the wave crest frequency. I know, you are scratching your head and saying to yourself, "This guy is an idiot! (maybe true, but...) I am not God - I can't change the waves!" No, you can't, but if you change heading a bit - say fifteen degrees - then you change the distance your boat travels between wave crests, and thereby changing the apparent frequency of the wave crests, assuming that you maintain the same boat speed. How much you have to change direction to find your boat's 'sweet spot' is dependent on the pitch frequency of your boat and the wave frequency. It can be done mathematically, but that is rather involved and geekly, so the best method is trial and error until you get to know your boat well and can 'read' the wave patterns to determine what heading would be best for you in that particular situation - in other words, seat-of-the-pants understanding.
    Oct 2017
    Berkeley, CA
    Ken
    I'm no expert, but I would think that the shape of the body of water, its orientation to the wind, openness to the ocean or not, and currents, would make a much bigger difference in wave forms than the small difference in density between salt and fresh water. To take but one variable, bodies of salt water very often are tidal, and tide running against a wind can generate a nasty chop. But some areas have a greater tidal range and/or variety of landforms that exacerbate this; others do not.
    Ken
    Nothing at a level that you can detect except mass. A one-foot-wide slice of a 3-foot tall seawater wave weights about 13.5 lbs more than a fresh water wave of similar size. The shape and frequency of the wave is determined by water depth.
