Page 5 of 5 FirstFirst ... 45
Results 141 to 158 of 158
Thread: Simple Proa
  1. #141
    Default Re: Simple Proa
    Me? I don’t know. Best guesses are what I got.
    That’s why I posed the question. I want experienced feedback, if there is any. Guesses, conjecture ps and thoughts are invaluable, too, because I have no idea. I’m working with 100% “book” learning.
    The reason for some of these exploratory lines, though, is the nature of the build. This is not pick what’s best and do it proper-like; this is catch as catch can, Rocketships From Dirt type building, and I have no IDEA what wood may present itself for cross beams and platform, yet.
    I’d like to explore all the options with the smart kids before I just go ahead and start doing stuff.
    Truth be told, that damned home made trimaran thread had me thinking about folding beams.
  2. #142
    Nothing has happened on the boat. Much actual work to do, and much heat have precluded boat work.
    Much heat.
    The next steps involve epoxy work, so I have to wait for this heat wave to pass.
    Meanwhile, I just look at the model, and the hull, and look some more. I keep thinking about the crossbeams and platform, too, and how best to build that assemblage as lightly and strongly as possible with the available resources.
    I think this boat is being born in the spirit of the originals in that way, at least; I am making the best of what I have to make the nicest boat I can with it. I hope, anyway.
    I continue to ponder three crossbeams (or maybe four even!), if only because the platform needs to be strong enough to support all the weight of the sailor(s), and the wider the span between beams, the heavier the platform slats need to be. And, that is the same thinking with the ama connection; an extra lashing is not that big a deal in relation to the benefits of having a better supported platform, for the same weight.
    And, yes, I know what it’s like to lash stuff together every time you use it. It’s all guesses and compromises.
    The real answer will reveal itself when I can do a few full size tests with mock-ups. Soon enough, I hope. We are due to get some habitable overnight lows soon.
  3. #143
    Lean and nosey like a ferret
  4. #144
    Yesterday, while shuffling the hull around my current paying job, I just kept noting some unfairness in the windward side of the hull; just some area where the bottom and side curves made a weird, harsh wonk.
    The spreader stick slipped and as the beam shrank, the wonk went away...
    So, the new beam at sheer is about 10cm less? I havenít measured. The side panels look much more smooth in their transitions to and from pointy, and the whole looks much more cohesive.
    Also, the weather may have broken, and if it stays this low overnights, I can start to tab this hull together!
  5. #145
    Fredericton, New Brunswick
    Very fine.
  6. #146
    This is the end... I’m not sure which. This shows the asymmetry and the tilt to the bottom panel well, I think.
    Yeah, I know, but the other end looks exactly the same. This is the side I had to remove the “wonk” from. There was a weird knuckle towards the end. Looks smoother to me.
    I’m going to use stems so I can screw the panel into something, as well as glue them. I think this will help keep the stem seam on the centerline, and it will give some meat to screw an outer rub strip into.
    This is an absolute jackelope of a monstrosity, already.
  7. #147
    Feb 2016
    Tryavna Bulgaria
    Now I get it, that's a hard shape to achieve.... I almost can't believe the 2 photos are the same hull.... Very cool bow and rocker.
    That flat bottom will take a load!!! Looking good.
    Finally back 2 it. Good Luck!
    Keep Shunting bro.......
  8. #148
    Thanks, Yo! I tried very hard to combine a LOT of different desires into a very simply made hull. I hop it all works as planned. Hahaha.
    I am finally able to contemplate using epoxy, again, so Iím messing around. The next few steps will be tabbing and gluing up the hull, so the heat was a HUGE factor in the delay.
    Well, that, and actual work to earn money. Haha.
    Baby steps toward a fall launch, I hope.
  9. #149
    Jun 2007
    Looking like some excellent TLAR engineering!
  10. #150
    Jan 2018
    Mosier Oregon
    Nice Work!
    Looks strong and fast.
    -Derek
  11. #151
    Thanks all.
    Unfortunately, I think there has been a MAJOR problem occur with one of the hull panels. Not one of the main hull panels, but...
    I donít know, and, frankly, I donít really WANT to know, at this point.
    It may be bad. Like, start over bad... but, at least I wonít have to start form total scratch, if I do.
    Now, off to ignore it for a few days, and come back with fresh eyes!
  12. #152
    I couldnít ignore it.
    There was a major failure in one panel. The inner ply simply broke apart, and the break spread outward. The panel is totally compromised, and would have failed completely except for the outer plies. I mean, the good news is, the stuff endured a failure fairly well. I guess thatís good?
    It could have been a random weak spot or undetected (by me) void, or just a flaw in the wood... or, all the inner plies of this stuff are just pure garbage.
    The literature says itís gravy, but this panel makes me too doubtful. I may never know if the damned thing sails, now.
    Insert seven minute long uninterrupted string of filthy swears here.
  13. #153
    Bugger. Bugger.
  14. #154
    Well... the good news is I have some righteous templates.
    I had doubts, and the ply wasnít exactly what I ordered, but I went ahead, and I shouldnít have.
    Meh.
    Dumb. Not my first time being dumb, either.
    Life keeps lifing.
  15. #155
    Juneau, Alaska
    Cool project Rob! Thanks for sharing it.
    -Jim
    Sucker for a pretty face.
  16. #156
    Sep 2020
    Michigan
    Could you post a picture? I would like to learn what not to do from the failure.
  17. #157
    There isnít much to photograph. There is a crack inside the plywood which allows it to bend along the internal failure.
    A simple material failure.
    The way to avoid it is to use good materials.
  18. #158
    Well, if I manage to sell a few more drawings, I may be able to to buy a few more panels and try again.
    My dude found a good source of some nice 4mm ply, and has promised to eat it if it sucks when itís delivered this time.
    I stare at the model every day and dream...
