Results 1 to 12 of 12
Thread: Perfect boat for a honda 20
    Jul 2016
    Duluth, MN, USA
    Default Perfect boat for a honda 20
    I have a perfectly awesome 20 hp Honda short shaft remote power trim tilt motor that I yanked out of Redwing 18 and I was kicking around the idea of building a boat that would be well suited to the motor. Iíve looked at the Devlin Candlefish but thatís best with a long shaft motor. Iíve also looked at Tango Skiffs, they seem to be short shaft specialists.
    Maybe 14 or more feet, 6ft plus beam, open boat, maybe even something like a power launch. Call it a putter around open day boat.
    Any other ideas?
    Bill
    Default Re: Perfect boat for a honda 20
    Generally, the more V in the hull aft, the lower your transom will be with a short shaft. Remember that the anti-ventilation plate needs to be even with the hull bottom. So, flat bottom designs will likely provide more choices for using a short shaft in the size you are looking at. Make sense?
    Of course, flat bottom may not suit your needs or wants.
    Aug 2017
    Kennebunkport, ME USA
    Amesbury skiff- 16 ft, fairly beamy (5.5ft?) lapstrake, flat bottom. Perfect skiff w/20 hp. A long time ago I had one with an 18 Evinrude. Great day boat!
    Mar 2021
    Southern Vermont
    I built this one, works great with a Honda 20hp.
    FS14LS
    https://www.boatbuildercentral.com/p...plans-fs14-ls/
    Mar 2021
    Southern Vermont
    FS14LS
    Would require a transom mod for the short shaft.
    Oct 2019
    Ladysmith, BC
    I think the Point Comfort 18 was designed for a short shaft about that size
    May 2002
    Gone West!
    Paul Gartside has a 14-footer thatís shy of the 6í beam you referenced, but might suit.
    https://store.gartsideboats.com/coll...iff-design-189
    Itís traditional lapstrake construction and glued-ply lapstrake may be an option.
    Jul 2016
    Duluth, MN, USA
    I forgot all about this line of boats. Iíve always wanted to build one of these or either the 13 or 15 garvey.
    Quote Originally Posted by VT_Jeff View Post
    FS14LS
    May 2006
    Ballard
    Check out the Ben Garveys in the WB shop.
    Yeadon is right, of course.
    Jul 2016
    Duluth, MN, USA
    I reached out to Hylan, who replied promptly that a short shaft would be just fine on the Ben Garvey. Great looking boat!
    West Boothbay Harbor, Maine
    ďEventually, all things merge into one, and a river runs through it. The river was cut by the world's great flood and runs over rocks from the basement of time. On some of those rocks are timeless raindrops. Under the rocks are the words, and some of the words are theirs."
    Dec 2015
    Dorset, UK
    Jericho Bay Lobster Skiff uses 15-20hp short shaft.
    https://www.woodenboatstore.com/coll...32022118531162
    Rich just built one on here.
    http://forum.woodenboat.com/showthre...-Lobster-Skiff
