Results 1 to 13 of 13
Thread: Best to put off-center prop on Port or Starb side of keel?
    Apr 2004
    Brisbane QLD (Everton Park)
    Default Best to put off-center prop on Port or Starb side of keel?
    I'm thinking about mounting a pod motor on Tempo. It will be beside the keel and hopefully the prop tips, won't extend much below the keel.
    Assuming it's a right-hand screw, which side is preferred?
    Thanks, Mack
    Mark Twain
    Default Re: Best to put off-center prop on Port or Starb side of keel?
    Starboard has the upper blade wash carrying junk away from the hull, albeit perhaps dredging up the bottom. If the boat's shape is normal, moving the unit aft might give room to get the prop tips out of the mud.
    Assuming steering with tiller and discounting the pod's ability to rotate and deliver directional thrust...
    In forward, your RH prop will want to push the stern to starboard...except much of the lateral thrust will / may be blocked by the keel if pod is installed to starboard.
    In reverse the RH prop will tend to kick the stern to port...except much the lateral thrust will be / may be blocked by the keel if pod is installed to port.
    Personally, I would install it to starboard to maximize my thrust and maneuverability in reverse.
    Prop kick is your friend once you know its direction and force.
    West Boothbay Harbor, Maine
    What design is your Tempo?
    “Eventually, all things merge into one, and a river runs through it. The river was cut by the world's great flood and runs over rocks from the basement of time. On some of those rocks are timeless raindrops. Under the rocks are the words, and some of the words are theirs."
    Aug 1999
    Woodbridge, Suffolk, UK
    You don’t get lateral thrust, in the ordinary sense of the word, with a side mounted prop. You get something different.
    I had one for 29 years and I know. She had a big LH wheel to port. Attempts to berth port side to, in the time honoured way, were fine until the untutored helmsman went astern to stop her and kick the stern in, as per textbook. She would immediately jump six feet sideways off the berth. Did it every time!
    On the other hand, whilst turning away from the prop was a lottery, turning towards the prop with the rudder hard over was impressive!
    You will get slightly better ahead performance if you mount the wheel as Ian suggests.
    IMAGINES VEL NON FUERINT
    Jul 2002
    I crewed on a NY32 with off center prop...backing was a byotch. Forward ok.
    Apr 2004
    I built Tempo from Reuel Parker's The Sharpie Book. (A book I highly recommend regardless if you're building a sharpie or not.)
    18-foot Modified Sharpie Skiff, Hooper Island, Chesapeake Bay, 1906.
    "The type represents the highest stage of evolution of the sharpie into the deadrise skiff. The model is moderate, neither a burdensome workboat nor a flat out racer."
    I don't think there will be much prop walk on this Crab Skiff. Reverse will probably cavitate and a folding 2 blade prop won't help back-down.
    Mark Twain
    Jan 2005
    Deepest Darkest Wales
    Quote Originally Posted by leaotis View Post
    I'm wondering if the pod/prop would fit into a cutout in the rudder..
    It's just a thought.
    Aug 2012
    PNW
    That is sweet! Any more images of the boat floating around the forum?
    If you ever feel the mood come over you to post more pics I'd be grateful.
    ♦ George Orwell
    Apr 2004
    Thanks for asking Auto.
    This is my favorite.
    Tempo being built.
    Tempo videos
    Mark Twain
    Or hang the pod on the rudder with the prop as close to on center and the blades as near the back of the rudder as makes any sense.
    As you take the ground on a falling tide put the helm down so the prop and most of the rudder stay clear.
    Or make a cutout in the rudder that holds the pod. Fair all nicely.
    Aug 2012
    PNW
    Thanks leaotis! The no-nonsense bow and sweeping sheer evoke a very yar impression.
    ♦ George Orwell
