Results 71 to 105 of 161
Thread: Caledonia Yawl build downunder
    May 2015
    Guerilla Bay, NSW, Australia
    Default Re: Caledonia Yawl build downunder
    Click on the word “thread” in the 3rd line of his post , it takes you straight there Neil
    Well spotted Moriarty :-) I should have seen that..................................
    Jul 2010
    northeast Ohio
    The thread is Building Ninigret
    post numbers show on the right side of the blue bar above each post.
    May 2015
    Finally managed to get plank number 2 glued onto the port side - a major step forward considering the recent very heavy rain and humid weather - my physical make-up doesn't handle heat & humidity very well these days.
    Happy with the fit & shape of this plank - starboard side is cut & ready to have its gains cut.
    I cut the gains as 12 inches long - wonder if I should go longer?
    Regards Neil
    Aug 2019
    Providence,RI USA
    Hi Neil,
    It's looking great! I'm a bit jealous of your warm, moist weather.
    Just off the top of my head, I think I ended up with 14-ish inches for my gains, using 9mm plywood. It looks like you are cutting them on the bench so-to-speak? That's probably easier than on the boat, which is what I did.
    Mike
    Feb 2019
    Rathmines NSW Australia
    Iain recommends 10" to 12" gains on 6mm ply from memory, I did them at 10" on the TN
    Mike, bite your tongue mate, we're getting humidity up into the 90% range and it's making life very uncomfortable.
    May 2015
    Yes, this my 3rd plywood clinker hull & I do cut gains on the bench, though on this hull I cut the gains in the garboard after the garboard was glued in place because I was concerned about the fragility of those narrow garboard ends - cut the gains on the hull using a tenon saw and a chisel - was easier that I expected.
    The very high humidity is not nice at all - reminds me a bit of Houston that my employer sent me to in the 80's. After 1 hour of work I have to stop, though the beach is 3 minutes walk away and the water is warm (about 21-22 degrees!): -)
    Regards Neil
    NW Georgia
    Regards Neil
    Happy is good. Just curious - did you spile or use the dummy plank method?
    Aug 2019
    Providence,RI USA
    Sorry fellas! Hoping that you all don't have such extreme weather this year. It's going down to 4 degrees F. here tonight, so I'm missing the milder temps.
    Keep on truckin'
    Mike
    May 2015
    Quote Originally Posted by dalekidd View Post
    I used the template plank method - spent several weeks trying to get spiling to work & failed - I was getting rather grumpy with my inability to get plank number 2 cut - maybe next time...........................
    Regards Neil
    NW Georgia
    Regards Neil
    No judgment here. You do what works for you. I don't classify myself as a craftsman and my spiling was far from perfect. I was very nervous that I was going to mess up some very good (and expensive) plywood; but I think it came out ok - not great but ok. You're going to have a very fine boat when you finish!!!
    May 2015
    Thanks
    Regards Neil
    May 2015
    It's rather wrm and humid here but slow progress is being made, now to to the 3rd planks. A friend helped me yesterday to make up the 2 wedge shaped wooden brackets that I can clamp to the workbench - they hold the planks on edge so that I can plane the edges fair. I do cut planks with a jigsaw which tends to leave me with the wobbly edges, though planing is pretty easy and a satisfying job.
    Regards Neil
    Feb 2019
    I do love a simple solution, how thick are the planks
    May 2015
    Quote Originally Posted by Steve TN 15 View Post
    9mm bruynzeel plywood planks - made by Joubert in France.
    Jun 2011
    Central New Jersey
    That's a useful tip Neil. I see the "quality Control Officer" has given his approval.
    Steamboat
    NW Georgia
    Looks like you're coming along. Nice setup for shaping your planks. I was concerned that my planks came out fair. I can't cut a straight line with a jig saw. I don't trust my planing skills. So I decided to cut the planks using battens and a 3.5" saw. I came up with nice, smooth fair lines. All that was left to do was sand them a bit. And then of course there were a dozen or so tiny nail holes I had to fill on each plank. But my objective was achieved - nicely shaped planks.
    May 2015
    That looks like a good setup, 2 question if I may :-
    a) was the 3.5" saw a circular saw?
    b) did you cut 2 planks at the same time - i.e. cut 18mm of ply?
    Thanks Neil
    NW Georgia
    Thanks Neil
    I did use a 3.5" Porter/Cable circular saw. Best pic I have of it right now:
    I measured and cut each plank separately until the sheer planks which I cut at the same time. I was using 6mm ply, so I was cutting 12mm at once on that last cut. The saw seemed to handle it well.
    I made my planking table out of the pallet that the plywood came on. I cut it down the middle, spliced it together and put some legs on it. Worked great. I used 2x's underneath the plywood to give my saw room underneath the ply. I always cut on the outside of the curve in the batten. When I cut near the edge of my scarfed ply, I had to add some material due to the offset of the saw guide and the blade. All the material in the pic is tacked together to prevent movement. End result: on one of the cuts the batten was tacked to the plank; on the other cut the batten was outside the plank; which translates into only one set of nail holes needing to be filled.
    The nails stayed in the batten after each cut and were reused on each new cut. I used small coated sinker nails. They wanted to stick the first time, but after coating wore off, the batten came up easily. I might use finish nails next time (if there is a next time).
    It worked well for me. I would use the same method again. Your mileage may vary.
    (just noticed: that might be a better pic of the saw - LOL)
    May 2015
    3 planks on each side. 4th plank template ready, rolling bevel and gains planed. 4th plank scarphed and glued.
    Time for a cuppa :-)
    May 2017
    North Bend, OR. USA
    Nice progress Neil! Quite satisfying to see that shape emerge, isn't it?
    Ken
    Aug 2019
    Providence,RI USA
    Thumbs up, Neil! It's looking great.
    Mike
    Jul 2010
    northeast Ohio
    Wonderful workspace you have there also.
    Jun 2011
    Central New Jersey
    Nice progress Neil!
    Steamboat
    May 2015
    Thanks all - I am hoping plank 4 will live up to your expectations :-)
    Regards Neil
    May 2015
    At last 5 planks on each side. Recent progress has been glacial due to lots of complexity including a stretched Achilles tendon which was (for me) surprisingly sore but now much better. Weather has been extremely wet this year so we are hoping for a drying off mid-year. Our new dog D'Arcy has had his cleft palate operated on which meant trying to keep a 7 month old golden retriever from chewing anything at all for 2 weeks. Not an easy task trying to 100% control a dog of his age, but the healing is going well and he is displaying all the classic signs of retriever!!!!!!!
    Some photos:
    Regards Neil
    Schleswig Holstein Germany
    Glacial, but progress Neil
    Looking good!
    Cheers
    Max
    Dec 2010
    UK
    Looks good Neil!
    May 2015
    The mysteries of clinker boat building, how a plank like this:-
    Can look like this on the hull :-
    Perhaps I should ask D'Arcy, our latest addition he seems to like lying outside in shavings & sawdust. I just need to cut the gains in the 2 shear planks & glue them on :-)
    Regards Neil
    May 2017
    North Bend, OR. USA
    Wow Neil, nice progress! Doesn't seem glacial to me at all!
    Ken
    Mar 2019
    Rushworth, Australia
    Is that it for planking Neil? Six months isn’t too bad for planking up . Looking great.
    Jun 2011
    Central New Jersey
    Looks very good to me Neil, and very familiar for some reason.
    Good luck with the new dog, I love retrievers but they always challenging the first two years. After that we become the best of friends. When young, if I did wood work around the house mine would tear it back out when I went to work the next morning. I found the only way to keep them out of mischief was to play with them to the point of exhaustion, mine not theirs. I will say, the two that I had (one at a time) were excellent baby sitters. They have more patients for kids and puppies than any human.
    Steamboat
    Dec 2010
    UK
    Looking good Neil!
    May 2015
    1 more plank left to glue on :-)
    Did I mention we live in a nice spot - here is a photo from this mornings walk..................
    And yes Steamboat I do now try to tire them out before D'Arcy gets up to mischief, though he seems to fully recharge in 1 hour !!!!!! In this photo he has nicked the bed from Chilli who regularly shows him tricks he has never seen/felt before - current favourite is grabbing one on his hind legs in her jaws lifting it up & watching him fall over. Still he is fun :-)
    Regards Neil
    May 2017
    North Bend, OR. USA
    I would say "a nice spot" is a bit of an understatement! Beautiful view.
    Ken
    Glorious looking morning there Neil and good to see some progress, ‘looking forward to seeing her flipped over for framing
