Results 1 to 12 of 12
Thread: Two Day Boat Build Chuckanut 12s Skin-on-Frame
    Scottsville, Virginia
    Default Two Day Boat Build Chuckanut 12s Skin-on-Frame
    I'm more familiar with boat projects that take years to complete. So going from a pile of wood and fabric to a completed hull, ready for paint and trim, was kind of baffling.
    My wife wanted something she could manage on her own, so I thought one of Dave Gentry's skin-on-frame open kayaks would be just the ticket. Dave happens to live a few miles up the road from us, so brought a couple of his prototypes over to the local pond for her to try out. The Chuckanut 12s was a perfect fit ("s" for slim or small or supremo). Dave offered to show me how he builds these, so we could build this one together.
    More details here than I can put in these short posts:
    Two Day Boat Build
    Day 1
    I got to Dave's shop on Saturday around 10:30am. He had already cut out the patterns and most of the stringers by then.
    We quickly set up a 2z4 as a strong back, clamped down a keel plank, and maked off the stations.
    Then clamp and screwed some brackets in place to hold the frames, and we were off to the races.
    Dave had modified every step to make if faster, cheaper, and easier. We dry fit everything with stainless steel screws from the hardware store.
    Then backed out the screws, squirted in some thickened epoxy, and screwed everything tight again.
    By dinnertime, we had a completed frame done, and a logical break while the glue to set up overnight.
    Default Re: Two Day Boat Build Chuckanut 12s Skin-on-Frame
    Day 2
    On Sunday, I rolled up again late morning and we got started around 11am.
    While the hull warmed in the sun to finish curing the epoxy, we cut some foam insulation sheets with razor blades and stacked those in the bow ends.
    Cheap but effective floatation.
    Then moved back into the shade of the shop for skinning.
    Polyester is super hard to find right now, so this boat is skinned with nylon. Nylon absorbs water, and swells and relaxes when it does, so we soaked the fabric first and put it on wet.
    We spritzed it with water to keep it damp while wresting it in place.
    Dave uses stainless steel staples to "stitch" the fabric to the frame, so this goes really quickly. Just takes a lot of strong hands to stretch it tight and drive the staples.
    Once the bottom was covered, we trimmed the excess fabric, flipped it over, and singed the edges to keep it from unraveling.
    Day 2 Continued
    Next was covering the deck, same way. After that, we ran a heat gun over the whole thing to dry it out. The heat gets a little shrinkage – not like polyester, but but enough to pull out a few dimples.
    And then it was done before dark on the second day! The whole boat weighs 25 pounds.
    Next up is sealing the fabric with paint, and adding cockpit trim and a rub rail. That's it.
    This is what a finished boat looks like, the one we tried out beforehand.
    And here's is some video from that day on the pond. Dave is there with his daughter in the new prototype of the Indian Creek Motor Canoe.
    The boat is driven by cheapie 12v trolling motor and a little battery the size of a lunch box. Dave covered the motor with a wood veneer cowling.
    Aug 2017
    Melb, Vic, Aus
    Jeez... took your time. lovely, thanks for posting
    Nice!
    I will build a Gentry yak someday!
    Apr 2004
    philadelphia
    Very nice Barry. I’ve been pondering a skin on frame, and this provides a lot of encouragement. I hope to see the boat some day.
    Andy
    Nice!
    I think I’ll build two. Loved the video.
    Awesome! Dave is just the coolest guy, and that boat looks sweet.
    Nov 2010
    Wellington, NZ
    That looks awesome!
    I'm going to have to build another kayak for my daughter, her current one has basically run out of freeboard.
    This (or something like it) looks just the ticket.
    I can't bring myself to buy one of those plastic abominations.
    Nice. The fun-to-work ratio is off the charts for these little boats. You mentioned finishing with paint, but what paint works on nylon? I thought thick goops worked into the fabric were necessary.
