Re: Caledonia Yawl build downunder
Does the hole for the outboard need to be rectangular? When I went to do this on Marianita I started with figuring out what the actual "footprint" of the OB was as it passed through the hull, gave my self a bit of room and cut out the resulting potato shape. On the Eun Mara there isn't enough room to tilt the motor up while sailing without creating a ghastly large hole in the boat right next to the stem so straight up and down through as small a hole as I could manage seemed like the best option.
I try to not think about what that hole in the bottom is doing to the drag profile of the hull, it would be nice to fit a filler piece but there just isn't room.
Use a fine toothed jigsaw blade, don't worry too much about tear-out, you are going to have to sand back the edges anyway to seal up the exposed plywood anyway.
H.A. Calahan
